Results 1 to 16 of 16
    Active Member Two Rings ayjay's Avatar
    Jan 04 2014
    C6 Z06
    United States
    White Dog 1 Piece Bi-Pipe Group Buy
    Trying to get a group buy together for a Single Piece Bi Pipe. Tired of your throttle body boots ripping here is the answer.
    Please comment below if you would like to purchase. I have added the link for the product. The product may also come in a bigger size if needed.
    http://www.whitedogracing.com/store/
    Website Description of Product is
    V-Banded One Piece Bi-Pipe
    The ultimate solution to the stubborn stock throttle body boot. This bi-pipe is one piece, and connects to the throttle body via a aluminum v-band completely eliminating the throttle body boot. A great complement to a set of SRM, ER, Apikol, or other brand intercoolers. It is offered in a few variations, first the 54mm version and secondly the monster 60mm version. Can be coupled to the stock throttle body, RS4 throttle body, or the Hemi 80mm throttle body. All versions include W/M bungs installed. Location can be customized, please contact us when ordering.
    Stock map sensor location retained.
    Stock clutch fan can be retained with trimming of the fan, although deletion of the fan is recommended. Contact us regarding clutch fan delete kits.
    These are built to order and may take up to 14 business days to ship. We do try to have stock size throttle bodies in stock, however we may require your throttle body be sent in for welding to complete your order.
    A $50 STOCK throttle body core fee is INCLUDED in the price of both the 54mm and 60mm . If you would like to use an RS4 or 80MM Hemi TB they MUST be shipped in beforehand for welding.
    You can choose to mail yours in ahead of time or send us your old one upon installation of your new unit.
    These will be flow tested before we all submit our purchases. We should have that information by early next month.
    10 buyers 10% discount - total with shipping and core fee $395. After you send your core in that's $345 shipped to your door.
    15/15% - core and shipping = $377.50 after core fee $327.50.
    20/20% - core and shipping $360. After core fee $310.00
    The 60mm version is the same
    10/10% - $417.50 core + shipping $367.50 after core
    15/15% - $398.75 core + shipping $348.75 after core
    20/20% - $380.00 core + shipping $330 after core
    Veteran Member Four Rings Tjtalan's Avatar
    Jul 19 2014
    Tulsa
    This looks good, thinking vary hard lol.
    Veteran Member Four Rings NOTORIOUS VR's Avatar
    Jan 29 2009
    Would have been really nice if they used a VANJEN style clamp @ the TB to allow for some flex IMO.
    Veteran Member Four Rings bakedziti's Avatar
    Oct 23 2014
    _
    I have no skin in this game, but be careful with your group buy talks (unless this is an "approved vendor"), or you could end up like this thread.
    http://www.audizine.com/forum/showth...nstalled/page5
    2014 S4 | MGM | 6MT | ABG | ACC | ADS | AFS | ASA | B&O | MMI | Sport Diff | 034 DP 57/187 | 034 Adjustable UCAs, Toe Arms, Front + Rear Endlinks | 034 LCAs | 034 Strut & Engine Mounts | 034 Trans Mount + Insert | AWE Touring + Res DPs | Bilstein PSS10 | CR15 | G5-r | H&R Sways | Merc HX | P3 | Ringer S3+ Clutch & FW
    1999 A4 Avant | Cactus
    2001 S4 | 6MT
    Gone: 2011 A4 | 6MT
    Jul 04 2012
    Woodbridge, VA
    The only way I'd consider it is if I'd go rs4 sized coupled with rs4 sized SRMs. But I'm pretty sure I'd have to also upgrade the the charge pipes and y pipe to see any gains. And id need to retune. Are these true assumptions? Anyone know?
    Jan 04 2014
    C6 Z06
    United States
    Quote Originally Posted by bakedziti View Post
    Thank you for the heads up!
    Veteran Member Four Rings erykv1's Avatar
    Jul 01 2014
    'murca
    looks nice, good to see someone step in where APR discontinued.
    however theres just no way to get the same cross sectional area like APR had.
    notorious brings up a very valid point as well.
    Jan 04 2014
    C6 Z06
    United States
    Quote Originally Posted by NOTORIOUS VR View Post
    Good Point. I will ask if there is a way we could do that as well.
    May 16 2008
    WA
    Hmm, will be interesting to see what happens here, on paper it seems like a nice and simple solution to a common problem.
    (granted i am part of the 1% of b5s4 owners that has never had an issue with the TBB, but i know in even saying that i have just jinxed myself lol)
    Aug 30 2007
    nyc
    I may be interested in the 80mm hemi version
    c5 A6 tip
    this n that
    Established Member Two Rings Ramathorn420's Avatar
    Jun 05 2010
    01.5' S4 Avant, 02' Allroad, 89' 90 MC2 Swap
    Lima, OH
    I didn't choose to do a VenJen clamp for costs reasons although it is something that I could do although I haven't experienced any issues with the current design.
    Jan 29 2009
    Quote Originally Posted by Ramathorn420 View Post
    I wouldn't really expect any issues with the solid V-band (are you at least using the oring'd version?) but it's just a nice touch, plus the engines in these cars move quite a bit.
    Jun 05 2010
    Lima, OH
    Yes sir the vband rings have machined grooves for a rubber o-ring style gasket. I do agree the VENJEN clamps are very appealing! I've had pretty good success using the hump hose connectors as they give a decent amount of flex at the intercoolers. The design is also going to continually be improved, should an issue arise it will promptly be addressed
    White Dog Racing LLC
    Active Member Four Rings aysix's Avatar
    Feb 06 2012
    Las Vegas
    vanjen clamps are too expensive for this platform.
    Jun 05 2010
    Lima, OH
    agreed
    Quote Originally Posted by aysix View Post
    Jul 01 2014
    'murca
    what gauge thickness is the tubing?
