PM or text for quickest response, Blake 602-487-3838:
EFK Kit
- 15 Amp Toggle Switch
- 8-10' 14G power wire to run from fuse panel to switch to fan.
- 15 Amp Fuse and blade fuse holder
- Ground sheet metal screw and washer, fan mounting hardware
- Shorter serp belt to delete the clutch fan assembly.
- Electrical plug disconnect. So when you put the car in the service position you can disconnect the power wire from the car and pull away the rad support instead of always cutting the wire.
14" Fan kit $100
14" is the largest you can go with out cutting or chopping. This is the easy drop in fan, set in place with the mounting legs already attached, place four pilot holes and bolt to rad support (hardware included). 130F in Arizona works great so will work anywhere.
16" Fan upgrade, add $35 in place of the 14" fan. Be warned! The 16" is not a drop in fan, you will cut and chop and cut and chop and cut and chop to fit it in place. It will fit nice and flush once done, but be warned it takes time.
$135
What ever fan is left I will sell by itself, buyer of the kit gets the pick of either the 14" or 16". Best to contact PM as may not see a response here.
[IMG][/IMG]
