Thread: Rod bearings
    Established Member Two Rings darkstarghost's Avatar
    Feb 08 2014
    2014 Estoril blue s4
    Rod bearings
    Hey guys, Im wondering if anyone here has replaced their rod bearings on the 3.2 or 3.0. And if any of you have any tips or tricks. Im whole heartedly trying to avoid dropping my sub frame (which sucks). I have my oil pan and sump off, just struggling with the bed pan atm. Any help is greatly appreciated
    Veteran Member Four Rings lettuce's Avatar
    Jun 19 2015
    Boston
    You'll probably have better luck posting this and/or searching in the V6 engine tech board.
    B8 A4 - Eurodyne-tuned F23L - 12.6 @ 107 on 93
    Feb 08 2014
    curse this 3.2, zero diy ahahah thanks man ill give it a look
    Veteran Member Three Rings themadscientist's Avatar
    Oct 10 2010
    Las Vegas
    It's not the type of thing you do with the engine in the car.
    2005 A4 Avant 1.8t QTM
    Feb 08 2014
    Well ive done it before, just not on this specific engine. Its fine if i can just walk the bearing out and replace, where im stuck is the bed pan. All bolts removed, and this thing is on there tighter then a nuns twat. And i had my certified mechanic friend come over and even he's stumped as to why this bed pan wont come off.
