Results 1 to 1 of 1
    Veteran Member Three Rings Crispy222's Avatar
    Mar 15 2008
    Syracuse, NY
    AWE Tuning 2.7T/4.2 Lightweight Flywheel[SOLD]
    [SOLD]
    AWE Tuning 2.7T Lightweight Flywheel
    Part# S4LWFW, Regular price new $749.95 from AWE
    http://www.awe-tuning.com/clutch-kit...minum-flywheel
    Flywheel is used, less than 4,000 miles. Never launched, never used for high boost. Pulled and replaced by a CM850SS. CM FX400 clutch was already sold.
    Looking for $400 shipped, OBO
    Fits:
    MAKEMODELSUBMODELENGINEDRIVETRAINTRANSMISSIONYEAR
    ALLROADBASE2.7L TURBOQUATTROMANUAL2001-2001
    ALLROADBASE2.7L TURBOQUATTROMANUAL2003-2003
    ALLROADAVANT2.7L TURBOQUATTROMANUAL2000-2001
    ALLROADAVANT2.7L TURBOQUATTROMANUAL2003-2003
    S4AVANT2.7L TURBOQUATTROMANUAL2000-2002
    S4SEDAN2.7L TURBOQUATTROMANUAL2000-2002
    Will also bolt to a belt driven 4.2 Motor for a manual swap. Transmission spacer is required when using the 2.7t flywheel. 1.2mm spacer required between crank and flywheel for proper starter alignment
    98 Passat Var,2L,IE/JE,ARP,034,SPA,50tr,3tbe,FX400,BigREDs,Uni440,Fuel ab,Sterns,Mocal,Bils,JHM
    LINKS:2L Build,Further PerformanceHausOfHarnessD2 S8 40vQM
