Results 1 to 19 of 19
    Senior Member Two Rings freekonwheelz1's Avatar
    Apr 07 2014
    1995 Mazda Miata 1.8 daily, 1965 C10 SWB gift
    Oklahoma
    just bought maestro
    first off, wow... maestro is a big bite to chew on.
    secondly, i flashed the stage 1 base file onto my ECU and it had no change in performance at all the first time and only a 3 psi increase in boost the second time i flashed it. is that normal for the first time to not always be successful and is 11 psi where a stage 1 car sits?
    thirdly, is there a stage 2 file for AWM motors? i didnt get one with my software...
    fourthly, i keep getting CELs for various things like ecu power loss, powertrain data bus missing message from abs controller, and pressure drop between turbo and throttle valve... none of which occurred before the flash(es), EVAP incorrect flow.
    my car is a 2001 Audi A4 TQM with a cat-delete, borla catback, forge 007, 4 ply boost hoses, snub mount, RA4 clutch kit, intake phenolic spacer, and upgraded coil packs.
    2001 A4 TQM. AWM motor - TR11 Intercooler, ECS Snub Mount, RA4 240mm clutch kit with lightweight flywheel, SAI delete, PCV delete with catch-can install, Borla turbobackFS, Forge 007 DV, Raceland Coilovers, weighted shift knob, x2 10" clarion subs, 0/1 awg power and ground, pioneer door and deck speakers, clarion 6.3" headunit, HX35 t3 turbo (installing), E85 conversion (installing), AEB head (to be built)
    Oct 30 2008
    B5, B7, B8, 8V, 4M
    Big Lake, MN
    Whoa, you probably flashed the wrong file. Which one did you use?
    Screen shots please.
    2020 SQ7- Wife's ride
    2000 S4- Working?
    Apr 07 2014
    Oklahoma
    Quote Originally Posted by redline380 View Post
    i flashed the stage 1 file for an AWM audi b5 a4 motor.
    here is my most recent VAG-COM scan,
    Tuesday, 08 March 2016, 15:52:20:41838
    VCDS-Lite Version: Release 1.2
    Control Module Part Number: 4B0 906 018 CH
    Component and/or Version: 1.8L R4/5VT G 0007
    Software Coding: 07500ect..
    Work Shop Code: WSC 77873
    VCID: 69A59DC90061
    Additional Info: XXXXXXXXXXXXXXXXX XXXXXXXXXXXXXX
    5 Faults Found:
    18057 - Powertrain Data Bus: Missing Message from ABS Controller
    P1649 - 35-00 - -
    17840 - Secondary Air Injection Solenoid Valve (N112): Open Circuit
    P1432 - 35-00 - -
    17695 - Boost Pressure Control Valve (N249): Open Circuit
    P1287 - 35-00 - -
    17705 - Pressure Drop between Turbo and Throttle Valve (check D.V.!)
    P1297 - 35-00 - -
    16825 - EVAP Emission Control Sys: Incorrect Flow
    P0441 - 35-00 - -
    the SAI and N249 valves are deleted so thats why those codes are there.
    the car will start up and idle and drive just fine but throws random codes and wont go above 11 psi.
    here is a screenshot of the files that came for the AWM motor.
    Veteran Member Four Rings Avant Nate's Avatar
    Dec 23 2009
    2001 Audi Allroad 6MT,1999 Yukon Denali, 1987 4Runner
    Boulder, CO
    Can't you just uncheck the deleted mods with an awm?
    99.5 1.8T QMS: GT2860RS .63 T3, PSI T3 Mani, Turbosmart 38mm EWG, Unitronic 415, Forge 007,Treadstone TR18 FMIC, Walbro e85 450, FSI coil conversion, 3" DIY Magnaflow/Dynomax VT exhaust
    Depo ecodes, DDM slim 6000k, VDO boost gauge, PLX AFR, Greddy profec B EBC,
    H&R sport springs, 034 rear sway, 034 rear diff carrier, A8 fronts,18x8 OZ Superleggera
    Next up E85, efr 7163 or gtx3071r?
    01 allroad 2.7t 6mt, GIAC stage 1
    Veteran Member Four Rings A1 A2 German's Avatar
    Feb 28 2005
    Audi A4 B5, Audi Fox, Audi AMLS TT, GS450, CB175, CL175
    Tempe
    This is exactly why I have not bought Mastro yet. You buy a flashed 630cc ECU and just plug it in (with proper maf, injector size, fpr bar, etc) no issues.....ever. You buy this, you get all kinds of stuff going on. ~Fine if not driving the car, but what if you have to. What'd it set you back?
    Dec 05 2007
    I run maestro on my awm...but would not for the stock turbo. This software is engineered for custom tunes. Not to mention, I don't know how to tune. Forum member tunes my car for me.
    One thing I can say, you can squeeze a shit ton of power out the na aspect of the 1.8t. It was done to my car. Low end and high end tuned. Agressive timing to the point I hardly drive in boost. I can also beat any car off the line too, mini vans and all. Regular driving.
    Apr 07 2014
    Oklahoma
    yea, the stock turbo is just for now. i bought maestro so i can change my setup at my will rather than having to wait on someone else to tune it or being limited to certain mods because they cant tune for other mods. soon to be at least a K04 car with 550 cc injectors, but no promises lol but i figured out two of my problems that could be causing more of my problems. firstly, i have a bad relay for my ecu power. once that is replaced i should have less issues. second, i figured out that deleting my N249 causes code P1297 under harder acceleration. only issue now is my evap and the throttle body wont align itself properly anymore... i think i need to pull my throttle body and clean it...
    i have the N249, boost pressure, and evap CEL turned off now. hopefully in the morning i can swap the relay out and reflash the ECU with the new stage 1 file and have no more issues.
    does anyone have the stage 2 file or am i forced to attempt to make my own? no worries. im going to need to make my own anyway when i upgrade my maf and turbo.
    Apr 07 2014
    Oklahoma
    still dont understand why i am getting
    P1649 - 35-00 - -
    Apr 07 2014
    Oklahoma
    car wont start or align the throttle body now... help?! i tried flashing back to stock, ive tried holding the positive and negative terminals together off of the battery, ive tried checking the fuses and relays, ive tried everything i can think of to get this thing running... every time i try to flash something onto the ECU i get a session timed out error of maestro...
    Veteran Member Four Rings GrapeBandit's Avatar
    Dec 13 2010
    FL
    does maestro come with any type support(phone/chat/email) for when ppl get jammed up in these situations?
    r.i.p.CASABLANCA B5 1.8t
    r.i.p.BRILLIANT YELLOW B5 30V
    PCV? Just dump it on the ground!
    Oct 30 2008
    B5, B7, B8, 8V, 4M
    Big Lake, MN
    Yeah, Tapp is usually quick at email support if your issue is serious enough. This one sounds like it fits the bill.
    2000 S4- Working?
    Dec 05 2007
    You just need to understand the software. Follow the instructions for each step properly and you will be fine. Check and uncheck criterions for your car. If mods don't match what you are flashing, expect issues.
    But I don't quite think you are understanding how our ecu works. After you flash the file onto your ecu, car will initially run like straight poop. It is during this time the ecu is actually learning your car. You need to give it time. First let it idle and fluids get up to temp. If you take off right after the flash, car will run incredibly lean...and like poop. After fluid get up to temp, you still need to let the ecu learn the car. Go for a spin and drive casual. No boosting. At this time, ecu is learning load calculations for proper fueling. Drive different speeds and do speeds to use all gears. Slowing down to downshift and so forth. You need to do this for roughly 15 minutes. At this point, ecu should have learned the car by now and things will be just fine. You can boost with no issues and so forth.
    As for the throttle body adaption, Eurodyne uses the same measuring blocks as Ross Tech. So in a nutshell, you have a full version of VSDS with Eurodyne. I sold my cable with laptop after purchasing the suite because it was no longer needed. And...you can use the diagnosing section for all cars. That section of the software is not locked onto your ecu as maestro is. Use the measuring blocks below from Ross Tech, including the measuring block for the throttle body adaption. But do what was stated above first.
    http://www.ross-tech.com/vag-com/m_blocks/
    Dec 05 2007
    Wanted to add, that it seems your issue really is from loading the flash incorrectly and not knowing about the ecu having to learn load calculations. Also with flashing, you need proper battery voltage on both your laptop and car.
    Apr 25 2014
    Downey, CA
    Fix all codes before flash... or fix them first and then see how it boosts. You're not going to get anywhere regarding boost issues if you hsve a CEL specially about pressure drop...
    Sent from my SM-N910T using Tapatalk
    Using Tapatalk
    Dec 05 2007
    I can see you also don't understand how this softwate works. There is no going back. He already registered the ecu. Ecu is basically married to the cable and software now, with no possibility of divorce...unless you know how to play with ecu coding. There isn't even a stock base file. Starts with stage 1 with stock turbo. Only way for him to do what you are suggesting is to swap in a different ecu.
    Apr 07 2014
    Oklahoma
    I got it running. Issue was a relay went bad halfway through a flash and new relay didn't fit in correctly. So I made the new one fit by repinning the plug so the new relay matched the old relay and then it worked fine. Only issue now is the car refuses to idle. I am loading just the base stage 1 file my software came with using the cable it came with on a car with sufficient voltage. I only flash with the car hooked up to the battery charger to avoid voltage issues.
    Oct 30 2008
    B5, B7, B8, 8V, 4M
    Big Lake, MN
    You either need to run throttle body adaption, or you could have a massive vacuum leak. I usually forget to plug everything in and have a freak out moment when my car doesn't run.
    2000 S4- Working?
    Apr 07 2014
    Oklahoma
    i jsut got back to my shop where my car is parked. i am gonna run TBA and check for any leaks and codes and if nothing turns up just flash the stage one base file to the ecu from the eurodyne server instead of from a file.
    Apr 07 2014
    Oklahoma
    everything is fine now that i flashed from the eurodyne server. now i just need to make a file to remove my cel for things i have modded or removed...
