Results 1 to 15 of 15
    Veteran Member Four Rings chrissurfr's Avatar
    Apr 26 2005
    Houston
    Rear brake job. RS5...do rotors need to be replaced too? 20k miles
    Hey guys,
    I just got a warning light in my car that says I need new pads. I don't think it could be the fronts since I got them replaced at 12k miles. I'm now at 20k miles.
    How much mileage are you getting out of the rears? Also, do just the rear pads need replacing or do the rotors also need to be replaced?
    Thanks,
    Chris
    2017 Cement Grey TRD Pro 4runner
    2014 Suzuka Grey RS5 >:)
    • AWE Track Exhaust with center muffler straight piped
    • H&R Street Coilovers
    • BBS CH R - Gold with red caps
    • eCode headlights
    • Eventuri intake
    • JHM Stage 2 ECU/TCU
    • other things I forgot about
    Veteran Member Three Rings 1illA6's Avatar
    Aug 20 2012
    Arizona.
    Not sure on mileage, but I helped a buddy do his. We just pad slapped & the rotors had plenty of meat on them.
    Vagcom & about 1hr you can get them done all around (pads), very easy car to do.
    Apr 26 2005
    Houston
    Quote Originally Posted by 1illA6 View Post
    Thanks. The rear rotors aren't cheap at all. I've never tracked the car so I would anticipate the rotors are still good.
    • eCode headlights
    • Eventuri intake
    Aug 20 2012
    Arizona.
    Quote Originally Posted by chrissurfr View Post
    Yeah they aren't, why my buddy didn't replace them. Figured do them on the next go around.
    Oct 09 2008
    No one can really tell you as it depends on the thickness of the rotor.
    The Awesome™
    Apr 26 2005
    Houston
    Just got car checked...need to rears pads a rotors. The rotors are worn. Cost is looking to be $1500.
    Is there a non-OEM option out there? Anything better for reasonably more money?
    ECS only has fronts rotors, no rears available.
    • eCode headlights
    • Eventuri intake
    Sep 27 2015
    OH
    Check out rock auto site for parts usually solid pricing. I checked out rear rotors for a rs5 13 and I think they were $499
    Apr 26 2005
    Houston
    Should I go with a different pad or OEM?
    • eCode headlights
    • Eventuri intake
    Nov 19 2012
    Irvine, CA
    I am looking for a non-oem way to do my rear brakes. however i have heard that it messes up your Parking Brake if you put an different rotor on the car. can someone confirm?
    Current Vehicle:
    2013 Audi RS5
    Daytona Grey | Carbon Ceramic Brakes | Bilstein PSS10 Coilover | Custom Sport Exhaust | Eurocode Sway Bars Eurocode End Links | LYKT Sport Control Arms
    Sponsors: Bilstein US | Eurocode
    Past Vehicle:
    2014 Audi A5 S-Line Ibis White
    2008 Audi TT V6 Ibis White
    Senior Member Two Rings Canadianwraith's Avatar
    Dec 30 2014
    London, Ontario
    Adam's Rotors?
    2009 S5 / Meteor Gray / Fast Intentions / JHM Tune / RS5 Grille / Honeycomb Fogs /20 x 10.5 Niche Targa M129 with 285/30/20 / AWE Filter / 034 Inlet Hose
    Sep 27 2015
    OH
    Seems unlikely it's just a rotor,
    Aug 04 2010
    Queenz/Westchester
    Veteran Member Three Rings NuVega's Avatar
    Feb 06 2010
    Las Vegas, NV
    Quote Originally Posted by zhclvn View Post
    Like a different design rotor or same design but just different maker? The only way I believe the parking brake would be affected is if you don't have the same diameter, since all it does is press the pads firmly against the rotor when engaged.
    Instagram: donomoko
    - 2014 S5 3.0T Prestige - : Plain ole S5 w/ a few cosmetic mods...
    Oct 09 2008
    FWIW it looks like FCP has OE rear rotors for 550 a piece. No aftermarket ones yet.
    I'd go with the same pad material as the fronts.
    The Awesome™
    Nov 19 2012
    Irvine, CA
    Quote Originally Posted by JoshDub View Post
    ECS has a set for about 1K :( NOT CHEAP.
    I even think my front brakes have the wrong pad because Carbon Ceramics.
    Current Vehicle:
    2013 Audi RS5
    Past Vehicle:
