2013 allroad.
Pulled out of the driveway to pick up the dog from the vet, immediately get an ASC and TPMS fault. Pull into the vet's office parking lot, cycled the ignition, fault still remained.
Got the dog, started the car again and drove for a bit, ASC and TPMS fauls disappear. CEL pops up.
I did do a VCDS scan before anyone says anything...all the pertinent modules that came up with codes are listed. Car was just in two weeks ago for 45k service which included the PCV recall and two days ago for the cellular module to be replaced (stuck in 2G with known 3G coverage areas)
Chassis Type: FL (8R0)
Scan: 01 02 03 05 08 09 15 16 17 19 36 42 44 46 47 52 53 56 5F 62
6C 6D 72
01-Engine -- Status: Malfunction 0010
02-Auto Trans -- Status: Malfunction 0010
03-ABS Brakes -- Status: Malfunction 0010
04-Steering Angle -- Status: OK 0000
05-Acc/Start Auth. -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: OK 0000
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: OK 0000
36-Seat Mem. Drvr -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
44-Steering Assist -- Status: OK 0000
46-Central Conv. -- Status: OK 0000
47-Sound System -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
53-Parking Brake -- Status: Malfunction 0010
56-Radio -- Status: OK 0000
5F-Information Electr. -- Status: Malfunction 0010
62-Door, Rear Left -- Status: OK 0000
6C-Back-up Cam. -- Status: OK 0000
6D-Trunk Elect. -- Status: OK 0000
72-Door, Rear Right -- Status: OK 0000
Address 01: Engine (DET-CPMA) Labels: 06H-907-115-CDN.clb
Part No SW: 8K5 907 115 F HW: 8K2 907 115 L
Component: 2.0l R4/4V TF H09 0007
Revision: ECH09---
Coding: 722A0013242600062000
Shop #: WSC 60807 000 1048576
ASAM Dataset: EV_ECM20TFS0118K5907115F 001008
ROD: EV_ECM20TFS0118K5907115F.rod
VCID: 356B539A940DF3969D-8060
5 Faults Found:
4698 - Function Restriction due to Faults in Other Modules
U1113 00 [044] - -
Intermittent - Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Status: 00000001
Fault Priority: 6
Fault Frequency: 1
Mileage: 73945 km
Date: 2016.03.04
Time: 13:10:59
4699 - Function Restriction due to Faults in Other Modules
U1113 00 [036] - -
Intermittent - Not Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Mileage: 73947 km
Date: 2016.03.04
Time: 13:37:09
2821 - Bank 1; System Too Lean off Idle
P2177 00 [237] - -
MIL ON - Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Mileage: 73944 km
Date: 2016.03.04
Time: 13:08:50
5668 - Mass Air Flow Sensor (G70)
P0101 00 [096] - Implausible Signal
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Mileage: 73945 km
Date: 2016.03.04
Time: 13:10:59
7663 - Boost Pressure Control Valve (N249)
P2261 00 [108] - Mechanical Malfunction
Freeze Frame:
Fault Priority: 2
Fault Frequency: 20
Mileage: 73791 km
Date: 2016.03.03
Time: 13:22:02
Readiness: 0000 0000
Address 02: Auto Trans (J217) Labels: 0BK-927-156.clb
Part No SW: 8K1 927 158 HW: 0BK 927 156 AL
Component: 0BK 20TFSIUSA H16 1003
Revision: --H16---
Coding: 000002
Shop #: WSC 00000 000 00000
ASAM Dataset: EV_TCMAL551211 002020
ROD: EV_TCMAL551211_AU48.rod
VCID: 74EDAE9EDFF7AA9E6A-8020
1 Fault Found:
2505 - Torque Management Feedback Signal A
P2637 00 [044] - -
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Mileage: 73945 km
Date: 2016.03.04
Time: 13:11:02
Address 03: ABS Brakes (J104) Labels: 8K0-907-379-V1.clb
Part No SW: 8K9 907 379 M HW: 8K9 907 379 M
Component: ESP8 quattro H09 0100
Revision: -------- Serial number: --------------
Coding: 0E1D18
Shop #: WSC 06335 000 00000
VCID: 4C9D167EEF87925ED2-8018
2 Faults Found:
01044 - Control Module Incorrectly Coded
000 - -
Freeze Frame:
Fault Status: 01100000
Fault Priority: 3
Fault Frequency: 13
Reset counter: 120
Mileage: 73789 km
Time Indication: 0
Date: 2016.03.03
Time: 11:07:02
Freeze Frame:
Hex Value: 0x00C0
Hex Value: 0x4782
Hex Value: 0x0015
Hex Value: 0x1092
Hex Value: 0x0000
01314 - Engine Control Module
013 - Check DTC Memory - Intermittent
Freeze Frame:
Fault Status: 00101101
Fault Priority: 6
Fault Frequency: 2
Reset counter: 160
Mileage: 73945 km
Time Indication: 0
Date: 2016.03.04
Time: 13:10:59
Freeze Frame:
Hex Value: 0x2F00
Hex Value: 0x4006
Hex Value: 0x120B
Hex Value: 0x46B2
Hex Value: 0x0000
Address 53: Parking Brake (----) Labels: 8K0-907-801-V2.clb
Part No SW: 8K0 907 801 L HW: 8K0 907 801 J
Component: EPB-4 H01 0003
Revision: -------- Serial number: 00000001194482
ASAM Dataset: EV_ParkiBrake 001027
ROD: EV_ParkiBrake_AU48.rod
VCID: 38755AAE831F0EFE86-806C
1 Fault Found:
464384 - Function Restriction due to Faults in Other Modules
U1113 00 [008] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 160
Mileage: 73945 km
Date: 2016.03.04
Time: 13:10:59
Address 5F: Information Electr. (J794) Labels: 4E0-035-6xx-5F.clb
Part No SW: 8R1 035 746 G HW: 8R1 035 746 B
Component: H-BNT-NA H43 0901
Revision: -------- Serial number: 204J$0C7538048
Coding: 010200050006E1EF45028B4E00000403140000000000000000
VCID: 3B7F45A2BA2925E66B-806E
Subsystem 1 - Part No: 8R0 060 884 AM
Component: NAR 2012 0605
Subsystem 2 - Part No SW: 8R0 919 604 HW: 8R0 919 604
Component: DU7 High H41 0104
Subsystem 3 - Part No SW: 8T0 919 611 L HW: 8T0 919 611 C
Component: E0380 Bedient H02 0030
Subsystem 4 - Part No: 8R0 060 961 D
Component: CD-Database 4353
1 Fault Found:
03276 - Please Check Software Version Management
000 - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 117
Mileage: 73789 km
Time Indication: 0
Date: 2016.03.03
Time: 10:16:45
Freeze Frame:
Text: DUA130,Front,M,0,0,6
