Results 1 to 12 of 12
    Oct 22 2014
    Atlanta, GA
    Question Should new tires go on back or front?
    Hi All,
    I took a hit on one tire that has made it unusable. All four tires are about 15K miles used, so I am going to replace two tires to keep a match on the axle.
    My question is should the new tires go on back or front on the S5?
    I appreciate your thoughts.
    Senior Member Two Rings Canadianwraith's Avatar
    Dec 30 2014
    London, Ontario
    I'm shocked that at 15k you have tires left at all. I would think you would change them all.
    2009 S5 / Meteor Gray / Fast Intentions / JHM Tune / RS5 Grille / Honeycomb Fogs /20 x 10.5 Niche Targa M129 with 285/30/20 / AWE Filter / 034 Inlet Hose
    Veteran Member Four Rings Sweep's Avatar
    Sep 05 2014
    I believe the default torque split is 40/60 F/R, so my intuition says rear? Maybe someone who actually knows what they're talking about can verify
    Sent from my XT1575 using Tapatalk
    Ken
    2021 Q5e Prestige
    District Green
    2013 A5 Premium+ 6MT
    Glacier White | E-Codes | Bilstein | STaSIS | Roc-Euro | VMR V810 | Hankook | SunTek CXP
    Veteran Member Three Rings wangshuo1989's Avatar
    Jan 09 2016
    How much thread left on other tires? It's highly possible that you have to replace them all.
    2013 S5 Misano Red, DSG, B&O, Sport Diff, MMI+, JHM 207mm crank pulley (7PK1370 Contitech belt), APR Stage II Dual Pulley, APR TCU tune, APR CPS, CR15, IE CAI
    2018 XC90 Inscription, B&W sound, Convenience Pkg, Air suspension
    2014 Mercedes E350 rwd
    2021 BMW 540i
    Oct 22 2014
    Atlanta, GA
    Quote Originally Posted by wangshuo1989 View Post
    They are fine, as the Continental ExtremeContact DWS tires are all-season with a 50K mile warranty. I need to measure depth but at this point they have plenty of tread left. Maybe I don't drive hard enough, although my wife would disagree. :)
    Oct 22 2014
    Atlanta, GA
    Another thought I had was finding a single replacement, but I am very wary of buying a used tire. Any thoughts on that possibility?
    Senior Member Three Rings d1amund's Avatar
    Oct 27 2014
    Park City, UT
    Ideal: Replace all.
    Slightly less ideal: put 2 new on rear.
    Oct 22 2014
    Atlanta, GA
    Quote Originally Posted by Sweep View Post
    Quote Originally Posted by d1amund View Post
    Ideal: Replace all. Slightly less ideal: put 2 new on rear.
    Thanks. My gut was that rear was the right answer for the Audi. I appreciate y'alls input. (That's 'you all' for those from a more northern persuasion. )
    Veteran Member Four Rings Sgibb16's Avatar
    Jul 02 2012
    2012 A5 & 2002 Passat Wagon
    Fredericksburg, VA
    Quote Originally Posted by SpectreGadget View Post
    Could also get the new tires shaved down to match the tread depth of the other 2.
    2012 A5 P+ | Sports Package | 6MT | 35% Tint
    REVO Stage II | AWE Quad Exhaust | 034 HFC | E-Codes | FK Silverline Coils | JHM Short Throw Shifter | Eurocode HFIC Pipe | Roc Euro Intake
    TR8 Intercooler | CTS Silicone Hose Kit & Turbo Outlet | CR-15 Strut Brace | Alu Kreuz | S-line Front & Rear Bumper Conversion
    Jan 09 2016
    Quote Originally Posted by Sgibb16 View Post
    Second this, that'll be the best solution.
    As for used tires, I wouldn't worry too much as long as that tire is not damaged.
    2021 BMW 540i
    Aug 04 2010
    Queenz/Westchester
    New always goes on rear
    Senior Member Three Rings 15DGR V6's Avatar
    Jan 09 2009
    2018 Audi TTRS
    Cleona, PA
    Regardless of power split, the fronts always wear faster than the rears due to the fact that they support more load and do the turning. Put the new tires on the front if you want the new tires to get close to wearing the same as the 15K rears.
    Another trick to get more life out of your tires, if they're directional, is to have them dismounted and mounted with the insides of the tires to the outside of the wheels when they're about half worn. I got 120k miles out of four sets of tires on my 2009 S5 doing that with my winter and summer tires, and still had half tread life left on my second set of winter tires.
