Recently upgraded to a JDL tubular exhaust manifold, so I have some stuff from my old setup that needs a new home. IF IT'S STILL LISTED, I STILL HAVE IT. I'll also make deals with anyone that wants multiple items.
SPA exhaust manifold (T3 flange) -$250 plus shipping
Has some very light surface rust, but it is basically brand new. I just had to replace this because I found a tiny crack in my original manifold. I contacted SPA usa, and they replaced it for me. I only drove my car once with it on for about 20 miles, and it's been sitting since.
Tial F38 wastegate -$125 plus shipping
38mm with 1.5 Bar spring installed. I'll also include a new banjo fitting, crush washers, and bolt from my new wastegate. (right one in the picture)
034 down pipe for use with SPA manifold (b5 fitment) -SOLD
Was freshly wrapped, but it got a little torn up when I was pulling it out. Has a 3rd o2 sensor bung welded in for a wideband, but I will include a plug incase whoever buys it doesn't have one installed. It has also been cut and rewelded right before the flex to fit better. (not the best looking weld, but it doesn't leak)
Custom enlarged plenum small port manifold -$300 plus shipping
modified AWM manifold (small port runners), with a 70mm throttle body flange built by H3 fabrication in salt lake city. Has billet injector cups installed, and has port matched runners, and throttle body flange. I'll also include the tool to remove the billet injector cups.
