So I normally like to solve these types of things on my own, but this problem has been around too long without any resolve and any helpful advice would be much appreciated. I rebuilt my engine from the bottom up starting early last year, and then decided to do the trans too. The car was originally bought an awe stage 3, and the reason I started the rebuild was because what originally was a light ticking from the lifters turned into a monstrous chugging after a pull. A few lifters with holes, shaved camshaft lobes, bent rods, and smoked piston rings later the engine was rebuilt with new seals, bearings, ect. Changes to modifications were as follows: 85mm CAI, RS4 y-pipe, rebuilt K04s(New CHRAS), ER Intercoolers, APR bipipe (the lobes where bolts go through shaved), RS4 throttle body, RS4 intake manifold, RS4 fuel rail, 550cc Bosch injectors, 2.0 coil conversion, and a base tune from Daz. The rebuild was finished in late August. First problem was the car was only misfiring terribly. Turned out to be bad ICMS(hence the 2.0 conversion). Then it was firing on only 5 cylinders , which turned out to be a bad coil conversion harness. Then again the car was firing on only 5 cylinders and that turned out to be a bad fuel injector adapter. After fixing that, around octoberish, the only fault codes I had left were for a bad 02 sensor. So I bought some used 02 sensors to replace mine. At this point when I was checking fuel trims they were pretty lean with slight disparities between the banks, and also the 02 sensors would set off the open circuit intermittent fault codes, so I just decided to buy them new and hopefully that'd get rid of the problem. Surprise surprise it didn't.
The fuel trims are as follows under normal driving(some of it on the freeway)
Adaption(Idle) bank 1 sensor 1: -3.4%
Adaption(partial) bank 1 sensor 1: 25%
Adaption(Idle) bank 2 sensor 1: -3.8%
Adaption(partial) bank 2 sensor 1: 21.1%
And here are the fault codes
Friday,26,February,2016,
4 Faults Found
16684 - Random/Multiple Cylinder Misfire Detected
P0300 - 35-00 -
16689 - Cylinder 5
P0305 - 35-00 - Misfire Detected
17536 - Fuel Trim; Bank 1 (Mult)
P1128 - 35-00 - System too Lean
17538 - Fuel Trim; Bank 2 (Mult)
P1130 - 35-00 - System too Lean
Under REALLY babied driving the fuel trims are as follows
Adaption(Idle) Bank 1 Sensor 1: -5.3%
Adaption(Partial) Bank 1 Sensor 1: 17.2%
Adaption(Idle) Bank 2 Sensor 1: -4.9%
Adaption(Partial) Bank 2 Sensor 1: 9.4%
(note the disparities between the two banks)
Some other things I have noticed are; when I have VCDS open and am checking fuel trims real time, they seem to go very lean when there is a bit more load, but sometimes it is very random and under normal load on the freeway itd shoot up to 25% on both banks, also when getting off the freeway and putting it in neutral it has trouble finding its idle rpm and will bounce around for a bit dipping mostly down until it settles down back at idle after a few seconds, and when braking slightly harder than normal in neutral the rpms dip a decent amount. Other than that the car idles and purrs beautifully and isnt making any weird noises. Hope this helps get me some help on pinpointing exactly what the problem could be. Thanks for any future input.
