Results 1 to 14 of 14
    Oct 06 2013
    Cincinnati ohio
    Having problems finding correct axle
    So replacing front left axle on my 2000 atw engine 1.8 manual trans. The guy I bought car from had a spare new axle. I proceeded to install bit noticed the bolts are larger diameter and also Allen head not the triple square. Doing some searching on ecs etc and they differ from engine code however it appears the atw ones they offer also have the larger bolts. Any help would be great. Thanks guys. Here is a pick of the damaged one.
    2001 Ausi A4 Quattro- Bone stock for now!
    2004 land rover discovery II 2" rte lift
    2001 trans am ws6 cam headers all bolt ons beafed up valve train.
    1999 audi b5 a4 gt28 http://www.audizine.com/forum/showth...-Gt2871r-build (SOLD)
    2004 audi s4 (SOLD)
    Veteran Member Three Rings Wrath And Tears's Avatar
    Apr 03 2014
    17 GTI Sport
    Was the old C/V axle making noise? If not you could simply buy a boot kit and repack the joint and replace the boot. I
    2017 MK7 CSGM GTI Sport DSG
    PP (Golf R Brakes, +10HP, VAQ LSD), LP, Kessey
    LW 17" Sparco Assetto Garra's, 034 Res-X resonator Delete
    Oct 06 2013
    Cincinnati ohio
    Yep it was popping on sharp turns
    2004 audi s4 (SOLD)
    Veteran Member Three Rings a4kamila6's Avatar
    Sep 30 2015
    Does the new axle you have slip into the spindle and bolt up to the transmission fine? If so, dont worry about the different bolts. Originals are triple square, while aftermarket axles are usually like you said allen head shaped, believe it was a 17mm impact socket i used.
    Oct 06 2013
    Cincinnati ohio
    Bolts are too big larger diameter Yeah I wouldn't. Care bout the different heads
    2004 audi s4 (SOLD)
    Veteran Member Four Rings nynoah's Avatar
    Jan 16 2006
    01.5 A4 avant Past cars: 95 S6, 85 Golf II VR6, 2 sciroccos, 92 Corrado VR6, 86 Euro BMW 535 Alpina
    LA CA
    I would just take your old axle to a shop and have it rebuilt. When I worked at a shop we did that for all audis. It was just impossible to order the right one so we just had them rebuilt instead.
    2001.5 black on black avant 5spd, EFR 6758, Pag Parts band manifold, Vibrant GESI High flow CAT, 2.0L 06A, IE intake manifold, built AEB head, 1000cc Boosted Euro Tune, bosch 044, Ringer Racing stage 3 hybrid Organic/Cerametalic 240mm clutch, S4 interior upgrade, full S4 brakes front and rear with lines, 17in OZ Racing Ultraleggera, 034 HD suspension arms, Stern soft mounts, mirimoto bixenon etc. http://www.audizine.com/forum/showth...s-Build-thread
    Mar 27 2015
    C6 Avant & B5 A4
    Boston
    https://www.ecstuning.com/Audi-B5_A4..._Front/Manual/
    Or you can take to the dealership for a remanufactured one and they give you credit for the core
    Oct 06 2013
    Cincinnati ohio
    Too much hassle imo to get it rebuilt just want to order one. That link ^ does nothing for me bro thanks though.
    2004 audi s4 (SOLD)
    Oct 10 2013
    98 Civic CX Hatch, 2012 CBR250R
    State College PA
    I went to my local auto parts store and picked one up. Has a lifetime warrenty and was like 90$ I think.
    Sep 30 2015
    I got two new axles for my b5 from auto parts warehouse online. Paid around 165 with shipping for two A1 Cardone front axles, new, not rebuilt, with lifetime warranty. Sure, it isnt a original axle, but can you beat the price and warranty? I live in NYC, the roads are horrible here. Anything you install, oem or aftermarket, it will feel the wrath of the potholes anyway.
    Sep 30 2015
    Got the email from them, looks like everything 20 percent off and free shipping. Maybe good time to consider their parts.
    Senior Member Two Rings MrSnickelsnizer's Avatar
    Dec 03 2012
    michigan
    Alright. Here is what you need to do. Figure out if the inner cv joint is 100mm or 108mm. I believe those are the two sizes. The larger one is for front wheel drive cars. The smaller is for quattro. The front wheel drive axles use larger diameter bolts. The quattro uses smaller. Measure then order. Remeber 1" is roughly 25mm. Done.
    1998 Audi A4 1.8t Quattro
    Oct 06 2013
    Cincinnati ohio
    Quote Originally Posted by MrSnickelsnizer View Post
    Boom! Just ordered the correct one thanks guys!
    2004 audi s4 (SOLD)
    Mar 27 2015
    C6 Avant & B5 A4
    Boston
    Quote Originally Posted by Sickws6 View Post
    The axle you are looking for costs $75 in that link. Not sure how it does nothing for you
