Results 1 to 6 of 6
    Veteran Member Four Rings LakeTahoeQuattr's Avatar
    Jan 04 2013
    '07 JHM S6, '21 TTRS, '06 CTT, '20 Supra GR
    Zephyr Cove NV
    Help me pick out the right rotors - much debate on the 18z retrofit rotors...
    So i am going to pull the trigger on the BBK retrofit for my ar. After much reading, the 18z caliper is for a "350mm" however many people say that we must run a 345mm rotor to make the pads fit better or something to that extent. I also read that people are using a 18z with a 345mm and 17z pads. People say that there is less overhand or something to that extent. Anyone heard of this?
    So i was looking at getting the ml55 amg 345 mm rotors until I learned that the vanes are not directional from side to side! They made each rotor the same so one gets efficient cooling and the other one gets no cooling! What the heck is going on here? Why would Mb design their rotors his way?
    Does anyone know of a a manufacturer of the ml55 rotors with right and left vane cooling?
    It seems that the only choice is a two piece girodisc or JHM to get the correct vane orientation...
    21 TTRS - track whip 1
    20 Supra GR - track whip 2
    06 Cayenne TT
    07 S6 Thread
    SOLD 14 JHM Q7
    SOLD 04 D3L
    SOLD 02 ar Thread
    Oct 21 2005
    y
    Iirc DBA is the only cast directional rotor that works correctly for both sides. After that its the $$$ floating rotors
    17z pads because it overhangs on the inside.
    These are 17z ebc yellow pads on 345mm rotors. There's still a bit of overhang with them, 18z pads would be a lot more.
    Veteran Member Three Rings gmdiluca's Avatar
    Mar 29 2013
    Ontario, Canada
    I think stop tech makes a directional vane rotor for the ML55. Not 100% sure though
    Jan 04 2013
    Zephyr Cove NV
    Quote Originally Posted by ricekikr View Post
    So then the ONLY benefit of the 18z vs 17z on a single piece rotor is rotor size. 330 vs 345.
    I could not find the ML 55 rotor made by DBA in their catalog.
    I thought Ricam tried the stop tech and they were single direction...
    06 Cayenne TT
    07 S6 Thread
    SOLD 14 JHM Q7
    SOLD 04 D3L
    SOLD 02 ar Thread
    Oct 21 2005
    y
    *** confirm this is the correct one first. Just did a quick google search ***
    http://www.lpiracing.com/DBA4552XS-D...078p159166.htm
    Another benefit is better piston diamters suited for the b5 master cylinder. And imho looks better. 17z, to me, looks quite odd (huge caliper makes rotors look tiny)
    The only negative is maybe rim size. The 18z fits under 17inch rs4 rep barrels but hit the spokes, i imagine the 17z will hit the spokes as well. Same thick calipers.
    But since 18z can be found for the same price, sometimes less, than 17z its almost a no brainer unless you prefer smaller wheels.
    Dec 10 2011
    991 C2S, Stage 3 S4, E46 M3
    CLT | MKE
    Quote Originally Posted by LakeTahoeQuattr View Post
    Audi does the same thing on the R8. Same rotor used on both sides. Most OEMs do it this way, and aftermarkets follow suit since that's "OE-spec". Same thing on most AMGs and many other high end cars. They don't seem to have any problems with brake cooling.
    You won't have any issues with the ML55, but by all means go two piece if you don't mind spending the money.
    -Hayden
    B9 Q5 | Brilliant Black
    E46 M3 Cab | Steel Grey
