Results 1 to 23 of 23
    Veteran Member Four Rings CJ_'s Avatar
    Oct 27 2014
    Flag/Phx, AZ
    Dual in -> Single out FMIC
    I was cruising through some build threads last night and found this pretty interesting. I was curious if anyone ever saw logs or data from this setup? Or if anyones done something similar?
    He's running a dual 2.5" inlet to single 3" outlet with a BOV and MAF between the intercooler and throttle body on k24s.
    Im interested because the core looks shorter and could fit in the whole opening of the bumper
    CX makes a similar core: http://www.cxracing.com/mm5/merchant...gory_Code=INCO
    All pics came from the following thread:
    http://www.audizine.com/forum/showth...-Top-End/page5
    He even made a video about the install
    2001.5 Silver S4 Avant - 6spd swap + BW K04s (Current)
    2001.5 Santorin S4 Sedan - SRM k24 build (Totaled)
    IG: CJ_s4
    Aug 06 2008
    Canadia
    There used to be a kit on eBay for the dual in single out intercooler, I found a few threads on it and apparently it's not that bad of a kit.
    the B5 S4 is like the mafia... there is only one way out!
    Veteran Member Four Rings Austonwerner4's Avatar
    Feb 01 2011
    00 S4 & 04 A8L
    MKE
    That's not a CX IC
    It's a treadstone.
    That is Meows car which he no longer has.
    Single Turbo on it's Way
    PM me for 17z and 18z Caliper Needs
    Oct 27 2014
    Flag/Phx, AZ
    Ah, I see, They have comparable size, The CX is 24x7x3.5 where the treadstone is 25x6x3.5 giving the CX a greater overall volume, which I know isn't everything.
    I know he no longer has the car, just wondering if anyone ever saw logs like he said he was going to post.
    IG: CJ_s4
    May 18 2007
    01 Laser Red 6MT, 13 Touareg TDI
    Baytown, TX
    http://www.treadstoneperformance.com...cooler++1000HP
    they sell everything cheaper one ebay with free shipping for whatever reason. fits behind bumper just fine. flow is good. best to run meth with it.
    http://www.ebay.com/itm/Treadstone-F...1VhIhZ&vxp=mtr
    Veteran Member Three Rings killerkali's Avatar
    Jan 01 2011
    Nor cal
    treadstone is good shit
    May 18 2007
    Baytown, TX
    And I have one of these units that I can let got of for a decent deal if anyone is interested, but the little inlet and oulet pipes are cut off.
    Oct 27 2014
    Flag/Phx, AZ
    Would this setup be better to run with meth? since you would only have one nozzle to worry about?
    IG: CJ_s4
    Veteran Member Four Rings Meow's Avatar
    Mar 08 2012
    MI
    This is my car, the core is NOT an ebay core, it is a legit core from Treadstone. All the piping was cut and fitted and welded by hand, the brackets are diy and not the best in the world but they work.
    Here is the build thread - http://www.audizine.com/forum/showth...nd-and-Top-End
    I sold the car and moved on, it was a fun build but I realized it would never be what I really wanted.
    RIP Daz, you will be missed.
    Mar 08 2012
    MI
    Snowtrooper (jared) also has this same core on his single turbo with a single in, single out end tank design. It flows really well. The cx racing intercooler is junk, it doesn't have the proper fin design to even compare to a good quality treadstone core.
    May 18 2007
    Baytown, TX
    i am running the same core on both of my single turbo cars now, but with single in and single out end tanks. I think its the TRV 25 that I have. good for me so far.
    Oct 27 2014
    Flag/Phx, AZ
    Sorry, didn't mean to turn this into a X vs Y intercooler debate. Just wanted more info on the setup was all.
    Meow, did you ever get any logs from the setup?
    Are there benefits/downfalls of running the maf and bov on that side of the turbos?
    IG: CJ_s4
    May 16 2008
    WA
    Quote Originally Posted by CJ_ View Post
    the BOV should always be on that side of the turbo....
    May 16 2008
    WA
    Quote Originally Posted by Meow View Post
    A dude magnet?
    Mar 08 2012
    MI
    I have logs, on my old laptop somewhere. I'll have to dig them up.
    The maf in blow through can be a bit challenging to tune. Its not something most tuners would enjoy working with so be sure to ask your tuner what they are willing to do.
    The bov should always be after the turbo though... lol. It can be before or after the intercooler, but if you do it before you will need two of them.
    Oct 27 2014
    Flag/Phx, AZ
    Yeah sorry, I meant intercooler lol.
    Where were you injecting the methanol at?
    IG: CJ_s4
    Mar 08 2012
    MI
    I never ran meth with that setup.
    Oct 27 2014
    Flag/Phx, AZ
    Just drew up a model for this intercooler setup using Bobkat's template.
    Was curious if this looks right or if anyone has any suggestions? Would it need check valves anywhere?
    Basically this would be deleting the n80 and n249 and routing the BOV directly to the top of the IM along with the other obvious changes.
    IG: CJ_s4
    May 18 2007
    Baytown, TX
    Don't forget the MAP sensor
    Oct 27 2014
    Flag/Phx, AZ
    Do you still need to run a MAP with an hpx MAF? Would it go between the MAF and IM then?
    IG: CJ_s4
    Senior Member Two Rings Quattro_The_Dog's Avatar
    Mar 03 2014
    sports gear
    The Woods, CA & WA
    The bov or bpv should always be to the turbo side of the intercooler, you only need one. The most efficient place for evacuating pressure from and towards the turbo and not flowing needless air through the IC core.
    Stage 3+ S4 28 PSI daily driven
    Veteran Member Four Rings phila_dot's Avatar
    May 26 2010
    2001 S4, 2019 Q5
    Philadelphia
    I wouldn't recommend anything about that setup.
    If you insist on it, then you will need to move the BOV as far away from the MAF as possible. It's also recommended to have a distance 3 times the diameter of straight and even pipe pre-MAF and that it be placed at least 10 inches before the throttle body.
    I hope you aren't looking to run high boost pressure either because MAF readings can become erratic under high pressure.
    The HPX MAF isn't magic and all of this still applies.
    And yes, you will still need a MAP sensor in the stock location.
    I suggest you talk seriously with your tuner before you invest in this design.
    WTB (1) OEM A8 Flat Five 18x8.5 et45
    WTB Black 6spd Shift Surround
    Mar 08 2012
    MI
    Quote Originally Posted by phila_dot View Post
    Pretty sure the new owner is looking into having you tune it... lol.
