Page 1 of 10 123 ... LastLast
Results 1 to 40 of 386
    Veteran Member Three Rings gmdiluca's Avatar
    Mar 29 2013
    Ontario, Canada
    gmdiluca's Silver Stage 3 Build
    Hey guys! Little background; So I've owned my S4 since March 2013. I've always dreamt of owning a B5 S4, why I have no idea. But anyways went on the hunt as soon as I needed a new car. Spent over a year looking for the perfect one. Finally found a very clean and stock S4 6spd with only 84 000 kms, score! Only downfall was its silver... But I learnt to love it haha.
    Car has been stage 2 shortly after I purchased it and over the last year I've been accumulating stage 3 parts.
    This will be a stock bottom end build on pump 94 FYI.
    Currently on the car:
    -APR tune
    -Stern mounts all around
    -KW V1s
    -SRM SMICs
    -SSAC Turbo back exhaust
    -034 RSB
    -18Z BBK
    Parts ready to install:
    -SRM RS6 K24 Turbos if I can't get a handle on OEM RS6
    -SRM inlets
    -630cc injectors
    -85mm hitachi MAF
    -Walbro 450 fuel pump
    -710N DVs
    -Silicone Lobster claws
    -3bar Map
    -AMD stage 3+ clutch
    -TTV flywheel
    -ARD bipipes
    -SSAC full 3" DPs
    -Zeitronix ZT-2
    -Notorious VR tune (Sascha)
    Other $$ suckers:
    -Oil cooler
    -new VCG and seals
    -300mm rear bbk
    -Aux water pump delete
    Contemplating:
    -Meth
    -JHM trio
    I'll be doing most of the work myself, should be starting mid March depending on weather up here. Wish me luck!
    Here's a few photos to spark interest.
    Veteran Member Four Rings jaychen's Avatar
    Feb 19 2011
    Earth
    Looks like a very clean base.
    Nov 16 2014
    ovid ny
    Very nice car. Good luck with your build. And go meth. Its good all the way around.
    Dec 10 2013
    Borden, Ontario, Canada
    Bout time you made a thread
    Everything graciously mispelled by Android
    IG: 24_et
    Sold:
    2010 Deep Sea Blue S4 6-spd
    RIP:
    Veteran Member Four Rings CJ_'s Avatar
    Oct 27 2014
    Flag/Phx, AZ
    Nice, almost my exact build! Since you're going to have the motor and tranny out, I would 100% recommend the JHM trio kit. Super easy to install with everything out and the parts are 100x more solid than the stock parts
    2001.5 Silver S4 Avant - 6spd swap + BW K04s (Current)
    2001.5 Santorin S4 Sedan - SRM k24 build (Totaled)
    IG: CJ_s4
    Mar 29 2013
    Ontario, Canada
    Thanks guys
    Veteran Member Three Rings cinimod25461's Avatar
    Dec 04 2013
    CA
    Sweet, looks like our builds will be nearly identical lol! I will definitely be following your progress. If you haven't sold the K24's yet, I would recommend keeping them. You won't be disappointed.
    Veteran Member Three Rings Corradovolksb's Avatar
    Aug 29 2013
    2018 VW Atlas
    Phoenix AZ
    Are you planning on installing rods I didn't see them on the list. K24s will bend your rods at high boost even on 91. Car looks great
    Mar 29 2013
    Ontario, Canada
    Quote Originally Posted by cinimod25461 View Post
    Haha I told you it was the same. Ya I mean I still can't really decide on these or a smaller frame turbo. They are still up for sale, I have a couple weeks to decide.
    Mar 29 2013
    Ontario, Canada
    Quote Originally Posted by Corradovolksb View Post
    No, stock rods. With a competent tune it is no issue
    Active Member Four Rings aysix's Avatar
    Feb 06 2012
    Lake Lanier, GA
    not in a million years
    Veteran Member Four Rings mikeb17's Avatar
    Oct 27 2012
    Lamborfeetes
    Washington
    Torque on set bends rods. A good tuner can work around that. You ideally would need e85 with the k24s to bend a rod.
    Mar 07 2013
    2015 Mercedes GLK350
    Rancho Cucamonga, CA
    Quote Originally Posted by gmdiluca View Post
    -APR tune
    -KW V1s
    -SRM SMICs
    -034 RSB
    -18Z BBK
    -SRM RS6 K24 Turbos? Pending review
    -SRM inlets
    -630cc injectors
    -85mm hitachi MAF
    -710N DVs
    -3bar Map
    -TTV flywheel
    -ARD bipipes
    -SSAC full 3" DPs
    Other $$ suckers:
    -Oil cooler
    -new VCG and seals
    -300mm rear bbk
    Contemplating:
    -Meth
    -JHM trio
    very nice ride man, jhm shifter upgrades should be a must, I did that immediately after purchasing my b5, went on to purchase every other shifter upgrade they make for our cars too, worth the money. cheers to the build
    2008 Ibis RS4....GETing tuned
    Mar 29 2013
    Ontario, Canada
    Looking into a Zeitronix ZT-2. Does anyone know if the 3ft O2 sensor wiring is long enough for our cars? or do we need 8ft?
    Veteran Member Three Rings hotshot32890's Avatar
    Dec 05 2009
    2008 VW Passat. 2000 Audi S4
    Boston, MA
    Wow almost an identical build thread to my silvaro sedan. Why Notorious VR Tune? I used zetrionix zt3
    Current:
    IN THE MARKET
    Previous:
    F21 Brilliant black b5s4
    SRM K24 silver b5s4
    Black B5S4: Eurojet Grenade DVs, AWE Twin1
    Eclipse GSX: 16G turbo
    Mar 29 2013
    Ontario, Canada
    Apparently the ZT3 doesn't log RPM... Which is necessary though.
    Chose Sascha because he is really knowledgable about our cars. He's tuned some really quick cars around these parts. He's also local so no remote tuning which is a huge plus.
    Active Member Two Rings B5Mark's Avatar
    Jan 15 2016
    Colorado
    Very clean car! I would much rather silver over my black s4!
    00 Audi S4 / Stage 1
    Check out this sick B5S4 Fanpage http://www.instagram.com/b5s4
    Mar 29 2013
    Ontario, Canada
    Fuel pump arrived today!
    Mar 29 2013
    Ontario, Canada
    Made some progress tonight now that the weather is warm (10c lol). I spent a lot of time reorganizing the garage and setting up my workstation but eventually began to dig in. Removed the rad support and diassabled a lot of components In the engine bay. Here is how it sits and also a few snapshots of the new hardware :)
    Aug 24 2014
    Newport Beach, CA
    Looking great! Made some progress on it, what lines are you using for the wastegate/turbo (coolant & oil)?
    2024 M3 Comp xDrive
    Mar 29 2013
    Ontario, Canada
    Quote Originally Posted by christianb5s4 View Post
    Was planning on reusing the OEM lines if they look good.
    Aug 24 2014
    Newport Beach, CA
    That's my plan as well, although I think the rubber sections of the wastegate lines will need to be replaced. Just curious which route you're taking.
    2024 M3 Comp xDrive
    Veteran Member Four Rings ianwpb's Avatar
    Dec 11 2010
    16 S3, 16 Q5 3.0t
    West Palm/ South Florida
    Make sure you clamp the inlets to the turbos.
    '16 Q5 3.0t S-line Daytona Grey Pearl, Black Optics, APR stage 1, Magnaflow exhaust (Looking for stock exhaust)
    '16 S3 Misano Red Pearl, Black Optics
    Gone -
    '13 Q5 2.0T Premium Plus
    '13 BMW 135Is 6MT Coupe - #387/586
    '01 S4 6MT - SRM K24's, Stock Block, E85 448/392 Mustang Dyno
    '12 A3 TDI Premium Plus
    '10 A3 Premium
    '99 A4 2.8 5MT
    Mar 29 2013
    Ontario, Canada
    Quote Originally Posted by ianwpb View Post
    Will do!
    What is everyone doing with the brake booster line that goes to the accordion hose? Do I cut a hole in my silicone hose?
    Senior Member Three Rings kdf8454's Avatar
    Apr 21 2014
    Akron OH
    you take it out and cap it. Or you take the check valve out of the accordian, put it into the gromet on the firewall, and run hose to the intake mani
    01.5 Stage 3 Seafoam S4
    @fizznizzy
    Mar 29 2013
    Ontario, Canada
    Quote Originally Posted by kdf8454 View Post
    Ok cool thanks. Where on the intake manifold would it connect? Have a picture for example?
    Apr 21 2014
    Akron OH
    Back side of the manifold. If you follow the line that goes to the accordian currently or the brake booster line, they T-together at a jet valve and clip on to a bung on the intake manifold.
    @fizznizzy
    Dec 11 2010
    16 S3, 16 Q5 3.0t
    Hey, sorry I haven't gotten back to you about the Fuel pump wiring.. I'll try to take some pictures tomorrow.
    Gone -
    '10 A3 Premium
    '99 A4 2.8 5MT
    Mar 29 2013
    Ontario, Canada
    No worries, just ordered the harness, if you can just send me some info like where you connected each part of the harness that would be great. Pictures would be a bonus haha. Thanks!
    Mar 29 2013
    Ontario, Canada
    Stripped more of the engine, only a few things left to disconnect but I'm taking my time because I can't get a cherry picker until next weekend.
    **Questions though, is it possible to disconnect the electrical wiring that runs along the passenger side firewall and support arm without cutting any of the ties downs? I'd like to put everything back the way it is.
    Some more pictures
    Jul 07 2015
    depends on how careful you are :) i was able to get a small pick into most of the zipties and cable anchors and release them without snapping then off. Some take a little finagling, but its possible.
    Mar 29 2013
    Ontario, Canada
    Does anyone know the Torque specs for the TTV Steel billet flywheel? Ive found the torque on the factory dual mass is 60nm +180 turn but not sure if the aftermarket flywheel would be different.
    Dec 04 2013
    CA
    60nm + 180 is correct.
    Mar 29 2013
    Ontario, Canada
    anyone have tips to getting the driveshaft disconnected? Engine is ready to come out but the DS just doesn't want to seperate from the center diff.
    Aug 29 2013
    2018 VW Atlas
    Phoenix AZ
    A few light taps with a hammer in different spots around the cv joint will do the trick.
    Dec 11 2010
    16 S3, 16 Q5 3.0t
    I don't recall having an issue with the driveshaft separating... But I'd imagine once it's unbolted you could just try pulling at the engine & trans assembly out and it'll probably break loose relatively easily. Or just hit it with a big rubber mallet.
    Gone -
    '10 A3 Premium
    '99 A4 2.8 5MT
    Dec 04 2013
    CA
    I had that happen when I was removing one of the axles. It didn't want to separate from the transmission. Hitting it with a mallet and a lot of wiggling got it to finally come apart.
    Mar 29 2013
    Ontario, Canada
    Update, motor is out. Unfortunately it got cold up here this week so I'm going to have to wait before I start cleaning everything. But I'll start taking off all the old hardware.
    Anyone know the best way to clean out the spider hose? Water, compressed air? It's full of oil and grime.
    Veteran Member Three Rings nkbks4's Avatar
    Mar 26 2009
    Silver stg 1 avant, Black 01' STG 3, wife - Honda Pilot
    Naples, FL.
    If u wire it in, it does log rpm...
    Stg 3 black sedan 395whp/402wtq (sold and will be missed)
    Silver stg 1 avant cleaner upper
    Mar 29 2013
    Ontario, Canada
    Quote Originally Posted by nkbks4 View Post
    Well I ended up buying a ZT-2 anyways lol
