Results 1 to 20 of 20
    Established Member Two Rings rspengle's Avatar
    Oct 26 2009
    Rivian R1S, Shelby GT350
    Elmhurst, IL
    Tires have a slit 90 miles after purchase (used)
    So I drove the RS7 for the third time ever tonight. Just passed 90 miles and while out for a drive tonight the tire indicator came on. I made it home, luckily I was close, and did an inspection. Turns out there is a small slit on the inside tread of the rear driver side. Can hear the air leaking out especially when I put my finger over it. Obviously this is a wear issue even though I just purchased the car last week but what are your thoughts on bringing this to the dealers attention? I hit absolutely nothing, was actually on a very smooth surface when it happened. In all my years of driving I've never had a slit happen like where there is not a screw or nail inside of it. I know these tires are like hockey pucks at 40° but still I was not even driving aggressive whatsoever.
    Any thoughts on if this is patchable? Looks a little too close to the sidewall…
    24’ RS 6 Performance - 24’ Rivian R1S - 20’ GT350
    Gone:
    24’ BMW M3 CS
    21’ Tesla MS Plaid - 19’ Tesla MS Performance
    19’ S5 - 14’ RS 7 - Unitronic 1+
    11’ S4 - APR RSC, Apr Stage 2+ with Pulley, Awe s-flo
    03’ RS 6 - AWE Stage 1+
    08’ S5 - AWE Tuning Exhaust, 6-speed
    01’ B5 S4 - Stage III AWE K04's w/ fueling, 6-speed
    04’ B6 S4 6-speed
    Veteran Member Three Rings jrsAudiA6's Avatar
    Oct 11 2011
    2018 A5 SB
    Riverside, California
    Road can be smooth as silk and you can still run over something that will puncture your tire and you may not know it until the pressure drops. Have had this happen a couple times. As far as repairing it I would check with a reputable tire place, such America's Tire co, they should be able to determine if it is safely repairable.
    2018 A5 SB Matador Red Premium Plus
    2012 A6 Garnet Red, Prestige Pkg, Innovation Pkg, B&O, 20" Sport Pkg, H&R RSS + Coilover, Alcon Mono6/380mm front brakes, S6 rear rotors(356x22mm)/caliper carriers.
    034 DL fr suspension arms, 034 Track DL engine mounts, Eurocode Front and Rear sway bars & Alu Kreuz front brace, 034 ECU/TCU tune, DP PR 3.11, JHM Hx
    CTX 50% Tint F. S. Windows, CTX 30% Tint R. & R. S. Windows, 3M Pro PPF, hood, L & R fenders, AWE Exhaust w/o down pipes
    Dec 10 2011
    991 C2S, Stage 3 S4, E46 M3
    CLT | MKE
    You could have easily punctured it without knowing it- I don't think it's fair to blame the dealer.
    -Hayden
    B9 Q5 | Brilliant Black
    E46 M3 Cab | Steel Grey
    Mar 02 2009
    State of Confusion
    Most tire shops where I live won't repair in the first tread block. You probably can find a shop that will be willing to do so though...
    Oct 26 2009
    Elmhurst, IL
    Yea I understand not blaming the dealer. Really just hoping its repairable. The treads are only about 65% anyways. Have a tire gauge at work to see what's remaining tomorrow. What is the standard "it's awd so all tires need to be replaced" tread threshold?
    Gone:
    24’ BMW M3 CS
    04’ B6 S4 6-speed
    Established Member Two Rings ekpyr's Avatar
    Jul 16 2007
    Long Beach, CA
    It's against DOT rules to repair outside the outermost ring. That's considered sidewall.
    Veteran Member Four Rings B-Time's Avatar
    May 03 2009
    East
    Shaving down a new tire is an option.
    If you're tire wasn't leaking before and it's leaking now, you ran something over.
    The repairable area is 1/2" in from the inner belt edge.
    Take it to America's Tire and have a professional inspect it. They will repair for free. Just return the favor and send some business their way.
    Good luck.
    2016 Sepang Blue S7
    2015 Q5 TDI
    2012 Ibis White S5 (SOLD)
    2016 S7 Sepang Blue HRE S101 21 x 10.5 275/30R21 Pirelli PZero. (EUROCODE) APR ECU/TCU Stage 1 VCDS Lowering . Exhaust by MAGNAFLOW
    2015 Q5 TDI Lava Gray The wife's
    2012 S5 6MT Ibis White SOLD
    Air-pressure/Load index table
    Veteran Member Four Rings VeryBadman's Avatar
    Jun 24 2012
    2017 BMW X1
    Bay Area CA
    Quote Originally Posted by Tireguy View Post
    Good luck.
    2016 Sepang Blue S7
    2015 Q5 TDI
    +1 They just repaired mine 2 weeks ago and I got puncture at almost the same location so yours is fixable.
    2020 ///M340i xDrive Mineral White Fully Loaded, IND Front Reflectors Delete Kit
    Remaining Parts: Neuspeed RSe102 19x9 et45 in Texas Grey
    Other: 2017 BMW X1
    Throwbacks: 2018 Audi TTRS, 2014 Audi RS7, 2013 Audi S6, 2011 Audi S4, 2008 Audi A4
    Veteran Member Four Rings madyspop's Avatar
    Nov 19 2005
    07 S8, 07 V10 Treg, 11 Stasis S4, 13 S6
    Central IL
    Definitely repairable...
    13 S6 Glacier Stage 3 llllllll APR DP's l Akrapovic l EC sways, endlinks and Alu Kruez l 034 mounts l Garrett GTX2873 turbos l Custom ECU/TCU tune l 3m tint l CETE Bluetooth Lowering Module l Escort 9500ci built in radar/laser diffuser l AWE Gen 2 intake l Xpel l P3 Gauge l RS 6 Grill l E-codes l APR HE l Carbon Designs valance & mirror caps l Dynamic tails l facelift rear bumper l 20" BBS CX-R on Blizzaks l 20" HRE P101 on Mich PSS l 034 density mounts
    Veteran Member Four Rings kiku's Avatar
    Jul 11 2013
    2001 Audi S4
    Pittsburgh, PA
    Plug it and forget it.
    2008 997.1 GT3
    2015 Allroad
    2014 Ram 3500 Dually (the double wide)
    2014 Phantom Black RS7 w/ APR Stage 1 Tune (sold - farewall fast rs)
    2001 B5 S4 (the track slut)
    2013 Q7 S-Line (sold)
    Jun 30 2012
    16 Lava Orange GT3 RS, 18 Nardo Grey RS3, 17 Panda Macan GTS, 91 C2 964, 16 F150 Lariat, 63 Impala
    Woodstock GA
    Does plugging have any negative effect on the speed rating?
    I go pretty fast-->>> and just noticed something about the size of a pin (very small) stuck in the outer tread of the tire. Doesn't seem to be losing any pressure, but I'm not eager to pull it out either. It's already bent sideways and flat now.
    Veteran Member Four Rings gk1's Avatar
    Aug 06 2014
    NJ->CO
    Quote Originally Posted by tonymission View Post
    http://www.tirerack.com/tires/tirete....jsp?techid=77
    2023 e-tron GT Daytona Gray
    Perf, Leather, Exec
    2015 S6 Quartz Gray
    2014 SQ5 Glacier White
    2012 S4 S-Tronic Monsoon, Stage II [email protected] 4275lbs
    2008 A6 3.2Q S-Line Daytona
    2007 A4 2.0T S-Line Ice Silver
    2001 S4 Nogaro Blue, Stage I [email protected] 3944lbs
    Veteran Member Three Rings BlueSVT's Avatar
    Oct 06 2013
    I had mine patched also, similar location... America's Tire did it without question.
    Arguing with an engineer is a lot like wrestling with a pig... After a couple hours you realize the pig likes it.
    Veteran Member Four Rings HyperM3's Avatar
    Mar 20 2004
    Lawrenceville, NJ
    I patch all my tires myself(and friends and family). On my previous S6 I had put on brand new Pilot AS/3 and within a week I got a nail in the corner of the tread. I know its a no-no but I patched it anyway. Lasted me with no issues till the tires were done at 20k miles. I wouldnt hesitate to trust a patch where your hole in the tread is.
    21 S5 Coupe - RacingLine strut brace/034RearSwayBar/CTSTransMount/034 tune/VPS Res Delete/CTSIntake
    10 S4 (gone),13 S6 (gone),14 S6 (gone),14 S6 (gone),16 S6 (gone),17 A4 (gone),19 S4 (gone)
    20 BMW R1250RS
    ACNA Lifetime Member - 26690
    Respond to a post with an answer, they will keep asking questions. Teach them how to RTFM, they will learn to help others.
    Oct 26 2009
    Elmhurst, IL
    Thanks for the opinions guys. I took the wheel off this AM and brought it to a trusted tire shop near me in Chicago and was told they would not touch it, need to replace all 4... Of course they want the business. I then went to my local gas station/tire repair Militos Mobil and they put a plug in it no problem. Unfortunately they do not do internal patches so its just a poke and plug. Seems that it is on ground contact area so I think ill give it a try for a few weeks. I have a major road trip late summer so il likely replace all 4 before then anyways.
    After researching on the forums and Tirerack, I may give these tires a try. Seem to have pretty good reviews
    Hankook
    Ventus V12 EVO2
    Gone:
    24’ BMW M3 CS
    04’ B6 S4 6-speed
    Mar 29 2014
    Hampshire, UK
    Hope you don't mind me jumping in with a question....
    Why do you guys (USA) talk about "shaving tires" if you have to replace a single tire?
    In my 35 years of driving (UK) I have never, ever shaved a tire, been told to shave a tire, or been recommended by any tire fitter to shave a tire.
    Is this something your tire dealers invented?
    Cheers
    2016 S7 Sepang Blue ///Matrix//Bose//Self Park//Lane Assist//ACC//F&R parking cams//Blackvue DR750//Phone Box//Sunroof//Privacy glass//Carbon mirrors//Neidfaktor Steering wheel//RS Knob//OEM RS Grill//Suntek PPF//De-chromed//Modded Exhaust//Cete ASC v2 installed//APR Stage 3 w/RS7 Turbos and intake pipes + TSU//Eventuri CF intake//Carbon Diffuser
    Gone: 2014 Audi A7Q 3.0 TFSI
    Gone: 2011 Audi A6Q 2.8 TFSI
    This applies to AWD vehicles. AWD requires all tires to match and have no more than 4/32" difference to prevent damage to the transfer case.
    Sent from my SM-G900V using Tapatalk
    Mar 29 2014
    Hampshire, UK
    Thanks for the reply Tireguy.
    I should have added, never, ever, with 12 years of Quattro's......
    And unless your planning to shave your spare tire whenever you use it, I still thinks its unnecessary.
