First off, I am well aware that there is an intercooler thread with a plethora of information on different ICs. I am created this thread SPECIFICALLY for the Treadstone family of intercoolers since there isn’t one dedicated to it.
Secondly, I’d like to thank members here who thought outside the box and became pioneers for their use of the TR series ICs. You guys helped me make a great decision and I can’t be happier.
Product and Impression: After several PMs with different members here, I decided to purchase the TR8 IC. The info I found listed it at about 10L of air; the OEM is 6L. Sorry I don’t have photos, but it’s nearly 2x the size and 3-4x the weight of the OEM unit. Plus, no more plastic end tanks: it’s definitely a quality piece of engineering.
Required components: Your choice of Treadstone IC (I choose the TR8), a pair of 45* 2.5” to 2.25” reducer silicone hoses, pair of 2.5” & 2.25” t-clamps (The 2.25” is optional as I ended up using the stock clamps because they fit better on the stock IC hoses), and a pair of 2.25” connector pipes. You will also need to purchase washers, lock washers, two M8 sized bolts and L-brackets or a sturdy metal strip to secure the IC to the crash bar.
Installation: You will need to remove the bumper, belly pan, disconnect the fog lights and disconnect the garage door remote sensor. The complete install took me about 6 hours to complete. [This comprised of removing the bumper twice. During an initial trial run, I blew off the discharge side of my IC pipe from not clamping it down tight enough.]
***Side note for allroad owners. The allroad’s crashbar is indented/rolled on both sides instead of being completely flush across the entire bar like on the A4. This IS NOT vehicle accident related.***
Connection goes as following: stock hose to 2.25” connection pipe ->2.25”-2.5” reducer hose ->2.5” IC end tanks. Once all the hoses were in place, the entire IC actually rested on the OEM end tank brackets. From there, I bolted a flexible metal bracket from the IC up and over to the front of my crashbar. From there, screw the metal bracket to the crashbar for a secure mounting point. Double check your entire IC install, hoses, clamps, etc, reassemble everything, then go for a trial run.
Passenger's side
Driver's Side
Intercooler Impression: From what I know and read, an IC does not “make” power per say, but actually helps your motor run/burn more efficiently because the air charge is cooler, thus richer in O2. This equates to more power by the motor. On APR’s stage 1-91 octane program, the Treadstone IC definitely does a good job. I FELT more power as the motor pulled very smoothly all the way to redline. The amount of new found power, I cannot determine, but I can tell you, the IC works! Once I put ethanol e85 in, it’s a completely different animal. Prior to the IC upgrade, the AR pulled phenomenal. After the TR8 install…it’s completely intoxicating now. It feels as though the IC helped to further enhance the e85 power.
Final thoughts: My complete out of pocket cost was about $350-$375. Time wise, 6hrs because I had no experience pulling the bumper off and had to figure out how to mount the IC. If I were to repeat, no more than 4hrs max. Was the financial investment worth the cost of admission, without a doubt, YES!!! On pump gas, you CAN tell a difference. On e85 ethanol, BIGGER difference. I HIGHLY recommend this modification.
