Results 1 to 9 of 9
    Veteran Member Four Rings CJ_'s Avatar
    Oct 27 2014
    Flag/Phx, AZ
    Is this an aftermarket short shifter?
    Pulled this out of my car when installing my JHM Trio kit.
    I also pulled those spacers out between the rails of the shifter and the box, which is why I'm guessing its not stock.
    Would I get any benefit by running those spacers with the JHM SS?
    Pics:
    2001.5 Silver S4 Avant - 6spd swap + BW K04s (Current)
    2001.5 Santorin S4 Sedan - SRM k24 build (Totaled)
    IG: CJ_s4
    Veteran Member Three Rings okkim's Avatar
    Dec 07 2004
    Finland
    Yes it is aftermarket. Those spacers are not needed with JHM. I guess that the old shifter is too long, and it would touch the base without the spacers.
    Veteran Member Four Rings zillarob's Avatar
    Nov 16 2010
    2kS4, 84gli, 84caddy dsl
    WetSide, WA
    If the white plastic ball thing is worn the jhm ss would make a difference. Id prob run it if the ball is in good shape.
    If you do run it, I think the foot on the bottom needs to be flipped over. Iirc, it is supposed to kick toward the dside?
    There are only 2 things needed to make an Audi work properly - Duct tape and WD40. If it moves and it shouldn't - Duct tape. If it doesn’t move and it should - WD40.
    Veteran Member Four Rings f4m0u5's Avatar
    Aug 04 2014
    Gloucester MA USA
    Almost positive thats a uuc motorsports short shifter. They come with the spacers.
    Veteran Member Three Rings Heavy Winter's Avatar
    Jan 27 2013
    Boulder, CO
    ^ sure looks like the UUC that I removed from my car which was installed by the PO.
    I was able to sell it pretty quickly via the regional 'zine classifieds. But the ball on mine looked nearly new. I think I got around $60.
    Oct 27 2014
    Flag/Phx, AZ
    The ball is almost non-existent, It felt like I could almost pull the shifter out of the socket, which is why I went with the JHM unit. Was just curious if the spacers would add any extra benefit with the JHM kit (shorter throw, smoother, etc).
    IG: CJ_s4
    Senior Member Two Rings rani_aridi's Avatar
    Nov 12 2013
    B5 S4 '00 BB
    Irvine, CA
    I believe I found the same shifter installed in my car. Ball is also super loose in there. I really want to go JHM
    1998 Tornado red VW GTI VR6 - hit a tree. Broke the tree
    Nov 16 2010
    WetSide, WA
    If you dont want it, Id like to play with it. (I dont think you can get that ball without buying the whole damn shifter)
    Just ordered an el cheapo 3d printer and that might be a fun project.
    Oct 27 2014
    Flag/Phx, AZ
    PMed^^
    Quote Originally Posted by rani_aridi View Post
    Just got the JHM shifter installed today and It already feels like a world of difference, and thats with the tranny out of the car right now
    IG: CJ_s4
