Results 1 to 18 of 18
    Apr 25 2011
    new york
    Popping noise when wheels turned in reverse?
    Hey all,
    Hoping someone here can she some light on whats going on with my car. I recently purchased a 2009 A5 3.2L and when reversing and the wheel is turned it almost feels like the tires are slipping, the car like pops and knocks back (hard to explain will get a video). At first I thought maybe this was the AWD and the low profiles losing grip but on second thought I think it may be something different and was wondering is this is common or if there is an under lying issue anyone may know about. Thanks in advance!
    Mar 09 2011
    Nashville Tn
    Sounds like it's your spring popping from getting bind. It's common and nothing to really worry about mine has done this too several times
    Veteran Member Three Rings jamin_00's Avatar
    Sep 14 2014
    Essex, UK
    Common issue, don't worry :)
    Audi S5 V6T 3.0 - Black Edition - Stage 2 MRC Tuning - 480bhp 580nm
    Apr 25 2011
    new york
    Thank you guys I was getting worried, so you think I should just leave it, no need to replace springs?
    Senior Member Three Rings Ake219's Avatar
    Mar 13 2013
    Fairfax, VA
    Hmm, strange because I have the same issue, but I have air suspension. Lately, when I am leaving parking lots, and I turn a good amount, I feel the outside wheel "skipping" or jolting a few times. Sounds almost like ABS or traction control, like OP stated.
    __________________
    2009 Audi S5 :: QuartzGreyMetallic :: BlackAlcantara
    [4.2 v8 :: quattro :: 6sp :: tech :: navi :: b&o]
    [air lift autopilot v2 :: awe track + nonres dp's :: ecodes :: wheels tbd]
    Established Member Two Rings jpatterson's Avatar
    Mar 16 2009
    Trussville, AL
    It has to do with our cars not using pure Ackerman geometry. Corvettes and Porsches do it too. My Cayman S was worse than my S5. It is not as noticeable in warm temps when tires are more compliant. from Wikipedia ---"Modern cars do not use pure Ackermann steering, partly because it ignores important dynamic and compliant effects, but the principle is sound for low-speed manoeuvres. Some race cars use reverse Ackermann geometry to compensate for the large difference in slip angle between the inner and outer front tyres while cornering at high speed. The use of such geometry helps reduce tyre temperatures during high-speed cornering but compromises performance in low-speed maneuvers."https://en.wikipedia.org/wiki/Ackerm...ering_geometry
    J. Patterson
    Alabama
    2015 S5 Prestige 6 spd manual
    2015 Q7 TDI Premium Plus (with the emissions fix)
    2001 TT 225 Quattro Coupe (some mods and track time :-) )
    2001 TT 225 Quattro Roadster ( pure stock)
    Veteran Member Three Rings TTRStud's Avatar
    Jul 12 2013
    Jacksonville, FL
    It may be totally unrelated, but my car made a pop sound when turning the wheels to full lock and back to center at low speeds, which started after a clutch service was performed on the car by the dealer. After having everything double-checked, it ended up being that the bottom bolt of the passenger side sway bar link had not been tightened to spec. The pop went away immediately and never came back. If you recently had any suspension work performed on the car, make sure all bolts/nuts are checked...also check the bolts on the stabilization crossbar underneath the car.
    '10 Meteor Gray Metallic S5 Prestige Loaded 6MT - AWE Track - PCed OEM Rotors
    Veteran Member Four Rings i1overice's Avatar
    May 09 2013
    Loads of junk.
    Northern Virginia
    I only noticed this after I put on coilovers and if the wheel is almost if not full turned.
    Current - 2017 Honda Civic EX-T
    Sold - 2010 Ibis White S5
    Jul 12 2013
    Jacksonville, FL
    Quote Originally Posted by i1overice View Post
    The popping on coilovers is a given - this is common. On OEM suspension it shouldn't be popping.
    Apr 25 2011
    new york
    Ok so it's warmed up a bit and I'm thinking maybe the car was extra stiff from sitting, the popping/jolting is now almost non existent BUT now when I first pull forward I here a screeching/almost metal metal sound. At first I thought maybe a pebble got stuck because I was driving on gravel but looked and see nothing and it only happens on cold starts. I'm thinking could this be power steering related?
    Jun 16 2010
    └A / California
    When I went to the one of the lowest settings on my H&R coilovers, I experienced a loud pop/bang when turning the wheels at 0MPH to prepare for a sharp or uturn. My friends and mechanic told me this was normal due to the amount of space available in the suspensions. However, I never had this issue with stock. Hope that helps.
    Rest in Peace:
    '10 Audi S5 | Quartz Gray
    Established Member Two Rings djthart's Avatar
    Mar 22 2013
    2014 Audi RS7 Panther Black, 2018 Honda Accord Sportm Black-Sold, 2010 Audi S5 Brilliant Black-Sold,
    Houston
    I had this sound with my S5, the dealer changed my front drivers side control arm, it was bent at the connection, so when you turned the wheel far, it would raise up and the pop back into place. After it was changed it never made that noise again. May not be your issue but it's possible, hope this helps.
    Established Member Two Rings Nilla_wafa's Avatar
    Apr 20 2015
    2003 bmw z4 & 2009 Range Rover sport
    New Jersey, United States
    Not sure if youre referring to the same thing but when I cut the wheel super hard it feels like im going over almost a bunch of small bumps so i went to Audi and they told me it is caused by the quattro system in the cold weather and is nothing to worry about.
    2011 Deep Sea Blue s5
    RS Grille/Tinted/Custom Chrome Audi Rims
    Apr 25 2011
    new york
    Never updated this but it turned out to be my passenger side control arm knocked out of place and rubbing into my sub frame. $3,000 later it's all good...
    Senior Member Two Rings ChaserBBS's Avatar
    Oct 25 2016
    2010 Corvette ZR1
    Rio Rancho
    Quote Originally Posted by anjoid View Post
    you spent 3K?
    2014 A5 Phantom Black
    2014 Ice Silver S5 Black Optics Premium Plus.
    2010 ZR1
    Apr 25 2011
    new york
    Yup I had to replace the subframe which was only available at Audi and was $1200 alone, then replaced both control arms, alignment, and labor. Wasn't very happy about it.
    Jun 09 2017
    West LA
    oh shit. thats crazy. you get into an accident to cause the damage?
    Apr 25 2011
    new york
    Nope, only guess is some potholes
