Results 1 to 18 of 18
    Feb 09 2016
    CA
    Which oil to put in when history is vague 2001 A4 167K
    After buying a 01 A4 1.8T with 167K, I have been reading forums.
    I have no idea what oil is in the car and want to change it. How do I decide if it's synthetic or conventional and/or what should I use?
    It sounds like there have been oil problems with the 1.8T in general
    and that there is a best oil/weight/oil filter to use?
    Veteran Member Four Rings adam044's Avatar
    Oct 31 2014
    2024 Jeep Wrangler Unlimited
    NH
    Change it and run whatever you want... I went from conventional to full synthetic, theres no reason why you can't do that as long as you drain all the oil out. Many people here use Rotella T6, it is about $20-$22/gallon at Walmart.
    Haven't heard about oil problems in 1.8's maybe you are thinking 2.0s?
    2019 Audi RS3 - Black Mythos Metallic
    2014 Audi S4 - 6MT
    2008 Audi A4 S-Line Titanium
    2000 Audi A4
    Veteran Member Three Rings Wrath And Tears's Avatar
    Apr 03 2014
    17 GTI Sport
    I believe our cars spec from VW/Audi is 502.00 so you can look for an oil that meets those qualifications, all will be full synthetic oils (note companies have to pay to get that qualification, and for that reason Rotella T6 which doesn't have that stamp is still a good quality oil that people run.)
    As far as weights go traditional is 5w30 or 5w40. I've run some 0w40 that meets the 502.00 spec. Also oil weight is suggested based on average temperatures on the region you live in. Your owners manual should explain more if you have it.
    2017 MK7 CSGM GTI Sport DSG
    PP (Golf R Brakes, +10HP, VAQ LSD), LP, Kessey
    LW 17" Sparco Assetto Garra's, 034 Res-X resonator Delete
    Veteran Member Four Rings A1 A2 German's Avatar
    Feb 28 2005
    Audi A4 B5, Audi Fox, Audi AMLS TT, GS450, CB175, CL175
    Tempe
    T6
    I went from the cheapest dino to T6, the car loves it, after that it's nit picking.....over welming the T6 gets a broad thumbs up.
    Jan 03 2015
    Vancouver British Columbia
    Lots of people use Rotella T6. Lots of people also eat at McDonald's and are clogging their arteries with fatty cholesterol killing themelves slowly lol. What I'm trying to say is, like your own heart your engine is what keeps your car alive, so why put some cheap crap oil in it that will clog your engine and varnish it over time. Go get yourself some Liqui-Moly 5w40 it's 502.00 spec approved, fully synthetic and I guarantee it won't cause any varnish what so ever. I did a rebuild last year put 35000km on my car over the year and it's still crystal clean inside still. (I'm doing a performance build so I have my engine open again).
    If you don't know the history go get some seafoam and run it through because it Will be full of sludge guaranteed, do a filter/oil change with some Liqui-moly and you will be good to go! Repeat every 4000-5000km even though Audi and the oil mfg say 8000-10000km.
    With oil, the cleaner/newer it is, the better it is. Why risk it?
    Apr 03 2014
    17 GTI Sport
    I usually use Pentosin 5w40, happened to have some Liqui-Molly 5w40 and have that in the engine currently. Last service I used the rotella T6 and interestingly it seemed like I lost less oil over the service interval through my CCT half moon gasket that has been leaking then normal.
    Veteran Member Three Rings Rodgman15's Avatar
    Jan 12 2014
    Fargo, ND
    T6 all day.
    Oct 31 2014
    NH
    Quote Originally Posted by VanCityA4Q View Post
    Troll harder next time.
    2014 Audi S4 - 6MT
    2000 Audi A4
    Veteran Member Four Rings tar's Avatar
    Jul 07 2009
    B8 S4, Orange B5 Avant
    Socal/IE
    Another vote for t6. Also big oem filters, with mocal oil cooler.
    Something about exchange rates and 100$$$ oil change and ecs coolaid
    Veteran Member Four Rings Avant Nate's Avatar
    Dec 23 2009
    2001 Audi Allroad 6MT,1999 Yukon Denali, 1987 4Runner
    Boulder, CO
    The reason people like T6, is because it's high in zddp(I think they lowered the levels). So really good anti-wear properties, not so good for catalytic converters. That's why it's a diesel oil. I could be full of shit though.
    99.5 1.8T QMS: GT2860RS .63 T3, PSI T3 Mani, Turbosmart 38mm EWG, Unitronic 415, Forge 007,Treadstone TR18 FMIC, Walbro e85 450, FSI coil conversion, 3" DIY Magnaflow/Dynomax VT exhaust
    Depo ecodes, DDM slim 6000k, VDO boost gauge, PLX AFR, Greddy profec B EBC,
    H&R sport springs, 034 rear sway, 034 rear diff carrier, A8 fronts,18x8 OZ Superleggera
    Next up E85, efr 7163 or gtx3071r?
    01 allroad 2.7t 6mt, GIAC stage 1
    Veteran Member Three Rings a4kamila6's Avatar
    Sep 30 2015
    I personally use Ravenol 5w-40 in my audis. As long as the oil you use has the proper specs and certifications, go ahead. heard a lot of people use rotella and if its cheaper than german oil, has the proper certifications and works just as well, why not?
    also heard orange dextron coolant works fine in our cars. its way cheaper than g12.
    Sep 30 2015
    http://microsites.audiusa.com/ngw/09..._1997-2010.pdf
    Check it out
    Jan 03 2015
    How is my comment being a troll? Of the 350 plus types of oil in that service bulletin there's lots of diesel oils that meet the Audi/VW spec. But T6 is not one of them. There must be a reason for that, there's tons of oils by Shell on that list, so it's not like they haven't tested it I'm sure. And no offense to anyone on here at all, but I'll take the scientific research of German engineers over a bunch of guys on a forum any day. ;)
    Sep 30 2015
    I posted it for OP and us as well, but good observation. Is it possibe Rotella is a new oil or whatever and thats why it isnt listed? I used mobil 1 10w-30 in the beginning but switched to Ravenol VPD 5w-40 which happens to be a diesel oil, worked fine. Now running Ravenol VPO 5w-40 mid saps. Havent seen a difference between the two. Dont burn any oil either. I try to change the oil every 3000-4500 tops. Depending on when i have time you know.
    Established Member Two Rings czum09's Avatar
    Nov 02 2010
    1999 Audi A4
    Cedar Rapids, Iowa
    I run Liqui-moly 5w40. It's good stuff, very smooth. T6 is solid. Can always run whatever then send it to Blackstone for analysis.
    Senior Member Two Rings nemick's Avatar
    Aug 22 2012
    Indianapolis, IN
    I like Castrol Syntec 5-40
    Neil M.
    2004 allroad 2.7T TIP
    2001 A4 1.8TQ, TIP
    Dec 09 2015
    neither here nor there
    Rp 20-50
    m1 15-50
    t6
    Of course you can spend more and get amsoil, or elf/total oil
    Oct 31 2014
    NH
    You're right.
