Results 1 to 31 of 31
    Feb 02 2016
    Salem, SD
    Cancer? How bad is it?
    so.. my passenger side quarter Is a eye sore to look at.. but that doesn't bother me so much knowing that I can just patch it this summer..
    however when you open up the rear passenger door.. low and behold...
    any chance I would be able to clean weld in a new piece you think?
    Sep 01 2011
    Louisville Kentucky
    That's a lot of rust! ... And I've had cancer (seriously), not something I'd choose to do again.
    Oozed from a pustule of thought somewhere within the recesses of my mind...
    Feb 02 2016
    Salem, SD
    thing that ticks me off the most, this is the ONLY rust on the car, really hope that I can just cut the rear quarter off a scrap car and transplant onto mine, due for new paint anyways..
    I'm just scared to find out just how far that rust penetrated into the car through that hole -_-
    Sep 01 2011
    Louisville Kentucky
    If it's that bad... I'd be skeptical that that is the only rust
    Feb 02 2016
    Salem, SD
    Quote Originally Posted by SynapticA4TQM View Post
    exterior wise that you can notice at least, and the bottom is all coated so I can't tell how bad it really is without tearing everything apart
    Dec 09 2015
    neither here nor there
    Not sure if mercedes
    or
    pulled out of a blazing inferno
    Sep 01 2011
    Louisville Kentucky
    Right... That's why it's referred to as cancer... 9/10 there's a lot more than what can be seen. Not that I'd wish it on anyone... That's just usually how it goes...
    If say for an actually educated guess... Drive up to a body repair shop and ask them for an estimate... Most places will give free estimates... That would at least give you a starting point
    Oct 30 2008
    B5, B7, B8, 8V, 4M
    Big Lake, MN
    That's awful. Check your subframe and rear strut towers. Bet they are worse
    2020 SQ7- Wife's ride
    2000 S4- Working?
    Orange County, CA
    Same... leukemia. A rust car is an easier job.
    B5 Parts For Sale
    Veteran Member Four Rings nynoah's Avatar
    Jan 16 2006
    01.5 A4 avant Past cars: 95 S6, 85 Golf II VR6, 2 sciroccos, 92 Corrado VR6, 86 Euro BMW 535 Alpina
    LA CA
    Look for a new car. That is not repairable
    2001.5 black on black avant 5spd, EFR 6758, Pag Parts band manifold, Vibrant GESI High flow CAT, 2.0L 06A, IE intake manifold, built AEB head, 1000cc Boosted Euro Tune, bosch 044, Ringer Racing stage 3 hybrid Organic/Cerametalic 240mm clutch, S4 interior upgrade, full S4 brakes front and rear with lines, 17in OZ Racing Ultraleggera, 034 HD suspension arms, Stern soft mounts, mirimoto bixenon etc. http://www.audizine.com/forum/showth...s-Build-thread
    Veteran Member Four Rings B-Time's Avatar
    May 03 2009
    East
    Was that quarter previously repaired? I've never seen an Audi that bad.
    Feb 02 2016
    Salem, SD
    Quote Originally Posted by B-Time View Post
    well its a 98, runs amazing, and I originally bought it for $600 all because of a bad fuel pump and the previous owners lack of caring to replace it.
    however along with the low price, came no service records. sooo I honestly have no idea wtf happened with this quarter.. although it looks as if the rusting nearly cuts off where its welded to the rails.
    and IF that is the case, and I can just cut this quarter out and clean up the rails, then I don't see why I wouldn't be able to weld in a new quarter
    Sep 01 2011
    Louisville Kentucky
    See all those contours where the rust is eating away? That's why you can't just weld in replacement metal... Pretty much expect to have to cut out an easy inch outside of what you can see... That would mean that you'll be trying to replace the entire profile of the piece at the bottom. I know some people have crazy fab skills... But to recreate the entire multi bend, curved profile of the door lip, and then around the fender... If you had that kind of skill you wouldn't be asking about whether it's possible.
    Feb 02 2016
    Salem, SD
    anyways, Ill be binging it body shop this Monday to have it checked out.. anyone know where I can get some rs4 quarters? hahaha
    Feb 02 2016
    Salem, SD
    Yeah body work is one area that I don't even trust myself doing, and sorry, when I say "I" mean as in "I will be handing out a lot of $$$ to a professional to do it for me"
    and to be clear, I would be cutting an entire rear quarter from a pullers to have welded in place, not having someone try to fab me a piece of metal with all those contours =p I can only imagine what kind of skill goes into all of that.
    Sep 01 2011
    Louisville Kentucky
    Fair enough... But do yourself a favor... Do some shopping to see what other b5 Audi's may cost so that when the shop gives you their estimate, you'll know how close you might be to an entire replacement car... I don't say this to say that I think it's what you should be doing ... On the flip side... Getting a different car, you could be buying a whole different set of problems...
    Jun 30 2008
    Erie, Pennsylvania
    That car was definitely hit in the corner and that is an aftermarket quarter. Audi's - and especially B5's - as a rule, do not rust like that. They just don't.
    My brother's B5 has that same quarter that is aftermarket and is rusting in the same way (but not nearly as advanced). The other side is OEM and still perfect. The aftermarket metal is not even close to the quality of zee German's galvanized steel. He can tell for certain that the quarter is aftermarket because (A) the contour of the wheel arch is not right, and (B) the inside is not "rolled" like the OEM rear quarters are. The aftermarket quarter has a 90 degree bend that would be all up in the way if he were to go for mad tyte hellalfush fitment back there. Your quarter as pictured looks like it is too far gone to identify either of those things, but the rate of decay compared to the rest of the car easily shows it is not original metal.
    Veteran Member Four Rings crazexr7's Avatar
    Sep 10 2011
    1998.5 A4 2.8 Quattro, 2001 Porsche Carrera 4, 1968 Cougar XR7
    Bristol, CT
    ^This would make sense. Wow is this the worst rust I've seen on a b5 though.
    Veteran Member Four Rings Turbo_B5's Avatar
    Oct 09 2012
    abunch of useless shit
    Notnomde Atrebla Adanac
    Quote Originally Posted by crazexr7 View Post
    Literally the exact thing I was gonna say, but with less profanity. It looks like a mazda 3
    EH F0UR 2001 A4 1.8TqM
    = Parked cause its junk.
    2002 Golf TDI
    = FASTER THEN YOUR B5.
    2018 Suzuki GSX-R750
    2014 Honda Grom
    2013 Golf TDI
    2001 A4 1.8TqM
    1997 A4 1.8TqM SPORT
    @Turbo_B5
    Veteran Member Four Rings A1 A2 German's Avatar
    Feb 28 2005
    Audi A4 B5, Audi Fox, Audi AMLS TT, GS450, CB175, CL175
    Tempe
    Something it up, my vote is panel repair.
    They say the Mazda is one of the worst offenders, the absolute best #1, Audi A4.
    B5's just do not do that.
    Nov 03 2011
    All Over!
    With that level of rot, I'd lose interest in that car. Once the Red Terror gets its teeth into a car that bad, it's pretty hard to break it lose.
    1986 Type 85 Audi 90 quattro
    Nov 03 2014
    BMW i3, Golf 1.4T, TT RS 8S
    Mexico
    Good luck on that serious repair!
    Veteran Member Four Rings Avant Nate's Avatar
    Dec 23 2009
    2001 Audi Allroad 6MT,1999 Yukon Denali, 1987 4Runner
    Boulder, CO
    Or find another $600 Audi with a blown engine.
    99.5 1.8T QMS: GT2860RS .63 T3, PSI T3 Mani, Turbosmart 38mm EWG, Unitronic 415, Forge 007,Treadstone TR18 FMIC, Walbro e85 450, FSI coil conversion, 3" DIY Magnaflow/Dynomax VT exhaust
    Depo ecodes, DDM slim 6000k, VDO boost gauge, PLX AFR, Greddy profec B EBC,
    H&R sport springs, 034 rear sway, 034 rear diff carrier, A8 fronts,18x8 OZ Superleggera
    Next up E85, efr 7163 or gtx3071r?
    01 allroad 2.7t 6mt, GIAC stage 1
    Veteran Member Three Rings SN95Audi87's Avatar
    Apr 26 2010
    96 Mustang GT/2001 Audi 1.8T
    North Jersey
    Part out the car, and look for 01.5+ B5.
    01 1.8T | B6 Sport Wheels | Forge diverter valve | A8/TT Front Brakes/SS lines | 034 HFC & Milltek Resonated CB | APR TIP & Intake |
    Jun 30 2008
    Erie, Pennsylvania
    Why is everybody hot on the 01.5? There are very few differences compared to the earlier 2001's. I have an early 2001 model, and other than the strut brace thing and the red flag on the "T" emblem, I don't think I'm missing anything. I've got ESP, Xenons, and what have you.
    Teach me, guys. Why am I less cool?
    Veteran Member Four Rings tar's Avatar
    Jul 07 2009
    B8 S4, Orange B5 Avant
    Socal/IE
    ^x2, neither of mine has the button both 2001s
    Avant is 03/01 xenons with strut bar red T
    Sedan 02/01 with strut bar not sure if xenons originally
    Also rusted car is dead, put it down
    Sep 01 2011
    Louisville Kentucky
    Apart from simply being the newest b5 you can get, I can't think of any other reason...
    Oct 09 2012
    What this guy said. My 01.0 is base lol. no strutbrace no esp no xenons but I do have the red flag. I did swap in my depo xenon headlights and have plans for Morimoto's so im not really missing out on anyting.
    Good luck on finding a new car OP. Took me almost two years to find my replacement.
    2002 Golf TDI
    2014 Honda Grom
    2013 Golf TDI
    2001 A4 1.8TqM
    @Turbo_B5
    Feb 02 2016
    Salem, SD
    Thanks for the reassurance that this car is officially done with, everyone.
    I think what I'll end up doing is keeping this one just to use as my winter car.. clean off all the rust down to bare metal, and Eastwood the hell out of it.. try to capsulate the damage that's already done =/
    anyways, I'm keeping my eye out for a nice summer car. Minneapolis craigslist has my eye on a few already!
    https://minneapolis.craigslist.org/h...432078378.html
    http://marshall.craigslist.org/cto/5423544545.html
    Jul 07 2009
    Socal/IE
    Quote Originally Posted by B5Aura View Post
    if ur traveling why not get a car from the not salt states? SD isnt that far removed and the time spent traveling will payoff the first time you need to repair a stuck bolt
    Apr 26 2010
    North Jersey
    I have base 01.5 that comes with the red flag. The only reason why I said that it because its the newest B5 you can get before they transition to the B6. I've always been a stickler for last model of any year. Most of the time its more refined since earlier problems been addressed I guess. My car came non-xenon.
    Quote Originally Posted by tar View Post
    I agree.
    Yep, its just newest. Possibly could be less troublesome too.
    Quote Originally Posted by King_ View Post
    I love my morimoto bulbs. I just ordered a new set since they are at the end of their life span from 55w ballasts.
