Results 1 to 17 of 17
    May 07 2015
    Butler, KY
    heater hose quick disconnect issues
    Hello. I'm having major issues trying to remove the quick connect/disconnect fitting on the heater hose on my 1997 A4 2.8L. I have searched forums, googled, ect and found nothing. I pushed down on the metal clip and pulled and nothing. I am apparently doing something wrong because it won't budge a bit. Please someone who has removed these give me some insight on this. The hose is snapped completely off at where the the rubber part starts. Thank you.
    Senior Member Two Rings MarcRogers's Avatar
    Jan 18 2016
    PA
    These things are a bitch. You can pull the clip off. Pull it off and pull that bitch it's hard but it will come off
    Oct 30 2008
    B5, B7, B8, 8V, 4M
    Big Lake, MN
    Yeah, those things get pretty seized on. I second just removing the clip so you do not have to worry about it.
    Best you can do is wiggle and wiggle until it pops loose. If that doesnt work, I would start cutting it with a razor blade.
    2020 SQ7- Wife's ride
    2000 S4- Working?
    May 07 2015
    Butler, KY
    Thanks guys. Would soaking the whole fitting in pb blaster help? Would it soak in or just make it hard to pull it off?
    Oct 30 2008
    B5, B7, B8, 8V, 4M
    Big Lake, MN
    You could try soaking them. Or jam a pick in there and try to loosen the crud.
    2000 S4- Working?
    May 07 2015
    Butler, KY
    I could probably get a small dremle tool down there but I'm afraid on cutting it too deep because I wouldn't be able to see what I was cutting to well. I have the new hose on order but I have no idea about the piece on the engine as to what it looks like or is made of. It seems to feel like metal. Thank you guys for the info. This seems to be something people don't have issues with or just don't post about. I've searched for days and came up with nothing. If I can remember I will take pics and post.
    Veteran Member Four Rings xdewaynex's Avatar
    May 24 2009
    98.5 A4 1.8TQM
    Danville, KY
    Most likely dont post about it. I try to twist the hose end just a bit (not a whole lot of room to twist) just to try and break it free a bit while pull on it. When you go to install the new hose, Id recommend putting some coolant or a little pb blast on both connections to help slide the hose back on. Ive done it without a few times, thinking I had it all the way on, get down the road and the hose had come off.
    1998.5 A4 1.8TQM My Build
    Jun 30 2008
    Erie, Pennsylvania
    These are a bugger. Pull really hard and jiggle it around. It will come off about .5 seconds before you smash your knuckles and/or forearm into the firewall/transmission. I'd recommend gloves. I might suggest some heat, if you can possible get some on the area. I think it helps to have 2 people to tag team it. When one person gets tired/frustrated they can tap out and have the other person give it a go. This leads to some show-boating along with an obligatory discussion afterwards about who "loosened it up" for the other.
    Oct 30 2008
    B5, B7, B8, 8V, 4M
    Big Lake, MN
    These are a bugger. Pull really hard and jiggle it around. It will come off...
    Cleverly edited, this is pretty dirty lol
    2000 S4- Working?
    May 07 2015
    Butler, KY
    Is the piece on engine metal or plastic?
    Jun 30 2008
    Erie, Pennsylvania
    Quote Originally Posted by redline380 View Post
    ROFL. Sometimes I purposely slip in some innuendo. This was not one of those times. Even if it seems like it.
    Tag Team it? What the heck was I thinking there? lol
    Dec 05 2007
    Guess this one doesn't count either, you dirty kids you!
    Veteran Member Four Rings nynoah's Avatar
    Jan 16 2006
    01.5 A4 avant Past cars: 95 S6, 85 Golf II VR6, 2 sciroccos, 92 Corrado VR6, 86 Euro BMW 535 Alpina
    LA CA
    I tapped mine off using a punch and a rubber mallet. Don't hit hard. Take your time and work all around the circumference as much as you can to prevent it cracking.
    2001.5 black on black avant 5spd, EFR 6758, Pag Parts band manifold, Vibrant GESI High flow CAT, 2.0L 06A, IE intake manifold, built AEB head, 1000cc Boosted Euro Tune, bosch 044, Ringer Racing stage 3 hybrid Organic/Cerametalic 240mm clutch, S4 interior upgrade, full S4 brakes front and rear with lines, 17in OZ Racing Ultraleggera, 034 HD suspension arms, Stern soft mounts, mirimoto bixenon etc. http://www.audizine.com/forum/showth...s-Build-thread
    Oct 30 2008
    B5, B7, B8, 8V, 4M
    Big Lake, MN
    Quote Originally Posted by nynoah View Post
    Wow, someone likes it rough!
    2000 S4- Working?
    Apr 22 2007
    Riverbank, Ca
    I use a pick and work my way around. I've got one with an L in it about 2" long for this reason... Oxidized coolant is basically glue.
    73 914 1.8T AEB + FWD 016 trans
    AWM Wiring harness, Comp Turbo CTB5356, ABS, ESP, Custom interior, Flares, Brakes, Custom everything :) Build below
    Budget Outlaws Youtube
    http://www.914world.com/bbs2/index.php?showtopic=114780
    May 07 2015
    Butler, KY
    I wish I could get a torch on it but too many wires and flammable material down there. Thank you for all the info guys. I much appreciate it.
    Dec 05 2007
    PB Blaster is not supposed to be used on plastics. Just keep wiggling and it will eventually budge.
    Pro Tip: Spray mating surfaces with some type of lubricant spray when placing back on. Should slip back on like butter. I am a fan of Liquid Wrench Silicon Spray.
