Results 1 to 10 of 10
    Senior Member Two Rings Poopcorn's Avatar
    Nov 18 2014
    Calgary/AB/Cansda
    What spacer I need?
    Hi,Im buying a set of OEM rs4 wheels.... Just wondering what size of the wheel spacer I need?
    I'm current using stock wheels....
    THX GUYS
    Aug 26 2005
    No wheel spacers are required.
    Vorsprung durch Technik
    Nov 18 2014
    Calgary/AB/Cansda
    then why they are putting spacer on other wheels?
    Oct 01 2015
    Newmarket, Ontario - Canada
    Quote Originally Posted by Poopcorn View Post
    -Appearance. You want to push the wheels out for a better stance and more aggressive look. This is totally subjective to your personal tastes. And we can't tell you what to like...
    -Clearance. Many wheels are not compatible with big brake kits. The spoke of the wheel will scrape the new brake caliper and you need a wheel spacer to push the wheel spoke away from the calliper.
    -Correction. You may have bought a set of wheels that don't have the correct offset for your car. The offset may be too high, resulting in the wheels sitting too far inward. This is both ugly and incorrect as the tire can now rub on the inside wheel well, or on suspension components, etc. A wheel spacer will push the wheel out and 'correct' the offset.
    -Handling. By spacing the wheels further apart, you can make the car more stable and corner better. You can gain a similar effect as adding a wider wheel without the added weight and expense.
    Nov 18 2014
    Calgary/AB/Cansda
    Quote Originally Posted by vwdann0 View Post
    Thx for the reply.. that make more sense to me now...
    I'm thinking doing a brembo 18z BBK upgrade.... any idea what size of wheel spacer i need?
    Veteran Member Three Rings cschuster's Avatar
    Jun 05 2013
    Lexington, KY
    This wheel thread may help. Read the setups, there a few in there with bigger brakes. You can see what offset you're looking for, then get spacers to add ET if needed. ET is measured in mm.
    2011 TTS
    APR Stage 1|H&R Rear Sway|Bilstein B12 Pro-Kit|42DD Downpipe
    2002 A4 Quattro 3.0 6spd - sold
    ST Coils|RS4 Reps|Rebuilt 01E|Color DIS
    Nov 29 2009
    Miami / Florida
    OEM RS4 wheels are 19 by 9 et29. The stock sport B6 A4 17" wheels are 7.5 et45. That means the RS4 wheels will stick out an extra 35mm and give you 3mm less clearance. Depends on what tires you are using and suspension. Stock ride height, no problem. Lowered, depends. Running 235/35/19 would be a good bet. Don't order spacers without measuring and fitting because you can't generally return them and you probably won't need them.
    Here are some pics of a B6 with RS4 wheels. The title says B7 but there is a B6 in the thread:
    http://www.audizine.com/forum/showth...-fit-the-B7-A4
    Nov 18 2014
    Calgary/AB/Cansda
    Thank you guys!!!!
    Aug 26 2005
    Thank you guys!!!!
    To clarify my first reply, wheel spacers are not required for the stock RS4 wheels, unless, you are fitting extra large brakes or intend on running wider tires or you want to move the wheels outward for appearance or handling reasons.
    Nov 29 2009
    Miami / Florida
    Yes! good advice.
