So I know you can't technically adjust the camber of a b5 s4. But I know you can loosen the bolts and shift the subframe. I'm currently in school to become a technician and the other day I decided I'd try and align my car. Well I loosened all the 8 bolts for the subframe and couldn't get that SOB to move at all. Couldn't really find a good pry spot either. I couldn't find a spot between the sub frame and the body. I tried just pry against the lift and the sun frame but the car wanted to slide on the alignment pads. What are my options? Has anyone had any luck doing this?
