Originally Posted by
S4V8
Hi All,
Looking for some guidance. I need some help deciding as to what would be the best wheel and tire size option for my set up? I will be lowering my Allroad on coilovers and although I will be going low, I won't be riding slammed - just enough to tuck the tire. That said, I thought the wheel and tire size in this picture (see below), would be ideal however, I am not sure if I want to the tire so stretched like that - Will it look silly given I will be on coilovers? I am not going with air suspension. I was told a 275 tire would be my best bet?
Given I will be on coilovers, would the following rim and tire size be over kill? I know I definitely want 20's but I question the tire size? Perhaps the rim size as well? Looking for some guidance!
geojt72
I'm looking at 20x10 et35 for my allroad. what do you guys think for a tire? lowered with h&r sports for the allroad. thanks.
Depending on how low you go you might be rubbing at 275 on 20x10. At .5 inches above to flush(top of the rubber) you should be good. I would say if anything, 255 or 265 you should be ok on the 20x10 if you are going past the top of the tire.
Cropped a few pictures to show you the fitment.
I'm running 20x10.5 at et23 wearing 275/30/20 and it tucks because of chamber with mild rubbing if I lower it enough to tuck the top part of the tire which I rarely do(don't like rubbing lol).
I will rub if I'm turning down a drive way, corner or a pothole.
20x9 at et45 wearing 255/35/20. Using 20mm spacers which gives me 3mm of play in the front but
still rub if I lower the car .5 below the top of the tire. **you can see a little gap in the front. Spacer sizes will also help you get the tire fitment you want while minimizing the potential to rub.
