Originally Posted by
JimmyBones
I have done timing chain services with the engine still in the car but it is much more involved then just taking the transmission/clutch/flywheel off. I say that because there is a certain order to how the covers for the timing components come off and there is a lot of other stuff that has to come off before you can even get the timing covers off. The lower left guide that always breaks requires the really big lower timing chain cover to be taken off. Which means that everything else is opened up. The camshaft adjusters however can be replaced without taking the transmission off but the whole top of the engine has to come apart.
Apologies for the thread jack, but this is great info. Right, so assuming trans/clutch/flywheel already off, what's involved to get to that lower left guide? Oil/Coolant drain, Coolant hard-pipe in the back, some wiring and misc connections, valve covers off up top, upper covers off from each bank, then the lower back cover? I know I'm over simplifying it.
Does removing that lower rear cover mean the full timing service is required? Or can it be removed to replace the bad guides without the motor needing to be re-timed?
