1) Intermediate JHM Timing Kit
2) Motor Mounts
3) Trans Cooler Kit (JHM)
4) Piggie Pipes
5) Oil Check Valves
This is being done in my 14x20' garage, no air compressor or air tools. My timeline is 9 days, starting last Saturday and I hope to be back driving it to work Monday. It's been quite the adventure so far. Knock on wood, everything to this point has gone fairly smoothly. Broke the rear coolant hose pulling the motor, and my DP flex joints are pretty trashed, but everything else seems OK so far!
Getting Ready:
Front End Off:
Pulling it Out:
Engine Out! Had to build some stands:
Tried to mimic the Audi specialty engine table:
Downpipes with flex joints in rough shape:
Electrical Harness Off. That's gonna be fun to get back on...
Trans Off:
Rebuilt the engine & trans supports in prep for motor teardown:
Ready to take Timing covers off:
Bank 2 and Bank 1 top end:
Crankshaft lock pin Installed - hopefully this is all the way in! I put some paint on the tip, it doesn't seem to bottom out in the hole in the motor but it definitely centered:
Covers off!
Justification and gratification for doing it all! Two cracks on the guide!
More to come later, this is as far as I am right now. Some interesting notes:
1) One bolt on the Bank 1 valve cover, top back corner, sheared in half. Might have to drill it out (if I can), or just put on extra RTV, not sure yet haha.
2) Bank 1 was a fraction of a mm off from being able to slide in the camshaft locking bar easily. Bank 2 went in fine. Had to manipulate the camshafts at the hex bolt with a wrench on Bank 1 just a smidge to get the bar to slide in.
3) Finally found a local shop weld in new flex joints and relocate my rear sensor bungs. So hopefully the piggies will still come to fruition.
This has been interesting. I just hope it goes back in as easily as it all comes out and I can get all the electrical and whatnot routed correctly again. I took lots of pics but it is a serious rats nest when it is all on there!!
