Results 1 to 20 of 20
    Veteran Member Four Rings CJ_'s Avatar
    Oct 27 2014
    Flag/Phx, AZ
    AN/NPT Fittings question. Running aftermarket fuel rails
    So I have a set of IE fuel rails I want to run and Im a noob with AN/NPT fittings. After some of research, I drew up a diagram of what I thought would work, but I wanted to get some help before I go order all this stuff (Its not cheap).
    The ends of the fuel rails are -8an o-ring boss ports
    The inlet/outlet of the FPR housing are -6an o-ring boss ports
    Can I use the NPT to AN fittings in the diagram?
    Here is my diagram:
    2001.5 Silver S4 Avant - 6spd swap + BW K04s (Current)
    2001.5 Santorin S4 Sedan - SRM k24 build (Totaled)
    IG: CJ_s4
    Veteran Member Three Rings Audi9's Avatar
    Jul 20 2014
    B5 S4, 8V A3, 8V.5 RS3
    San Antonio, TX
    So the rails and the regulator are NPT? I would assume so and in that case youre correct
    And awesome drawing/diagram by the way
    Oct 27 2014
    Flag/Phx, AZ
    Quote Originally Posted by Audi9 View Post
    Thanks, The ports are labeled on IEs website as -8an o-ring boss port and -6an o-ring boss port which is kind of my question..
    Does -8an o-ring port = 3/4 -16 NPT
    and -6an o-ring port = 9/16 - 18 NPT?
    IG: CJ_s4
    Veteran Member Four Rings FlyboyS4's Avatar
    Jan 06 2007
    Mk7 Golf R
    FL
    When I get a chance I'll see if I can find the part sizes I used.
    Veteran Member Four Rings jballou's Avatar
    Mar 19 2005
    2007 Honda Fit
    Corona, SOCAL
    NPT is totally different than -an size. If IE calls for a -8an O-ring fitting, that is what you must buy. Don't try and save money, it will just cost you more later on.
    2000 Audi S4 Stage 3,000 Million +
    Some crap just thrown together, puzzlingly making more power....
    YouTube Channel: http://www.youtube.com/user/jsballou
    www.tvme.info
    Oct 27 2014
    Flag/Phx, AZ
    Quote Originally Posted by jballou View Post
    Awesome, thats the answer I was looking for, thanks..
    So this is the fitting I would need to run the 90ºs out of the rails then correct?
    http://www.jegs.com/i/Russell/799/670700/10002/-1
    IG: CJ_s4
    Dec 14 2008
    Finland
    At what power level single feed isn't enough anymore, is there any experience (in any platform?). I was going to feed both rails separately.
    World's Fastest B5 Avant biturbo Full Weight
    With Race Seats @3800lbs
    TTE950+ 100-200kmh 3,81s
    Veteran Member Four Rings Corbett's Avatar
    Mar 09 2011
    Detroit, MI
    Quote Originally Posted by Mikse View Post
    None
    Sportec RS600 + 6 speed swap. Fastest RS6 in the USA
    Oct 30 2008
    B5, B7, B8, 8V, 4M
    Big Lake, MN
    Not really. The AN fitting size is just how many sixteenths the OD is. So, a -8an fitting would be roughly equivalent to 1/2 NPT.
    2020 SQ7- Wife's ride
    2000 S4- Working?
    Mar 19 2005
    2007 Honda Fit
    Corona, SOCAL
    Quote Originally Posted by redline380 View Post
    Ah, it says closest AN fitting Size. I would just stick with the -an size.
    www.tvme.info
    Mar 19 2005
    2007 Honda Fit
    Corona, SOCAL
    Quote Originally Posted by CJ_ View Post
    Looks about right. When I did my dual in-tank fuel pump set-up from SRM (their Kit,) I still spent a ton of money on extra fittings and lines as I wanted to run the stuff my way. It can get spendy quiet fast.
    www.tvme.info
    Mar 19 2005
    2007 Honda Fit
    Corona, SOCAL
    You can also do a 90 degree O-Ring fitting as well if you want to keep things a little tighter.
    http://www.summitracing.com/parts/rus-612470
    www.tvme.info
    Oct 30 2008
    B5, B7, B8, 8V, 4M
    Big Lake, MN
    I'm confused. Doesn't he just want to use NPT adapters to go from NPT on the rail to AN lines? Nothing wrong with using adapters, just use ones with similar ID's.
    Nevermind- I reread the OP. Yeah, you cant jam an NPT fitting into a AN thread! That will definitely leak. Need to keep it AN all the way around. I thought the rails had NPT threads on the ends.
    2000 S4- Working?
    Oct 27 2014
    Flag/Phx, AZ
    Sweet! Definitely got my answer.
    Those 90º o-ring fittings look perfect. Thanks Justin!
    IG: CJ_s4
    Dec 14 2008
    Finland
    At what power level single feed isn't enough anymore.
    Quote Originally Posted by Corbett View Post
    None
    That confident answer must have first-hand experience to back up a claim.
    Jul 20 2014
    San Antonio, TX
    Haha good thing this thread didn't get confusing.
    If the rails/regulator are AN threads then you'll have to stick with that as NPT threads are tapered while AN are standard with a 37* flared mating surface
    Veteran Member Four Rings zillarob's Avatar
    Nov 16 2010
    2kS4, 84gli, 84caddy dsl
    WetSide, WA
    I wouldnt use 90s off the reg and feed.
    This is with 90s
    This is with (iirc) 45s so I could route the lines along the firewall and out of the way.
    There are only 2 things needed to make an Audi work properly - Duct tape and WD40. If it moves and it shouldn't - Duct tape. If it doesn’t move and it should - WD40.
    Oct 27 2014
    Flag/Phx, AZ
    Quote Originally Posted by zillarob View Post
    This is with 90s
    Ahh, yeah that looks alot better
    IG: CJ_s4
    Veteran Member Three Rings rnagy86's Avatar
    Apr 12 2012
    RS4%2CRS6
    Budapest/Hungary
    This is what I did, 8AN feed to dual 6AN and 6AN return. Everything fits perfectly.
    Veteran Member Four Rings mauromj's Avatar
    Jul 23 2012
    Pullman, WA
    Quote Originally Posted by rnagy86 View Post
    Is that stainless hose painted black? Looks good!
