So I guess I'll start this story from the beginning and see what kind of advice I get from everyone here.
In order to keep from bringing negative attention to any company or anyone I'm going to omit some information.
So long story short, last week I went and had my all season tires stripped from my wheels and had my snow tires installed. During this time I spoke with one of the guys at the desk, mentioned I had 5mm spacers and that they didn't need to be reinstalled with the snow tires and that I would like to make sure the hub rings do get re-installed as well. Just before he walks off I also request that they be careful NOT to over-torque my lug nuts. He assures me that they use torque wrenches and that I have nothing to worry about. I ask how long I should expect to wait, he says 90 minutes. I say ok, thinking to myself 90 minutes to strip tires and install and balance snow tires? Seemed excessive but whatever.
About 60 minutes goes by and my phone battery decides its a good time to give up on me and leave me with nothing to entertain myself with. So I start wandering around the place and happen to notice my car on the security camera behind the desk, I think to myself well that's pretty cool, I'll watch while they work on my car. I go back to pacing about and glancing at my car. I actually commented to myself that the tech seemed to be spending an excessive amount of time working on my driver's side front wheel. No big deal, they don't always line up right away and can be a little finicky. Back to pacing. It took the tech about 2 minutes to reinstall the driver's side wheel. So after the about 90 minutes I was quoted and $40 some-odd dollars later I am on my way with my snow tires installed. Yay, they ride better and grip great.
Fast-forward to last night. In this time I drove from the tire place to my house and parked. Hadn't moved since then. I get in my car, driver's side wheel is making a squealing noise. Thought it was odd, maybe due to the cold, spray some wd40 on it. Drive a bit, gets a little less and then I hit a pothole and the noise disappears. I thought this was weird. Anyhow, I was on my way to a warm garage (parent's house) for dinner and to make adjustments to my suspension.
I take the driver's side front wheel off first to try and locate the source of the squeaking. Upon attempting to remove the wheel I find it EXTREMELY difficult to remove. I had to really lay on my breaker bar and even after it was broken free they didn't spin freely. It seems that the lugs are cross-threaded. (I have taken my wheels on and off at least a dozen times since I last had anyone else touch my car, always hand turn them in and out before applying any amount of heavy force.) I finish with that wheel. Go to the rear. 2 of the lugs take almost ALL of my bodyweight and strength on the end of my breaker bar to break free. I estimate WELL in excess of 200 lbs of torque on the lug nut. I notice that it has warped the socket on my breaker bar. I then go through the rest of the lugs and find several UNDER torqued and several take as much if not MORE force to break free. To further explain just how much force was used I SNAPPED the socket end off my breaker bar AND the adapter bit.
To top all of this off, they also added a scratch to my rims.
I am going to go over there and complain and demand some type of compensation/fix for the broken tools and cross threaded lug nuts. Do you think this is a fair course of action or would you do something else?
TL:DR version.
Went to tire store to have snow tires installed, they cross threaded my lug nuts on the driver's side front wheel, over torqued or under torqued all of my lug nuts, caused me to break a solid steel breaker bar and 1/2" drive to 3/8" adapter.
This is the breaker bar.
