Results 1 to 40 of 77
    Senior Member Two Rings blackmage's Avatar
    Dec 24 2012
    96 Mustang GT - 4V
    Northern Wisco
    Exclamation 03 Allroad 6mt swap
    don't post here often but I feel like it would be good to start up a thread on my swap to keep my thoughts organized. have an 03 allroad with a tip trans that I'll be doing an 01E swap in. Trans slips going into reverse and RPM's hang as I'm accelerating and sometimes slips going into 4th and 5th. Trans swap came from audi4parts.com and is out of a '99 A6. Current plan is to completely pull the motor and trans out of the car so I can replace leaky seals and I think it'll just make the overall swap easier. I have a lift and plenty of tools, so it shouldn't be too big of an issue getting stuff out. I have to wait till spring until the snow leaves northern wisconsin and I can get the mustang out so i dont have to rush through this swap. so hopefully we have a mild winter which so far is what we got.
    I have no plans at this point to do a K04 swap or any crazy power upgrades as it's mainly a daily driver and I have my mustang if I really wanted to have some fun. plus its way cheaper and easier to replace stuff hah.
    This is what i'm working with.
    i have no idea how the shifter stuff goes together, and I think im actually missing a cup and a bushing or two. not entirely sure
    Right now this is the list of things I still need to buy/order before I tear the car apart.
    Flywheel bolts
    pressure plate bolts
    clutch disc
    wheel bearing
    pinch bolts
    trans fluid
    brake fluid
    front brakes
    rear brakes
    valve cover gasket
    cam seals
    throwout bearing
    pilot bearing
    alignment sleeves
    SAI blockoff plates
    starter
    alternator
    spider hose
    motor mounts
    turbo gaskets
    hollow out down pipes
    flush heater core
    anything else I should look at replacing while its out?
    These are a couple links I'll be relying on while doing this swap to make sure I get everything I need as I don't think the swap kit came with everything, but some of it should just be replaced for maintenance reasons anyways.
    http://www.audizine.com/forum/showth...-Bigger-Badder
    haha, the fricking pinch bolt... i need to replace a wheel bearing so im going to pull both pinch bolts on both sides and it'll just make things easier with the axles, and any fixes in the future as i dont think theyve ever been removed
    http://www.passatworld.com/forums/b5...easy-pics.html
    01E parts swap thread
    http://www.audizine.com/forum/showth...p-parts-thread
    random thread 01e swap
    http://www.audiforum.ca/a6-s6-rs6-71...wap-diy-59468/
    and the random slight set back one afternoon
    DRIVE A HYBRID MY MUSTANG NEEDS YOUR GAS
    -95 Mustang GTS - Sold :(
    -96 Mustang GT - 4v swap
    -03 Audi Allroad 6MT swapped, stuklr tuned
    Dec 24 2012
    96 Mustang GT - 4V
    Northern Wisco
    ordered new front wheel bearings and pinch bolts. going to knock that out this weekend which will give me a head start when i go to do the swap. went with the F.A.G. front bearings and new bolts from Euopaparts.com. Wheel bearings will be the easy part... just have to deal with the pinch bolts in this Wisconsin climate.
    Aug 04 2009
    Glen Ellyn, IL
    Oh man, I wish you all the luck. I ended up replacing my uprights altogether. I hope it doesn't come to that for you. Good luck!
    OEM+ work in progress allroad
    Unicorn Society member #8
    @fourings | Build
    Dec 24 2012
    96 Mustang GT - 4V
    Northern Wisco
    Quote Originally Posted by 4rings2turbos View Post
    Don't tell me that haha. I've had both nuts off which is the easy part, attempted to remove them when I needed to replace axles. But realized I didn't need to and put them back on. Week of pb blaster, please do your job!
    Sent from my iPhablet
    Aug 04 2009
    Glen Ellyn, IL
    Godspeed northern neighbor ;)
    @fourings | Build
    May 16 2008
    South Texas
    Your missing the bolt and washer on the big end of the isolator rod on the shifter and you will blow the inner CV joints on those axles with the air suspension.
    Dec 24 2012
    96 Mustang GT - 4V
    Northern Wisco
    I was worried about that. Does that allroad manual axle bolt up to the a6 flange, I'm assuming it wouldn't and I would need an allroad flange at the Trani side?
    May 16 2008
    South Texas
    Quote Originally Posted by blackmage View Post
    You will need Allroad flanges and axles or my heavy duty axle kit.
    I also have Allroad axles.. Price is the same as the above.
    Dec 24 2012
    96 Mustang GT - 4V
    Northern Wisco
    Well lets see, almost have everything ordered
    Flywheel bolts
    wheel bearing
    pinch bolts
    trans fluid
    valve cover gasket
    cam seals
    throwout bearing
    pilot bearing
    alignment sleeves
    SAI blockoff plates
    motor mounts
    turbo gaskets
    coolant
    Just want to get a new starter and alternator and I should be set to pull everything
    Aug 04 2009
    Glen Ellyn, IL
    Yeesssssss.
    Do you have a hopeful deadline for firing it up?
    @fourings | Build
    Dec 24 2012
    96 Mustang GT - 4V
    Northern Wisco
    I really want to have it on the ground driving by June 1st. Does June 1st have any meaning? No not really lol. I still have to wait until the snow stops falling though before i can get started! :( :(
    Aug 04 2009
    Glen Ellyn, IL
    Oh, gotchya, outside venture?
    Too bad you couldn't come south a bit and we could bust it out in a weekend in my heated garage.
    @fourings | Build
    Dec 24 2012
    96 Mustang GT - 4V
    Northern Wisco
    ill actually be inside with a lift thankfully. but, ive never pulled an audi motor before so this is slightly new territory for me and ill be a little slower than pulling my mustang motor. with that being said, the stang is the only other mode of transport so i need the snow to go away before it comes out of the garage.
    Aug 04 2009
    Glen Ellyn, IL
    That makes sense. I bet you're itching though :)
    @fourings | Build
    Dec 24 2012
    96 Mustang GT - 4V
    Northern Wisco
    everyday I park next to the lift that i'll be working on. its never used except by myself and the maint guy i work with. so to say that its teasing me is an understatement lol
    Aug 04 2009
    Glen Ellyn, IL
    Hahah, that'll do it.
    Plans to bring it out to camp allroad?
    @fourings | Build
    Dec 24 2012
    96 Mustang GT - 4V
    Northern Wisco
    none at this point. It would be a fun trip but I don't really have the passion to do it at this point.
    Glen Ellyn, I used to live in Addison on Army Trail Rd, right off of 365 near the White Castle down there.
    Aug 04 2009
    Glen Ellyn, IL
    Crazy, I'm on the North side of downtown Glen Ellyn so pretty darn close to where you used to be.
    @fourings | Build
    Established Member Two Rings spoolinrs6's Avatar
    Nov 06 2015
    c5 rs6 w/fmics, c4 s4, b8 s4, built wrx
    Clifton, NJ
    lol why dont you just buy a manual allroad?
    Dec 24 2012
    96 Mustang GT - 4V
    Northern Wisco
    Quote Originally Posted by spoolinrs6 View Post
    wheres the fun in that? lol plus anything i find for cheap is going to need all the work im going to put into it anyways. so i dont feel too bad about it.
    Veteran Member Four Rings Racin2redline's Avatar
    Aug 19 2012
    1997 Yamaha razz 50 (sik)
    Long island
    manual allroads are not easy to find with lower miles or clean, most have been driven to the ground .
    best of luck dude! I did the same as you bought a tip with a bad trans and just swapped it. was much easier to find a cheap auto allroad then pay someone for their already manual one with double the miles mine had.
    I'd highly recommend throwing some ko4s in there while its apart, then doing the Tuning and other parts down the road. car will run fine with just turbos
    Sent from my SM-G900P using Tapatalk
    IG: d3bel1o
    Dec 24 2012
    96 Mustang GT - 4V
    Northern Wisco
    Trying to find an allroad in general in northern wisconsin is bad enough, then add on trying to find a manual one that isnt rusted to hell? might as well look for a needle in a haystack. plus car is paid off and trans is on its way out, why not dump some maint money into what I have and not add on a payment. I can do the work so im not stressing over it :) its a hobby that i enjoy doin.
    I really wish i could do k04's, but money is just not going to allow that on this go around.
    Dec 24 2012
    96 Mustang GT - 4V
    Northern Wisco
    well, i think i have everything now. starter will be ordered when i get it off the car, and alternator will be here monday or tuesday.
    i did find a boogered up bolt hole when I was testing out the shifter, so I'll have to drill and tap it. not sure what happened here during removal, but either someone messed up or it got ripped out in shipping lol
    Dec 24 2012
    96 Mustang GT - 4V
    Northern Wisco
    well, let us begin.
    cleaned out the hatch so i could put all the pieces staying with the car, in a safe spot
    dont froget to set up your work area!
    unclipped and disconnnected the washer nozzles to prep the hood for removal
    take this clipped on cover off to release the washer nozzle harness and line from the hood
    have someone help if you can, remove the 4 bolts holding the hinges to the hood, unclip the prop rod, and remove.
    4 x 13mm nuts
    remove the battery cover and the rest of the cowl cover
    remove intake tube from bumper and intake box
    disconnect battery and tape up connections so they dont accidentally make it back to the battery terminals
    remove MAF and Y-pipe
    3 x 10mm bolts
    remove the TCU after changing ECU softcoding and programming ABS module.
    remove 2 phillips screws and pull off kick panel on passenger side
    pull up sill plate cover (all clipped in) and then pull up the carpet and pull out the TCU box
    open up TCU box and remove TCU
    sending the ecu in for tuning. remove bolts holding cover on. (leave the back one in, and you can squeeze the ecu out. you will also need to unclip the metal bar going across the ecu
    4 x 8mm bolts
    drill out the far left 2 tamper proof bolts if to get the ECU to slide out of the case
    jumping around a little bit, but I then moved to under the car.
    removed the O2 sensors
    2 x 17mm
    started removing the exhaust at the mid pipe.
    4 x 17mm nuts
    you can remove the hangers easily with a pry bar. just put the prybar behind the hanger and slowly force it off. the stock exhaust is pretty heavy, so have a helper or keep a jackstand under it.
    then removed the heat shields for the driveshaft
    8 x 10mm
    loosened the D/S carrier nuts. i also put a pry bar in between the U-Joint on the D/S so I could loosen the driveshaft bolts without it spinning
    2 x 13mm
    removing the rear D/S bolts
    6 x 6mm allens
    moved up to the front to remove the d/s shield from the trans, and also the d/s to trans bolts
    2 x T45 torx
    6 x 6mm allen
    might take a little persuasion for the joints to pop out of the diff and trans
    take the two axle covers off. 3 bolts per side
    6 x 6mm Allens
    Dec 24 2012
    96 Mustang GT - 4V
    Northern Wisco
    then remove the rear axle to diff bolts. 6 per axle.
    12 x M9 triple square
    remove the bolts holding the diff to the rear carrier
    3 x 8mm Allen
    remove the 3 bolts holding the front left bracket to the diff
    3 x 8mm allen
    diff is somewhat heavy with fluid still in it. I twisted the diff, so pass side was down and drivers side was up, and the axles popped out and diff came out quite easily
    then moved up to the front.
    i removed 12 bolts from each inner fender, drivers and passenger
    24 x T20 Torx
    once you pull the inner fender back, you will need to take off two more t20 bolts. there are 4 bolts that appear to be holding the bumper to the supports, two will have large flat heads, leave those two, but remove the top and bottom ones, on each side of the car
    4 x T20 Torx
    There are then 3 nuts per side holding the front bumper to the fenders
    6 x 10mm
    remove the 3 lower front grill covers, they just pull straight off. Once those are removed there are two allen bolts that go UP into the bumper bar.
    2 X 8mm Allen
    reach behind the fog lights and disconnect them
    With a strong hand, you should be able to pull just the bumper cover straight forward and off. Be careful, you still need to disconnect the washer fluid lines that supply the headlight sprayers. if your tank is full, itll spill a lot
    Dec 24 2012
    96 Mustang GT - 4V
    Northern Wisco
    disconnect the ambient air temp sensor, and also remove the bolts holding the power steering cooler on.
    1 x 10mm
    remove the 5 bolts holding the fan bracket on, and also the brackets for the A/C condensor
    4 x 10mm
    1 x T20 Torx
    the fan and p/s cooler should swing out of the way, along with the A/C condensor
    disconnect the horns on both sides, and also the sensor for the a/c line on the pass side
    disconnect the hood release cable. it just pushed towards the rear of the car and its off
    disconnect headlight harness from both sides
    remove cover from P/S reservoir, and then disconnect these three connectors
    remove the bolts holding the bumper supports to the frame rails
    8 x T45 torx
    disconnect the sensor on the lower radiator hose, and also disconnect the lower radiator hose.
    disconnect the upper radiator hose
    remove the trans cooler lines. one per line in the radiator, and then one bracket near the bottom of the radiator
    3 x 10mm
    there are 4 bolts on the top of the core support, between the headlight bolts and the fender. remove two on each side of the car. There are then 2 more bolts under the tip of each fender than need to be taken out. Once those 6 bolts are removed, the front core support and radiator can be removed
    4 x T27 torx
    2 x T27 torx
    everything off thus far
    Dec 24 2012
    96 Mustang GT - 4V
    Northern Wisco
    Time to remove the bi-pipes on the front of the timing cover.
    2 x 10mm hex
    There there are 4 hose clamps that need to be loosened
    4 x 7mm hose clamps
    next to go was the snub mount
    3 x 8mm allen
    then i removed the bolt holding the trani cooler lines to the trani cooler on the back of the drivers side intercooler.
    1 x 6mm allen
    removed a trani cooler line bracket on the pass side of the motor. I also removed the 10mm bolt on the front of the motor holding the lines with the a/c lines. I then disconnected the trani lines where they bolted together under the alternator, just to give myself some extra space.
    2 x 10mm hex
    Next comes the a/c compressor and lines. you will also need to remove the coolant hose that runs across the front of the engine and up past the oil filter housing. Also, remove the oil filter to clear the lines. Dont forget to unclip the connector on the compressor, and the one that goes through the lines and down to the top of the oil pan.
    3 x 13mm Hex
    1 x 17mm hex to release the belt tensioner
    top of the pan
    wrap up the lines and condenser off to the side so they do not get damaged.
    then i had access to remove the power steering line.
    then i disconnected the 3 fuel lines. made sure to take pics and mark where they went. I cut the one clamp and the other two were regular hose clamps. Took some force but they all came off
    moved down to the axles. removed axle covers from both sides.
    6 x 6mm Allen
    Next was the 6 per side axle bolts.
    Next, remove the axle nuts
    2 x 1 1/16" hex
    From there, you can remove both front axles with some persuasion. I am replacing my wheel bearings, so I had the pinch bolt out from up top, made it a little easier.
    Dec 24 2012
    96 Mustang GT - 4V
    Northern Wisco
    next to go was the engine mount nuts
    2 x 13mm hex
    its hidden in there, promise
    I had to drop the sway bar in order to get some good access at the nuts
    4 x 13mm hex
    next up were the trans mounts
    4 x 13mm hex
    moved back up to the front of the engine. out came the alternator
    1 x 13mm hex
    1 x 8mm Allen
    back of the alternator sported a 13mm nut for the power wire and single wire plug
    1 x 13mm hex
    here we are at now
    next to go was the starter wire and single wire plug. route that wire off to the pass side of the motor and out of the way. there is also a ground strap on the left side of the motor, as seen in this pic
    1 x 13mm nut hex
    1 x 13mm hex bolt
    went to the top of the motor and disconnected the vacuum line connected at the firewall
    disconnected this vacuum line as well, on the drivers side, under the silver canister by the p/s reservoir (honestly no idea what it is haha)
    cut the clip of the vacuum hose right above it as well and pulled it off
    Next i realized i needed to pull the ecu box top off to get at all the connectors. you can sneak an 8mm socket with 1/4" ratchet in to get the back bolt and it pops up. Then remove all the connectors from inside.
    1 x 8mm hex
    then find some goodies inside!
    remove this connector from the side of the master cylinder and fish it out with the ECU wires
    there are then 2 metric caps holding on the connectors to the firewall on the drivers side. remove those and the whole panel that has all the connectors. you should be able to put the whole ecu harness up onto the motor now.
    2 x 10mm hex
    remove the battery hold down and battery
    1 x 13mm hex
    remove the fabric protector from the heater hoses, and disconnect both heater hoses
    should look something like this now
    Dec 24 2012
    96 Mustang GT - 4V
    Northern Wisco
    there is a single p/s line on the back of the motor you will need to disconnect. i got to mine as i was pulling the motor, but you could probably get to it now too. you can see it on the back of the motor with a white dot on it. you'll need a 19mm and a 17mm open end wrench
    i then removed the SAI pump, and hoses, you can see it missing here
    5 x 5mm Allen
    lets get cleaned up and inside the car now
    to remove the wood bezel, grab it at the rear and pull straight up and towards the back of the car.
    As for the shift knob, put the car in neutral, push the silver collar down as far as it will go (i used a screw driver to break it free from the knob), and then pull the silver thumb button OUT and pull up with some good force and the knob will pop off.
    there are 4 tabs on the outside of the aluminum bezel, carefully open them up and take it off
    there are 4 more clips holding the circuit board to the base of the shifter, carefully undo those clips and then unclip the connector going to it
    there are 5 bolts to take out now. (the gold ones)
    5 x 10mm hex
    with those out of the way, you can release the park safety cable by pushing it towards the passenger side with a screwdriver. remove the connector at the front of the shifter base also
    there are two white tabs per side that will need to be depressed now, (they are on top of one another) and the shifter box will go out the bottom of the car.
    Its cherry pickin time!
    there is a lifting point on the drivers side rear, right where the SAI pump was.
    the front one is on the pass side front head.
    start the lift! keep an eye out for all conenctors/wires/hoses that may be in the way. I used a jack with a piece of wood under the trans to get the trans mounts above their holes and to help move it forward until it cleared their mounts.
    you will need to feed the heater hoses through the bottom of the firewall as you move the engine/trans out
    oops, i missed two connectors on the transmission. that are under the drivers side axle. one is a normal PIA audi clip, and the other you need to twist 180 degrees counter clockwise to undo.
    Dec 24 2012
    96 Mustang GT - 4V
    Northern Wisco
    now time to get some done on the motor/trans
    remove the heatshields on the downpipes
    12 x 5mm Allen
    also remove the Downpipes on both sides.
    8 x 17mm Hex (flange nuts)
    2 x 13mm hex (springs for exhaust hangers)
    remove the heat shields from the trans mounts, and also the trans mounts
    6 x 10mm hex (heat shield)
    6 x 8mm Allen (mounts)
    remove the bolt holding the trans cooler lines on, and also remove the speed sensor connector. There are also a few more brackets holding the lines on going to the front of the engine.
    1 x 13mm hex
    1 x 5mm allen
    2 x 10mm hex
    now time for the torque converter. locate the rubber grommet on the front of the bellhousing and pop it off. use a 24mm 12 point socket and breaker bar and turn the motor until you can see the TC bolts through the hole.
    3 x T55 torx
    1 x 24mm 12point Socket
    time to remove the trans. there is a connector hiding behind the oil return line on the top, get that! 1 x 10mm bolt. The next bolt is a nut a bolt right under it.
    1 x 10mm hex
    1 x 16mm hex (nut)
    1 x 8mm allen (bolt)
    There is a bolt holding on the starter and threaded into the trans on the pass side. you can reach this from the front with a long extension.
    1 x 8mm allen
    Three allens across the bottom on the front
    3 x 8mm allen
    There are now 6 more bolts across the front.
    6 x 16mm Hex
    before you take all the bolts are out, make sure both trans and engine are on the ground. the trans is a HEAVY SOB!! remove all the bolts, and then separate the combo
    clean up and take a break for the night.
    Sep 16 2010
    Central Wash
    This is an EPIC pictorial walkthrough for engine removal for almost any C5 Audi. good portion of it is applicable to every version of the C5 (and A8, A4 also!) Some of the fittings differ, electrical and whatnot, couple hoses might be different. But generally it shows just what you need to do to get it done.
    I think it might be worth stealing your pictures for a DIY in the tech section if you don't mind..
    Totally Awesome.
    Dec 24 2012
    96 Mustang GT - 4V
    Northern Wisco
    Totally Awesome.
    Thanks! yea if you want to use pics go ahead, just make sure to give credit ;)
    Aug 04 2009
    Glen Ellyn, IL
    This IS stupendously good.
    Good job taking the time for the community!
    @fourings | Build
    Dec 24 2012
    96 Mustang GT - 4V
    Northern Wisco
    Thanks!!
    Dec 24 2012
    96 Mustang GT - 4V
    Northern Wisco
    i took the time to clean out the bay with some degreaser and plenty of scrubbing
    Ill update this hopefully in the next day or so. I went through a server migration and a couple new exchange servers at work so i havn't had time to work on the car or get pics uploaded. Hopefully soon!
    Established Member Two Rings MrWalker's Avatar
    Mar 22 2016
    Laredo, Texas
    hey blackmage the pics are great. i'm going to have to use your guide for when i swap my TIP. keep it coming and can't wait to see the finished product
    2003 Audi A6 2.7T (AT) Stock for now
    2005 VW GTI 1.8T (MT) Stage 1 ECU by APR/ Cold Air Intake/ BOV/more to come
    2007 Chevy Suburban Stock
    Dec 24 2012
    96 Mustang GT - 4V
    Northern Wisco
    so bear with me, i kinda jumped around on the project.
    time to do the VC gaskets and intake manifold gaskets
    so there are 2 charge pipes, one on each side of the motor going over the top of the valve cover. the pipes are held in with O-rings, so they will slide right out.
    2 x 10mm hex
    I then removed the EGT sensors, and the SAI sensor, this is on the backside of the intake manifold on the passenger side.
    2 x 10mm hex
    Intake manifold will need to have the wiring harness removed prior to removal. Need to take off the bracket on the TB boot to get all of the wires loose. You can pull the loom back on the Pass and Drivers side towards the rear of the engine and let them dangle.
    2 x 8mm hex for the TB bracket
    The intake manifold will have 17 bolts total, with one bolt on the drivers side front holding a sensor down. Make sure to tape the intake ports up so you dont drop anything down them.
    17 x 5mm Allen
    Now we can hit the valve covers. There is also one bolt on the front timing cover that needs to come out that is holding onto the valve cover.
    16 x 10mm Hex (8 per side)
    1 x 5mm Allen
    there are a ton of how-to's on the valve cover gasket replacement, so im just going to post some pics of it.
    Cam chain tensioners
    8 x T30 torx (4 per)
    Cam Sensor (Drivers side rear head)
    2 x 10mm Hex
    Dec 24 2012
    96 Mustang GT - 4V
    Northern Wisco
    went for the starter removal, this is easy while the engine is out.
    remove the intake pipe on passenger side turbo
    1 x 7mm hex
    2 x 5mm Allen
    With the trans already removed, the starter should fall right out.
    with that out, i took off the engine mounts. was able to get these with ease using a 1/4 ratchet and deepwell 13mm socket.
    2 x 13mm Hex
    then moved on to removing the SAI crap. (pictures are of SAI parts removed)
    6 x 5mm Allen (3 on one side, 2 on the other)
    Picked up some 034 block off plates. using the supplied hardware install them.
    5 x 5mm Allen
    i then removed the automatic flywheel
    8 x 17mm hex
    After the flywheel is removed, take off the spacer that was used. You do not need this for the manual flywheel. Mine came off with a twist, ive seen some people say it takes some heat. Be careful, there is a seal behind it.
    Make sure you have the right flywheel bolts, they should stick out about so far. YOU NEED NEW ONES! ABSOLUTELY NEED NEW FLYWHEEL BOLTS!
    I put in a new pilot bearing as well into the used flywheel. Then put the flywheel onto the crank and start some bolts. The flywheel will only go on ONE way, it helps to have a second set of hands to rotate the flywheel as you put in a bolt.
    Torque specs for the flywheel bolts are 44ft/lbs and then turn them 180 degrees. Torque them down, mark the bolts, and then start turning. I found it was easiest to do this by myself with the Cam lock bar in place.
    Make sure you have the clutch in the correct orientation. Nothing like putting it in backwards and having to pull the trans to flip it over. (RS4 clutch and pressure plate)
    Dec 24 2012
    96 Mustang GT - 4V
    Northern Wisco
    its a mess... an organized mess
    I didn't want to spend the money on aftermarket downpipes, so i hollowed mine out for right now.
    started throwing on the shifter linkage onto the trans
    i then threw the spacer onto the motor. The one i got from the 99 A6 was the same as the TIP one off my 03 allroad. same part numbers and everything. i used the one off the 99 just because it came with, although i think it would have worked with either
    Made sure the new throw out bearing was in correctly and also that the slave cylinder was in correctly
    with some help, bolt the trans up to the engine.
    make sure to use the manual trans mounts, and not the ones off the TIP
    next was to lift up the motor and secure the rest of the trans bolts
    as long as the engine was up, put on the drivers side engine mount
    before the pass motor mount goes in, we need to put in the starter. so remove the intake pipe from the turbo, then slide in the starter and mount it.
    once the starter is in, put the intake tube back in, and then put the motor mount in
    moved onto putting the trans mounts on
    Dec 24 2012
    96 Mustang GT - 4V
    Northern Wisco
    always hear about people flushing their heater cores, so perfect time to do it. didnt find much, but hey its something
    leveled out the trans on the ground and began to fill it with fluid. fill plug is on the drivers side, in front of the axle
    make sure your drain plugs are tight.....
    moved onto putting the downpipes on. One of them broke at the flex pipe so I guess ill be getting it either welded up or getting some new DP's
    forget what this sensor is, but make sure to plug it in. its on the drivers side of the trans, almost up at the block.
    dont forget the speed sensor as well
    make sure all your intake ports are clear of debris. even if you had tape over them, double and triple check.
    put on the intake gaskets
    place the intake down and secure it
    I ended up making my own spider hose, and now was a good time to get it hooked up
    threw the intake pipes on that go over the valve covers. clean them up so not to damage the O-rings
    run all of the engine harness back across the intake and plug everything back in
    im going to deal with this reverse light later...
