Results 1 to 40 of 53
    Veteran Member Four Rings 88ninety9's Avatar
    Nov 02 2012
    Four rings and a long roof
    Indianapolis, in
    The way of the S4
    We all know the way....run for a month....broke the other 11
    /rant
    Intended on running some errands last night, so I go start my car to let it warm to temp as its real cold here. Starts fine all is well.
    15 minutes later, I come out to find it sounds like a diesel. Also chattering a bit. I immediately shut it off and push it back in the garage. Sound seems to be coming from somewhere in the pass head, and the front area of the motor. I'm thinking maybe a cam bearing or a busted lifter? Here's a video, it's not mine but directly represents my issue. Thoughts?
    https://youtu.be/Jfb2PYyOvdw
    2002 Pearl/onyx S4 Avant
    Aug 30 2007
    nyc
    what weight oil were you running?
    c5 A6 tip
    this n that
    Nov 02 2012
    Indianapolis, in
    I run 0w40 in the winter months. I will add, the car was half quart low on oil, which is odd as just a couple days ago oil level was fine. I routinely check the oil every 4-5 days
    Veteran Member Four Rings LakeTahoeQuattr's Avatar
    Jan 04 2013
    '07 JHM S6, '21 TTRS, '06 CTT, '20 Supra GR
    Zephyr Cove NV
    I am confused because the the video is 2 years old...
    21 TTRS - track whip 1
    20 Supra GR - track whip 2
    06 Cayenne TT
    07 S6 Thread
    SOLD 14 JHM Q7
    SOLD 04 D3L
    SOLD 02 ar Thread
    Veteran Member Four Rings AudiSport12's Avatar
    Feb 17 2006
    Coastal Georgia
    read boy
    2011 B8 S4
    2003 Z71 Tahoe
    2000 B5 S4 - Sold
    2001 B5 1.8TQM F21L - Sold
    2000 B5 1.8TQM - RIP
    2000 C5 4.2Q - Sold
    1997 B5 1.8TQ - Sold
    Nov 02 2014
    06 9-3 Aero 2.8T, 96 Miata
    Winchester, VA
    You guys need to drive your cars more! Been driving mine every day since I bought it in November 2014.
    Been down twice, once for a flat tire and I was lazy so I drove the backup.
    Second had a starter shit the bed a week after going stage 3, at a gas station. I pushed it as fast as I could and popped 2nd gear, got it to work and parked on a hill so I could get home.
    Also, Rotella t6 here all year long. And, I go 7,500 miles between oil changes. (All highway though, constant rpm for most of my trip so keep that in mind, if I drove it only for fun drives on the weekends it would probably be more like every other month.)
    Nov 02 2012
    Indianapolis, in
    Quote Originally Posted by DieselElectric View Post
    Mine is my daily. I run t6 from March to November. I've had nothing but issues back to back with this car, but I still love it like the day I bought it. I'm going to try to get the car in service position and pull the vc today.
    Veteran Member Three Rings 2000s4_m's Avatar
    Sep 05 2012
    2005 vw touareg 4.2 V8
    Mcallen, tx
    You might have a timing chain guide broken, just take off the valve cover and inspect the tensioner and guides, upper and lower, if they're good try starting in and see if tensioner is working
    Nov 02 2014
    Winchester, VA
    Quote Originally Posted by 88ninety9 View Post
    Well shit, there goes my theory.
    Stock engine with some rods tossed in. 11.25@132mph.
    Nov 02 2012
    Indianapolis, in
    Quote Originally Posted by 2000s4_m View Post
    I have a good head in my garage, so worse come to worse I could use that I suppose......would I be an imbecile to use parts from my other head to get it up and running quickly. As stated, this is my daily and I don't think my wife would appreciate me taking her car again. I guess worse come to worse, I'll have the heads redone with super tech parts (if anyone has a part list with numbers I'd highly appreciate it). I already have a head gasket set and full timing belt kit. The tbelt kit is a Continental kit, but I see no writing on the tensioner, is that normal? Kind of makes me nervous....
    Here was last year's fun.....sigh (this motor is NOT in the car, rather the garage)
    Sep 05 2012
    Mcallen, tx
    Not normal that they go bad but i've seen it happen, most of times is worn out guides (which are replaceable), i suggest you find the problem before you disassemble anything, it might be a guide, it might be tensioner itself or it just might be something else, i just saw in the touareg forum a guy with the same problem in a 4.2 V8 (uses same style tensioner) and on his it ended up being a blocked oil passage from the head, so it could be a number of things
    Mar 07 2013
    2015 Mercedes GLK350
    Rancho Cucamonga, CA
    /rant
    I daily mine, i know its odd to recommend, but I run .5-1quart of Mercedes ATF134 - the red atf fluid benz uses, every oil change, I also change my oil every 5k. I feel the small amount of atf keeps things clean inside. I know its odd, been doing it in family members cars for years to quiet lifter noises and such. just a thought to try. plus I think your noise may be low oil related or possibly the cam tensioner related, maybe not. any codes pop up?? just a thought.
    2008 Ibis RS4....GETing tuned
    Aug 06 2008
    Canadia
    0w-40 and engine problems, I'm having déjà vu.
    Lots of guys were running this oil in 2008-9 and a lot of them had problems.
    the B5 S4 is like the mafia... there is only one way out!
    Nov 02 2012
    Indianapolis, in
    Pulled the vc, nothing seems out of whack at first inspection. Lifters all seem in shape, tensioner guide looks ok, chain is tight, I did however find my vc gasket leaking. Looks like I need to start pulling the ds vc and see anything out of place over there. I am not a mechanic, nor do I claim to be, so please bear with me. Here's a couple shots of the head
    Sep 05 2012
    Mcallen, tx
    Turn the car on with the covers off, check if the tensioners loose pressure while the car warms up
    Nov 02 2012
    Indianapolis, in
    Drivers side
    Still everything seems normal...
    Nov 02 2012
    Indianapolis, in
    I briefly started the car this morning only to immediate hear clatter. By let it warm up, you mean to hook my coils/inlets/maf back up and let the car run?
    Sep 05 2012
    Mcallen, tx
    Yeap, can you see the bottom guide? Is it tight? Sometimes the chain is tight on top and loose on botton so when you turn on the engine the cam jumps back and forth
    Aug 30 2007
    nyc
    i think you should be running a 5w40 year round for these cars.. as 0w40 is could be too thin... i use m1 5w40 TDT, try it!!
    c5 A6 tip
    this n that
    Nov 02 2012
    Indianapolis, in
    Completed this process, the cams don't seem to have any movement, but the noise is more pronounced.
    Veteran Member Four Rings jpurre's Avatar
    Jun 11 2013
    2004 BMW 325i
    South Florida
    Could it be the timing belt tensioner?
    2001 Silver F21 TIP (SOLD)
    Build thread--> http://www.audizine.com/forum/showth...ally-Happening
    Mar 07 2013
    +1 for running mobil one, I use it in everything ive ever had, no problems. a lot of manufacturers use it in all there cars, benz uses it in ALL there cars, should be good enough for our rides....
    no worries man, just be patient with the stuff we recommend checking, difficult to diag over the keyboard....
    Mar 07 2013
    im assuming it follows the rpms, the rattle, it gets louder and faster if you rev the engine up??
    Mar 07 2013
    motor mounts good?? when was the last time you did the timing belt?? maybe try using thicker oil?? it sounds identical to the video you linked above??
    Mar 07 2013
    sorry for the multiple posts, just thinking and typing as the thoughts pop in my head, I doubt its mounts, but ive had some trashed motor mounts on cars before and the engine is basically rattling around in place, sounds horrific. I keep coming back to cam tensioners, if you've had a timing belt done recently or on schedule, that's my best guess..... but, if I remember correctly, should go away above a certain rpms, im not positive since I have not personally had that happen to me ....yet
    Nov 02 2012
    Indianapolis, in
    I shot a vid of the previous process I tried, just waiting for photobucket so I can upload it.
    I suppose I may as well start pulling the front off so I can get to the timing belt..
    http://s1160.photobucket.com/user/02...40523.mp4.html
    Nov 02 2012
    Indianapolis, in
    No worries for multi-posts I'm happy to take in the info.
    Yes, the noise follows rpm
    Mounts are in good shape
    It does sound identical (until removing the vc's where it's now more pronounced)
    Nov 04 2013
    stg 3 widebody, 1990 miata, '05 gsxr 1000
    Palo Alto, CA
    guys, this isn't an oil weight issue. and 0w 40 is fine for many conditions on a healthy motor (I ran it for years, as did thousands of others with no issues -- several audi shops were using it as their default fluid), yeah 5w 40 is probably better, but i highly doubt this is the cause of his issues. As to your specific issue, wish I could help, but i'd guess you're barking up the right tree. I wonder if it's as simple as that gasket leak. Might take a peak at the bottom end see if anything's obvious.
    maybe this helps, or hurts:
    http://www.audizine.com/forum/showth...-like-a-diesel
    so might check and see if there as a cylinder in particular misfiring. could be as simple as a dead plug?
    Aug 06 2008
    Canadia
    Quote Originally Posted by axnjaksn View Post
    Been in the s4 game 8 years now, it's always the guys running 0w40 having issues and saying "never had an issue".
    Jul 04 2012
    Woodbridge, VA
    Quote Originally Posted by james 408 View Post
    This guy might be on to something... Have you tried checking for misfires?
    Sep 05 2012
    Mcallen, tx
    Well, i guess then those are ok, i would check timing marks, crank and cams to make sure theyre ok, but other than that you might want to check into the oil grade, i really dont think that could be the problem but you never know, every engine is different
    Mar 07 2013
    Quote Originally Posted by MacDaddy View Post
    Yea, too thin of oil could cause an issue, I think I run 15/50... my shop use 5/30 or 5/40... one of the 2 weights......
    I didn't see you mention any cel or codes being present. that's where I would always start first, I thought that was asked above and idk if OP had checked that or not??? very easily could be a misfire, dead plug, coil.... check for codes, if its a whole bank then you could be onto something... icm maybe or that related bank cam tensioner?? if the gasket that sits under the cam tensioner leaks, do they cause that noise?? possibly, I know after I did mine, first start up was noisy as hell
    Nov 02 2012
    Indianapolis, in
    Only code is for sai, which is gone. Plugs are all new. Pulled them, rechecked the gap, all were in spec. Found a possible vac leak, will be addressed tomorrow when I pull the core support to examine the timing belt. One of the icm's are new, but I don't see having a misfire of that magnitude without a code
    Veteran Member Three Rings rguil's Avatar
    Dec 17 2014
    San Diego CA
    check total misfire count per cylinder in engine measurement blocks of vcds, misfire might not throw code but you can still feel it, nevertheless i dont think its a misfire issue.
    id have to agree with others as it sounds like the timing belt.
    Nov 04 2013
    Palo Alto, CA
    sometimes it's the insulation on plug wires, bad coil, etc. if it's isolated to a specific cylinder then you can start the spark, compresion, fuel testing with a more focused attack.
    Mar 07 2013
    I hope its timing belt and not the cam adjuster....... be less expensive and less labor intensive to do a timing belt service.....if that's all it is.. fingers crossed for ya man
    Nov 02 2012
    Indianapolis, in
    Tomorrow it's going the rest of the way into service position and I'll check the timing. Might as well do the timing belt job while I'm in there. I had intentions of doing head gaskets, timing belt, and misc other jobs come spring, but I have the parts and it getting torn down anyway I may just do it all. I have two other heads too so either way I have the parts. We'll see what tomorrow brings. Thanks for the help
    Nov 04 2013
    Palo Alto, CA
    that's the most b5 thing i've ever heard. Praise be. Amen.
    Jul 20 2011
    Providence - RI
    B5 needs oil change? I guess I'll do stage 3 w motor pull while I'm at it
    Nov 02 2012
    Indianapolis, in
    Ha! Love this
    Quote Originally Posted by Samataras View Post
    I'm not exactly sure I follow...
    Car got put off today. It was raining and it's right on the door of the garage. I already miss my climate controlled oversized 2 car
