Results 1 to 13 of 13
    Jun 09 2015
    Albania
    Changed the Headlights.. Need help
    Hello Guys.
    I own a Audi a4 2013. I was using the halogen headlights, when i bought the car it was in Halogen, and yesterday i decided to buy the Bi Xenon Lights.
    But now i am having some problems with an eletronics on car.
    The dealer changed the lights, the led lights are working perfectly fine, and they look so great now .
    But the problem is , that now none of interior lights isn't working, also in the speedo mater its not so light what it was before, if i want to put more brightness nothing happens. Also the back light when i put on R isn't working now.
    I changed today inside the headlights, a disk ( looks like an hard disk ) and put a new one, because the one that i had it wasn't supporting the jacks to put the Xenon lights. So When its this one, i am having all of these problems.
    Also the Start Stop, is not working, i can't turn it off, it's always on now.
    Anyone knows how can i remove all of the glitchs that are now in my car?
    And sorry guys, my english its not good.
    Sep 09 2010
    Destin, FL
    Quote Originally Posted by audi_fan1 View Post
    Hello Guys.
    I would bring it back to the dealer and see what they messed up. Did all of this start happening after you left there or later that day?
    Jun 09 2015
    Albania
    It starts immediately . They said that i need to go at another deal ( that is authorized ) and the new plate ( like hard disk ) needs to be added on computer and then everything will work fine. I never had any problems with my car until now
    Senior Member Three Rings Slim0531's Avatar
    Aug 05 2014
    2010 Santorini Black Land Rover LR4
    The basic thing to do is to check your fuse for any shortage. The dealer should know also if anything in the settings through VAG needed to be adjusted because you changed your headlights to HID.
    Aug 06 2012
    Parker, CO
    Did you have a non-Audi dealer do the work?
    Jun 09 2015
    Albania
    Quote Originally Posted by treginginco View Post
    Yes, its just one authorized place here in Balkan, where i live and its far away from where i am. Have everyone ever experienced these things?
    Jun 09 2015
    Albania
    Anyone has thoughts how to repair it?
    Jul 16 2008
    Finland
    Not quite sure what you mean by the "disc" but I assume you changed the 46 - Central Electrics / Comfort control module? It sounds like you got the wrong part.
    ______________________________________
    2013 A4 B8.5 Avant 1.8tfsi quattro, Ibis White. Mods: 8x18 OZ Leggera HLT for winter, OEM RS4 9x19 for summer, OEM trunk organizer rails, Underseat storage bins, S4 pedals, LED interior lights, H&R Sport, tint.
    Jun 09 2015
    Albania
    Quote Originally Posted by TDIaholic View Post
    Yes this one they changed, they took it from me because the one that i had, was not able to put the Chip inside from the LED Headlights, so they put the Audi q5 2013-4 and they started to work fine. But other parts inside the car are not working , starting from lighting inside, start-stop ..
    Veteran Member Four Rings Gunnark100's Avatar
    Oct 21 2012
    Earth...
    You still have component protection active, Audi dealer will remove. Its 09 module j519 and q5 one should be ok with a4 but cant be sure (depends from revision probably). 46 is convinience module.
    Retrofits: FL taillights / MMI 3G & 3G+(Street view incl.)/ Color Cluster & FL S5 Cluster/ BiXenon/ ADS Lite
    Other: ECU Tune/ VCDS Tweaks/ FL Gearknob/ Soundproofing/ Interior 6D Carbon Wrap/ Rieger Rep Front Bumper Valance/ Basic sound(8) upgrade to "ASS"(9+1) + B/O Sub(in sidepanel)/Tweeters + Activsub/ Efficiency Prog via Cluster & Gateway flash/ Sideskirts/ Window Tint/ Wsp Peeler reps/ License plate & Interior leds
    Jun 09 2015
    Albania
    Quote Originally Posted by Gunnark100 View Post
    You still have component protection active, Audi dealer will remove. Its 09 module j519 if q5 one is fully ok with a4 but should be, 46 is convinience module.
    Hello. Yes they told me the same thing!! Do you think that it will work good like before, when i remove these?
    Jun 09 2015
    Albania
    Hi guys. Now i got back, and someone programmed on vag com, and now they are working very well :) Does anyone knows how can i decrease a bit a brightness of the led? Because its to light at night.
    Thanks !!
    Oct 21 2012
    Earth...
    Thanks !!
    Search is your friend:
    http://www.audizine.com/forum/showth...-VAG-COM-codes
    Adjust LED brightness with headlight ON:
    [09 – Cent. Elect.]
    [Security Access - 16]
    [Adaptation - 10] -> Channel 3
    change from 9 to 100 (If you want LEDs at 100%)
    Adjust Turn Signals brightness when used as Parking lights:
    [09 – Cent. Elect.]
    [Adaptation - 10] -> Channel 5
    change from 35 to 100 (If you want LEDs at 100%)
