Results 1 to 8 of 8
    Established Member Two Rings QuatA4's Avatar
    Feb 12 2014
    2008 Infiniti FX35 AWD
    Strange "feature" in my 2016 A4?
    My 2016 A4 does this weird thing when I leave it running but parked, step out (with the key in my pocket) and come back 5 minutes later, I notice the e-brake is enabled and when I put it on drive, reverse or what not it wouldnt move.. Sometimes I cant even disable the e-brake and I have to turn the car off and on again. Is this some safety mechanism?
    2016 Audi A4 Progressive Plus w/ S-Line Competition Package in Suzuka Gray
    [RIP] 2009 Audi A4 2.0T Quattro Premium-Tech in Daytona Gray
    Senior Member Two Rings Nightkiller6's Avatar
    May 30 2015
    San Diego, California
    I dont think it is strange. Im sure it is just some safety feature for whatever reason maybe so someone cant attempt to drive off with the car.
    B8.5 Ice Silver A4
    Mod List- USP Motorsports Full Interior Lighting Kit | USP Motorsports RFB Led Reverse Lights | Hoen Xenonmatch Fog Lights | iJDMtoy Led Front Turn Signals | USP Motorsports Honeycomb Grille | Hartmann HTT-256 MA-M 19x8.5 ET 38 | Michelin Pilot Supersport 255/35/19 |
    Nightkiller6 is my Xbox gamer tag I made when I was 8.
    Aug 04 2010
    Queenz/Westchester
    Does not happen in mine. Do you shift into gear with the door open?
    Veteran Member Four Rings Project Quattro's Avatar
    Mar 24 2014
    1984 Porsche 3.2 Carrera Targa, 2019 Audi SQ5 Prestige (hers)
    I don't have the advanced key, but what happens if you leave the car key part in the car and remove the silver piece (which I assume would have your house key on it)? That may eliminate the issue.
    Sent from the Pedal Responce Emergency Bat Phone
    2020 Alfa Romeo Giulia Ti Sport Carbon - 1984 Porsche Carrera 3.2 Targa
    Past: 2017 Audi A4 Prem+ 7AT, 2013 BMW 528i xDrive, 2013 Audi A4 Prem+ 6MT Sport, 2009 Audi A4 Premium 6AT
    Chairman Emeritus for the Pedal Responce Team
    Dec 12 2014
    Bolingbrook/Illinois
    I thought that this was going to be about the factory installed swirl marks.
    2012 A4 P+ quattro S-line appearance
    Established Member Two Rings mlzervas's Avatar
    Oct 02 2009
    2009 B8 A4 Avant Gone: 03 A6 Avant- 04 350z roadster - 98 A4 1.8tQ - 03 Range Rover HSE
    Louisville, KY
    The 2015 I had for a loaner did the same thing. I had to disengage the parking brake in park if I left the car running with the keys in my pocket. I never had it not allow me to disengage, even if I would put it into gear first. I would simply put it back in park then turn off the e-brake.
    Veteran Member Four Rings Lambda13's Avatar
    Jul 07 2012
    A4, car parts, paint, random sockets, OEM parts.
    Boston, MA
    Is your car an MT? Could be to prevent the car from rolling away if you step out?
    My 2009 A4 Prem+ Build thread
    Veteran Member Four Rings adamazing's Avatar
    Apr 26 2014
    San Diego, CA
    Mine does it. The car engages the e-brake as soon as I open the driver door with the car running. Always thought it was a nifty feature so you're not using the transmission as a brake.
    You don't even have to disengage the parking brake. Simply put it in gear and start to drive off slowly - it will automatically disengage as well.
    2013 A4 Quattro Green Black Iridescent / APR E85 Stage 2 / AG F421 Polished Copper / Eurocode FMIC + HFC / AWE Quad + CF Diffuser
    build / instagram / flickr
