Results 1 to 7 of 7
    Senior Member Three Rings AllroadMass's Avatar
    Oct 30 2015
    Massachusetts
    04 Allroad 4.2 power steering leak
    Got a slow leak in my power steering system, I usually top off the fluid about once every 3 weeks. Starting the car today and heard the whine and I'm getting bubbles in my power steering reservoir.
    Where's the power steering pump on these 4.2? I see 2 lines leaving the reservoir and I'm wondering if I have to take the frond end off to get to the other end or can I can I get to it by taking the belly pan off?
    Veteran Member Four Rings LakeTahoeQuattr's Avatar
    Jan 04 2013
    '07 JHM S6, '21 TTRS, '06 CTT, '20 Supra GR
    Zephyr Cove NV
    Where is the leak dripping down from. What area under the car? Take off the belly pan and have a quick look
    21 TTRS - track whip 1
    20 Supra GR - track whip 2
    06 Cayenne TT
    07 S6 Thread
    SOLD 14 JHM Q7
    SOLD 04 D3L
    SOLD 02 ar Thread
    Oct 30 2015
    Massachusetts
    will do as soon as it warms up a tad. Sucks working on the car when it's 9 deg and I don't have a garage
    Veteran Member Three Rings carmudgeon's Avatar
    Oct 23 2012
    1995.5 S6 Avant
    Kansas City
    If you're lucky its one of lines between the reservoir and the pump. The pump is on the drivers side and is fairly close to the reservoir.
    Previous vehicles: 2012 TTS Roadster - 2017 Golf R - 2002 S6 Avant - 2013 S4 - 2008 Subaru STi - 2007 Mazdaspeed3
    Oct 30 2015
    Massachusetts
    Quote Originally Posted by carmudgeon View Post
    That would be awesome! Will I be able to see the pump from underneath?
    Sep 16 2010
    Central Wash
    On that particular engine I think it's not super fun. Maybe less than the normal amount of power steering fun. Follow the lines, I think there's nothing on the drivers side front of that engine. The thread below says it's just below the AC compressor and driven off the back of the engine.
    Here's a thread that talks a little about where things are on that V8..
    http://www.audizine.com/forum/showth...a-few-pictures
    Sep 27 2015
    Prov
    check the high pressure line in the pump , the 19mm/17mm flare nut running to the back of firewall. low pressure line passage from pump through block ----> rresevoir
