Results 1 to 10 of 10
Thread: Spacers
    Apr 21 2004
    2013 S4 6MT, 2011 Escalade
    Coopersburg, PA
    Spacers
    Just got a '13 6mt. Looking to push my stock 18" split 5 spoke wheels closer to flush. What size spacers do I need front and rear? Thanks.
    2013 S4 6MT // sport diff // B&O // Phantom Black // Black Leather and Black Alcantara
    Nov 19 2015
    Philadelphia, PA
    Ecs tuning has a spacer flush kit. Check it out
    Sent from my SM-G925V using Tapatalk
    Senior Member Two Rings justr0's Avatar
    Jul 24 2015
    2001 Mustang GT, 2007 VW Jetta, 2015 Honda CRV Touring
    2014 Phantom Black CPO
    P+/DSG/Sport Diff/B&O/Black Optic/Carbon Inlays/Magma Red & Black Nappa/19" Rotors/Supercharged Badges/Conti DWS
    Mods:APR II+DL501/InjenSP CAI/AWE Touring 90 BD+Res.DP/CR-15/EC AK+Sway+EL+Mounts/Bilstein B8/H&R OE/ECS Flush Kit+SS Lines/Motul RBF600/RS4 Grille/SunTek Carbon 35%/PC 19" Rotors/PD Emblem (Red)/Carista/BV DR650GW/Passport Max2
    TBD:Akebono pads/Slotted Rotors or JHM 382mm Kit
    Apr 21 2004
    Coopersburg, PA
    Thanks, that's what I was looking for.
    Senior Member Three Rings Mat@1975's Avatar
    Jun 14 2015
    FRANCE
    Hello !
    Those flush kit are rather for 19" OEM wheels (8.5" width , ET 43)
    I can remember that 18 " OEM wheels are 8" width, ET 47
    So 18" wheels are ~ 10 mm less flush (more interior) than 19" ones.
    A verry conservative set up could be : 17.5 mm Front and 20 mm Rear
    The maximum flush set up (with possible little rub depending on tires and alignement specs) is ; 20-22 mm Front and 22-25 mm Rear.
    Best regards,
    Mat
    S4 B8.5 AVANT | S-Tronic | Full ADS | Sport Diff | Glacier White
    MRC Stage 2 Tune | MRC TCU Tune | AMS/Alpha Cooler| AWE + AFE filter intake with airbox hole
    KW HAS Springs | H&R Sway bar F&R | Custom 14 mm Front and (13 R / 16 L) mm Rear Spacers | CR-15 Strut Brace
    OEM Rotors | Michelin PSS 255/35/19
    Q5 calipers | Goodridge SS Lines | 2-pieces Girodisc Rotors Front & Rear
    Apr 21 2004
    Coopersburg, PA
    I ordered 10 front, 15 rear. We will see what that comes out looking like.
    Mat, what part of France do you live in? My uncle lives right outside of Monaco.
    Veteran Member Four Rings AWDLover's Avatar
    Feb 07 2012
    15/20 f/r is a good spacer setup for OEM 18's
    2010 A4 Quartz Grey (click) | APR | Eurocode | GFB | 034 Motorsports | Eibach | H&R | VMR | P3Cars | aFe
    Jun 14 2015
    FRANCE
    Quote Originally Posted by Live2Ski View Post
    Hi !
    I live near Paris.
    Are you lowered ?
    Seems you made a verry verry conservative choice. I hope you will not be disapointed.
    Personnaly, i think i would have gone with H&R DRA spacers (double lugs) with 20 mm front and 20 mm rear with the OEM 18" rims.
    Happy new year !
    BR
    Mat
    Apr 21 2004
    Coopersburg, PA
    Not lower, with no real plans to go lower. Im thinking about just placing a new order for 15f/20r and just sending back the first order.
    Veteran Member Four Rings S-Fore's Avatar
    Sep 17 2007
    I have ecs 10 & 15mm w the correct size RAD lugs. I had used them on my oem 18s for winter when I had my B8.5 S4. Pm me if interested in them. Was getting around to posting them for sale.
