Results 1 to 21 of 21
    Active Member Four Rings alien_brain's Avatar
    Jun 04 2013
    SE MI
    air ride console switch delete?
    id like to consider doing this. has anyone already done it and what did you do exactly?
    Veteran Member Four Rings LakeTahoeQuattr's Avatar
    Jan 04 2013
    '07 JHM S6, '21 TTRS, '06 CTT, '20 Supra GR
    Zephyr Cove NV
    I do not even know what you are talking about. A few more specifics
    21 TTRS - track whip 1
    20 Supra GR - track whip 2
    06 Cayenne TT
    07 S6 Thread
    SOLD 14 JHM Q7
    SOLD 04 D3L
    SOLD 02 ar Thread
    Jun 04 2013
    SE MI
    do you have air ride? or an allroad? have you deleted your airbags yet? its a common thing to do. that makes the control buttons on the center console useless.
    Sep 11 2009
    NE
    you'd have to do something with ESP button....
    Jan 04 2013
    Zephyr Cove NV
    O I left my air ride. But yes, you can delete it and put a cup holder there or something. or like I did, I deleted my cup holder and in its place I put more buttons to control my exhaust cutouts. The slot there can be filled with any buttons for the most part...
    06 Cayenne TT
    07 S6 Thread
    SOLD 14 JHM Q7
    SOLD 04 D3L
    SOLD 02 ar Thread
    Sep 11 2009
    NE
    I went with passive wastegate activated cutouts on my set up, much more reliable set up vs electrics which fail due to heat and water fairly quick.
    Jan 04 2013
    Zephyr Cove NV
    Quote Originally Posted by julex View Post
    Yes that is the much better way to do it. Live and learn. I went with the DMH brand and have had to rebuild them 4 times. But they are solid after rebuild. I also keep them lubricated with pb blaster. Have had them for 2 years now. I learned the trick is to not use them too much either haha. I moved them behind the rear resonator so they no longer get the extreme abuse of the hot downpipe exhaust and they have more reliable.
    I rarely use them unless I am blasting the car. If I were to do it again I would do vacuum activated like you
    06 Cayenne TT
    07 S6 Thread
    SOLD 14 JHM Q7
    SOLD 04 D3L
    SOLD 02 ar Thread
    Aug 04 2009
    Glen Ellyn, IL
    Get facelift C5 button panel, for cars without power rear sunshade there will be two convenient blanks. I think the ESP button might be a different shape between A6 and allroad due to suspension controls being wider than the two A6 blanks. But I don't know that for fact.
    OEM+ work in progress allroad
    Unicorn Society member #8
    @fourings | Build
    Jan 04 2013
    Zephyr Cove NV
    They very much are. I will take a picture of my setup and post it later
    06 Cayenne TT
    07 S6 Thread
    SOLD 14 JHM Q7
    SOLD 04 D3L
    SOLD 02 ar Thread
    Aug 04 2009
    Glen Ellyn, IL
    Allroad ESP switch is more narrow?
    @fourings | Build
    Jan 04 2013
    Zephyr Cove NV
    Yea. Also you need the soft touch buttons from like a late gen c5 so they look right
    06 Cayenne TT
    07 S6 Thread
    SOLD 14 JHM Q7
    SOLD 04 D3L
    SOLD 02 ar Thread
    Aug 04 2009
    Glen Ellyn, IL
    Thanks for the verification!
    Pre-facelift (non soft touch) didn't even have ESP switch, right? Just coin tray, or coin tray is where facelift cup holder is and cupholder in place of button array, yes?
    @fourings | Build
    Jan 04 2013
    Zephyr Cove NV
    I can not verify that. I know on my 99 c5 2.8 it had credit card slot and it had cup holder. I think the 4.2 had esp however and maybe 2.7 also
    06 Cayenne TT
    07 S6 Thread
    SOLD 14 JHM Q7
    SOLD 04 D3L
    SOLD 02 ar Thread
    Jun 04 2013
    SE MI
    Quote Originally Posted by LakeTahoeQuattr View Post
    care to post a pic and some details? even tho its not the air ride
    Sep 16 2010
    Central Wash
    C6 ESP switch (same exact electrical connection) relocated to center console. I just extended the wires- then added 2nd cupholder where this was.
    Jun 04 2013
    SE MI
    holy shit thats awesome!
    after you moved it, did cupholder fit right in?
    are those navi buttons functional?
    Jan 04 2013
    Zephyr Cove NV
    Here is what I did. Right cup holder was deleted. I added the 4.2 soft touch buttons on that side. The ESP button on the right activates my cutouts with a single push. I have a forum diy on this btw. The window visor button "seals" the cutouts more closed if they ever rattle with a special circuit I built also.
    Blank button will be used eventually. Eventually I want to get the buttons replaced with ones that represent the function but they are 35 euros each from the company who makes them...
    06 Cayenne TT
    07 S6 Thread
    SOLD 14 JHM Q7
    SOLD 04 D3L
    SOLD 02 ar Thread
    Sep 16 2010
    Central Wash
    Quote Originally Posted by alien_brain View Post
    Yes-- dash is symmetrical so cupholder fit both sides easy! And yeah..that bottom part of the NAGrivation controller was just a blank spot so I trimmed it to fit the C6 ESP button. Extended the wires and shazam. Boom! OR whatever... NAV is functional. It is very helpful at pointing you to an area roughly near a destination if you need to get there in 2003.
    On non-Allroads that left side console button thing is a waste of space. What do you have? ESP and on a deluxe car a rear-sunshade button? Lame.
    Jun 04 2013
    SE MI
    who is that?
    Aug 04 2009
    Glen Ellyn, IL
    Thats rad tahoe. I also hate button blanks, makes you feel like your car isn't as good as it could be. Had an A6 S-line with everything and it KILLED me that the furthest right button on the left side was blank. Loved the rear sunshade though, so cool.
    Fun fact: Volvo's button blanks can actually be pressed. Like they're not solid immovable slabs, they're spring loaded just like real buttons. I adore that totally useless fact.
    @fourings | Build
    Established Member Two Rings Clockwerks's Avatar
    Jul 19 2013
    the impending feeling of doom with 4 C5 audis
    Parker CO USA
    My furthest right button is also nonfunctional, but it has been replaced with a working button that says "funk" on it.... Apparently it was used to disable radios or something. I have not wired it to anything yet but the possibilities are endless. I think ecs sells them.
    4 Ducatis..Streetfighter V4s, Supersport S, Hyper SP, Monster evo
    18 Ariel Nomad
    16 Aston Martin V8 Vantage, blue, manual
    07 Porsche 911 Targa 4s, manual
    07 S4 Avant, 6 speed, sprint blue, supercharger, silver, rotors
    05 allroad 6 speed, blue, color matched, S5 wheels and spacers, Justin hitch...
    04 2.7 A6 6 speed with GT28RS Turbos, water/meth injection, RS6 body
    03 RS6 Blue/silver, 6 speed
    02 S6 Avant, polar white, RS6 wheels
