Results 1 to 9 of 9
    Veteran Member Four Rings nynoah's Avatar
    Jan 16 2006
    01.5 A4 avant Past cars: 95 S6, 85 Golf II VR6, 2 sciroccos, 92 Corrado VR6, 86 Euro BMW 535 Alpina
    LA CA
    Awesome FIS screen computer interface
    Check this product out. I have seen something like this in the past. But I really like this version.
    The FIS-Control allows to access a wide range of measurement values and status information of vehicles of the VAG brands (Audi, Volkswagen, Seat, Skoda). The data is shown in real-time on the display of the instrument cluster. The system is controlled by the buttons of the wiper stalk. This way the FIS-Control integrates seamlessly into the car and can be installed perfectly invisible.
    The focus of development was the fast and accurate monitoring of relevant data, especially of tuned cars: e.g. boost, oil temperature, air-fuel-ratio, exhaust gas temperature.
    Many measurement values are already acquired by the stock control units and can be read out by the FIS-Control. Furthermore the FIS-Control has inputs for directly connecting additional sensors.
    http://www.fis-control.de/index_en.html
    2001.5 black on black avant 5spd, EFR 6758, Pag Parts band manifold, Vibrant GESI High flow CAT, 2.0L 06A, IE intake manifold, built AEB head, 1000cc Boosted Euro Tune, bosch 044, Ringer Racing stage 3 hybrid Organic/Cerametalic 240mm clutch, S4 interior upgrade, full S4 brakes front and rear with lines, 17in OZ Racing Ultraleggera, 034 HD suspension arms, Stern soft mounts, mirimoto bixenon etc. http://www.audizine.com/forum/showth...s-Build-thread
    Veteran Member Four Rings zillarob's Avatar
    Nov 16 2010
    2kS4, 84gli, 84caddy dsl
    WetSide, WA
    Snake ftmfw!!
    That has been around for a long time. It is still around so prob legit.
    There are only 2 things needed to make an Audi work properly - Duct tape and WD40. If it moves and it shouldn't - Duct tape. If it doesn’t move and it should - WD40.
    Jan 16 2006
    LA CA
    There was a guy who was making something like this in the US. Last I saw one was like 4 years ago. Do you know if the US company is still around and who it was?
    Established Member Two Rings czum09's Avatar
    Nov 02 2010
    1999 Audi A4
    Cedar Rapids, Iowa
    Really not even a bad price. I may have to try it out. I saw this about 6 months ago.
    Veteran Member Four Rings A1 A2 German's Avatar
    Feb 28 2005
    Audi A4 B5, Audi Fox, Audi AMLS TT, GS450, CB175, CL175
    Tempe
    Complete garbage.
    I've been trying to install this along with the 034 rear stabilizer brace on my '97 FT for 3 years, no luck.
    Aug 30 2014
    United States
    Quote Originally Posted by A1 A2 German View Post
    Complete garbage.
    really? I'm sure that's just your isolated case....I can't see that the software even is supported for the 97 cluster. Did you get an updated cluster? I'm sure its more complicated than that. Any luck in the forums from the original developer?
    Feb 28 2005
    Tempe
    Quote Originally Posted by Articus View Post
    '97's do not have lcd screens (nor do Front Tracks take rear stabilizer braces).
    Man! I've hacked 3 engine harnesses and 2 main harnesses, 115hrs of labor, and on my cluster I can't see squat!
    Nov 03 2011
    All Over!
    My '95 B5 had LCD. Very few early Euro V6 models could be found WITHOUT. It became an option around '98 on base 1.6 / 1.8 models.
    1986 Type 85 Audi 90 quattro
    Apr 22 2007
    Riverbank, Ca
    I've thought about this for my project but I am using a tablet for media and connecting to the computer to use Dash Command or Torque. If I wasnt doing that I would probably use it.
    73 914 1.8T AEB + FWD 016 trans
    AWM Wiring harness, Comp Turbo CTB5356, ABS, ESP, Custom interior, Flares, Brakes, Custom everything :) Build below
    Budget Outlaws Youtube
    http://www.914world.com/bbs2/index.php?showtopic=114780
