Results 1 to 14 of 14
    Veteran Member Four Rings Gberg888's Avatar
    Jun 16 2011
    996tt
    MA
    Failed MA Inspection - all codes passing
    Thoughts?
    I have a UM tune, ko4, nothing should have been deleted or hard passed by the software, and still got flagged, now I am preparing my ass for a beating by the state because MA inspections suck!
    Veteran Member Four Rings AudiTechS4's Avatar
    Oct 19 2007
    2000 S4
    Scottsdale , Az
    do they dyno test ?
    2001 Audi S4 Manual - Nogaro Blue/black - Full AWE stg 3 kit w/ manifolds,h&r coilovers,jhm trans rebuild,UUC VM3 exhaust , 2.5" dp's - Needs Love - Got some love now 442awhp and 512 awtq
    2004 Audi S4 Avant manual - Silver/black - 2.7 swapped ,k24's and srm side mounts
    Veteran Member Four Rings DiertyEuroSpec's Avatar
    Aug 21 2009
    Fairfield County, CT
    State inapections doing dyno testing. Wow never heard of that one before. They should of gave you a printout of why you failed.
    Sent from my LGL33L using Tapatalk
    2003 A4 1.8T Quattro | 18" BBS CH | KW V3 | FT F21 Mixed Flow | MOTOZA | RA4 Stage 1 w/SMFW | Milltek | Uni HFC/3'' DP Combo | 3'' TIP w/MAF | 550cc | TR1.8 FMIC | USP F/R | H-Sport F/R Sway | APR Snub | RS4 Motor Mounts | Stern Trans Mount | Skid Plate | Solid Tie Rod Ends | Short Shifter | Euro Shift Knob | VMR Boost Gauge | S4 F/R Brakes | Tyrolsport Stiffening Kit | ECS S.S. Lines | Hawk HPS Pads | 034 PCV
    Jun 30 2008
    Erie, Pennsylvania
    Quote Originally Posted by Gberg888 View Post
    So, like cocoa butter or...?
    Veteran Member Three Rings agart's Avatar
    Mar 20 2008
    Belmont MA
    What did you fail for?
    DG '02 A4 1.8TQM
    My Build Thread
    Jun 16 2011
    996tt
    MA
    It just failed me because my computer has been tampered with. Its an auto fail even though every single system is functioning properly on the car.
    I called UM, they will retune my car with no systems set to automatically pass which I believe is why I failed.
    Dec 28 2006
    '13 A5, '24 Tiguan SEL R-Line
    Western Maryland
    You can thank VW for this one.
    More and more States are changing how they check for emissions readiness. Instead of just checking readiness they are also resetting the readiness codes. Anything that has been written out will still show as ready even after the reset. For example, if you have a test pipe with the catalytic converter written out the cat will still show as passing even after the reset. Consequently you will fail the test.
    Mar 20 2008
    Belmont MA
    Ding ding ding. If you have all systems installed on the car as they should be and UM can retune to remove the forced passes, you will be fine. I've had to go through the MAC, it's not that bad. As long as your ECU gives them the answers they want, they'll let you pass.
    DG '02 A4 1.8TQM
    My Build Thread
    Jun 16 2011
    996tt
    MA
    Good to know. I am getting reflashed early next week by UM. I know all the systems are working on the car and are probably just coded to auto-pass. We will see.
    Thanks Agart.
    Aug 30 2013
    Rockville, MD
    hey old guy, do you know if md is doing this yet? If so, might be something I want to take care of now
    Dec 28 2006
    Western Maryland
    Quote Originally Posted by hgtuner08 View Post
    As far as I know, not yet. I had to go in for emissions the first week of December and passed. I am running an 034 HFC but I had it written out since the 034 cat can be hit or miss with a P0420.
    Veteran Member Three Rings VAGlover's Avatar
    Sep 23 2013
    b6 a4 track rat
    boston
    Massachusetts has been doing this for a few years. RI hasn't changed it yet, so for now thats the reaason my car's registered to my parents home address.
    Like Old Guy said, the computer can see if readiness codes have been disabled or written out. Times are a changin' unfortunately, but I've still got my test pipe in haha.
    Jun 16 2011
    996tt
    MA
    Im going to see if the retune and the o2 spacer I have will get me through emissions. If not, I may need to put a HFC in the car. Between an hfc and the o2 spacer I shouldnt have any issues.
    Mar 20 2008
    Belmont MA
    Just sent you a PM, did not realize you are catless.
    DG '02 A4 1.8TQM
    My Build Thread
