Results 1 to 6 of 6
    Dec 23 2012
    New York
    any way to get the car to turn off if it doesn't sense the key?
    Hi. I have the push button start. is there any config (e.g. VCDS) option to get the engine to shut off if i forget to push the engine stop button then walk away with the key in my pocket?
    Aug 06 2012
    san diego
    how does someone forget to turn off the car?
    is anyway we can vcds into your brain and rewire it so that you dont forget to turn the engine off
    Established Member Two Rings Benji00's Avatar
    Nov 26 2014
    Richmond, VA
    This is just one of those things in life that you need to remember to do.
    Aug 06 2012
    san diego
    forgot to turn off the car.
    forgot to close the door.
    forgot to flush the toliet.
    forgot to wipe butt after taking a
    there are just some things vcds can't help you with.
    not to mention how dangerous it would be if the car just shut off when the key is not recognized
    Jun 09 2015
    North Palm Beach, FL
    I'm kind of curious too. Other than a symbol on the dash, does anything happen when the key is removed from the car while it is running?
    Veteran Member Three Rings deadbolt's Avatar
    Aug 29 2014
    NY/LA
    No nothing will happen.
    Stage 2+ 2015 Audi A3 2.0T Prestige
    My Build Thread
    @EUROGRADE_
