Results 1 to 24 of 24
    native launch control on DBC ecus, aeb/aha. proof of concept.
    this is not a 2step. so no pop pop, flames, scene points, or panties instantly dropping. sorry about that.
    it is a native soft launch limiter enabled on an ecu with no type of limiter currently available.
    yes, this is a mk3 obd2 vr but the same patch can be applied to any DBC obd2 ecu. aeb, aha, aeg, etc.
    merry christmas.
    https://youtu.be/v5xhAmNKUZ4
    contact via email please.
    Senior Member Three Rings bmos's Avatar
    Apr 29 2014
    1973 BMW 3.0S Bavaria
    Maine
    Neat! Awesome to see new functionality for our stock ECUs.
    Jan 22 2014
    Fairfield, Ca
    Any chance you could change the set point for this (driver chooses depending on conditions)? I'm sure that's complicated, but launching in the street is different than a sticky drag strip.
    2005.5 A4 Avant; TSI cam follower conversion. Build Thread
    99.5 1.8TQM; Maestro, GTX2867R, and a ton more mods. RIP
    Build Thread
    would not be able to be changed on the fly. it is a hard coded limiter.
    Established Member Two Rings cclarkb5's Avatar
    Feb 02 2015
    1991 Audi 90 20v
    Bellingham, Washington
    One please
    They last long if you treat them any better than totally shitty. | 1999.5 2.8QA Volcano Black Mica | 1991 90 20vQM Pearl White |
    Dec 09 2015
    neither here nor there
    Has anyone here tried to launch a 1.8t at 3,000 rpm's?
    What happened
    Did you win the race?
    Veteran Member Four Rings vrmm's Avatar
    Nov 14 2011
    NW
    Your car will bog and probably want to die..
    Granted I have a significantly larger turbo than stock and launch at 6-7k, 3k even with a k03 will just not work. iirc I tried back in the day at 4k and it wouldn't work. A stock clutch won't enjoy it either.
    Dec 09 2015
    Quote Originally Posted by vrmm View Post
    That is exactly what I was getting at. This mod is absolutely 100% useless and counter productive, so I don't get why some people are in awe over this.
    Sep 01 2011
    Louisville Kentucky
    Bc people have turbos on their AEBs other than k03s.... and because previously it was an absolute that DBC couldn't have launch control like this... Sure the applicable market is slim, but then the number of folks modding B5 audi's is pretty slim compared to all the b5s sold... But folks still design stuff for them, some folks still race them... Lastly... Because it can be done.
    Oozed from a pustule of thought somewhere within the recesses of my mind...
    Veteran Member Three Rings Rodgman15's Avatar
    Jan 12 2014
    Fargo, ND
    Quote Originally Posted by Kronprinz View Post
    Because Kompressed tunes are dirt cheap, highly efficient, and lots of people run them. I'm sure he can just add it on to any ecu he's programming along with all the other additional features he adds (or codes out ). Are you able to set the rev limit when you order the ecu is my question, or is 3k the only option available? Even with this option it's still probably cheaper than any ots tune.
    the limiter could be set to 10k if you wanted it that high. it was only a proof of concept. its the holidays people. lighten up a bit.
    Veteran Member Four Rings nynoah's Avatar
    Jan 16 2006
    01.5 A4 avant Past cars: 95 S6, 85 Golf II VR6, 2 sciroccos, 92 Corrado VR6, 86 Euro BMW 535 Alpina
    LA CA
    K0mpresed is a great guy to deal with :)
    2001.5 black on black avant 5spd, EFR 6758, Pag Parts band manifold, Vibrant GESI High flow CAT, 2.0L 06A, IE intake manifold, built AEB head, 1000cc Boosted Euro Tune, bosch 044, Ringer Racing stage 3 hybrid Organic/Cerametalic 240mm clutch, S4 interior upgrade, full S4 brakes front and rear with lines, 17in OZ Racing Ultraleggera, 034 HD suspension arms, Stern soft mounts, mirimoto bixenon etc. http://www.audizine.com/forum/showth...s-Build-thread
    Dec 09 2015
    Quote Originally Posted by k0mpresd View Post
    So people would need to practice launching to see what RPM is the best for their application, then they tell you what RPM to code into the ECU NICE
    not sure if sarcasm or not. must have been lost in translation.
    im going to assume you see that as a positive.
    but hey, if you dont like someone still trying to develop for that dinosaur of an ecu, then im happy to give up as well and move to bigger and better.
    Dec 09 2015
    hey, if you dont like someone still trying to develop for that dinosaur of an ecu, then im happy to give up as well and move to bigger and better as well.
    If aimed at me, no sarcasm at all.
    It's good to see no one has given up on the dinosaur b5 platform
    these olders are a bit more of a challenge but the challenge is what makes it fun.
    Dec 09 2015
    To challenge yourself, is to better yourself.-Some one once said lol
    Registered User Four Rings
    Feb 08 2011
    B5 A4 2 liter HTA3586r
    Phoenix, Arizona area
    How would they do that because launching on a rev limiter (2 step) is completely different then launching without one, a rev limiter for launching is best used for a FWD car seeing it limits wheel spin when on a AWD turbo car you want some wheel spin to keep the car from bogging if the tires get full traction before the car is moving. Fact is that our AWD turbo cars need the RPM rising at a fast rate to get the best launch.
    except this isnt a 2step limiter, as stated originally.
    Dec 09 2015
    How does the 2 step differ from this native launch control? How does this native launch control cut? Does it retard timing, cut fuel, cut ignition, or a combination of the said?
    2step retards ignition. this is a fuel cut. no load produced.
    Veteran Member Four Rings BaseDrifter's Avatar
    May 18 2010
    Nice work! I was considering getting a new tune from you anyways..hmm.
    | Update thread / Youtube Channel |
    97 A4 1.8TQM: Frankenturbo|TyrolSport SMIC|034 HFC|Borla catback|Carbonio/007 DV|Vogtland GT3|034 RSB|Apikol Bushings|034 SD motor/tranny/strut mounts|A8 brakes/SS lines|JHM trio|Meyle HD CA/TREs|
    01 S4 2.7T: Stock
    Feb 08 2011
    Is it cutting fuel from all cylinders or a few at a time? WOTbox holds the rpm by cutting spark which is why it doesn't really produce much boost.
    Jan 21 2008
    Tucson
    Thanks for continuing development on the narrow band DBC Motronic system. I've read nothing but rave reviews on k0mpresd tunes. I like the emissions delete you offer as well. Presently running APR but sitting on a brand new, BW K04.
