Results 1 to 8 of 8
    Veteran Member Three Rings IHave2Turbos's Avatar
    Aug 17 2015
    MMI 3G (Concert) Secret Menu Possible?
    2010 Premium with Audi Concert, no nav. I have attempted to enable the secret menu and get the error message to the effect of "Module Missing". Based on the information I have found, it is not possible to enable the Secret (Green) menu in the MMI 3G (Basic/Low) not even sure what it is technically called.
    Is it possible to install whatever "module" is missing or do I need to do a full MMI 3G High upgrade? Very confusing with the nomenclature for all of these various systems.
    Veteran Member Four Rings jmeenach's Avatar
    Mar 17 2014
    Los Angeles, CA
    I am also curious. Please HALP.
    Pedal Responce Team's expedition ace/Banana Responce Team first responder
    2013 B8.5 A4 Quattro. RS grille / 20" 'Flower Petal' reps / AFE / VCDS mods / more to come...
    instagram
    Sep 02 2015
    Edmonton
    If you have no NAV, you do not have MMI, hence no hidden menu.
    Veteran Member Four Rings booost's Avatar
    Jul 17 2008
    '12 VW Beetle Turbo DSG, a boat
    Not possible on that unit but you can do many of the hidden menu commands with VCDS.
    Sent from my iPhone 6s+ using Tapatalk
    Click: B8 Quartz Grey Metallic A4 2.0T quattro | 18" Peelers et35| APR stage 1 | aFe | eurocode | H&R | 3.0 TDI FMIC | PowerStop | PODI
    Sold: B5 Silver A4 1.8T Quattro 5MT GIAC KO4 | B5 Santorin Blue A4 2.8 Quattro 5MT | B6 Caribic Blue A4 3.0 cabrio
    Sep 09 2010
    Destin, FL
    Aug 17 2015
    Yeah I had luck using Carista to code a few options. I guess I was confused about the naming of the various systems. So do I have MMI 3G Basic/Low or No MMI at all since i just have a screen and the Concert Head Unit?
    Sep 09 2010
    Destin, FL
    Quote Originally Posted by IHave2Turbos View Post
    Do you have the radio controls next to the shifter and cup holders or no?
    Non MMI
    MMI
    Aug 17 2015
    Gotcha, Non-MMI.
    C7.5 S6
    Mods : OEM+ Stage3 / DS1 ECU / SRM TCU / CTS HX
    B8 A4
    Mods : HPA\\\ K04 / Manifold / HFC / Tune | CTS FMIC / DP | CR-15 | ECS Inserts
    Retrofits: MMI3G+ / RVC / AHH / Color DIS / Cruise Stalks
