Results 1 to 9 of 9
    Veteran Member Four Rings V1nny's Avatar
    Dec 04 2012
    Arlington VA
    log and advice about Stage 3 2.7t misfires
    got my car back after more than 2 weeks in the shop, and my misfires were not fixed, CEL come back later same day.
    Car is 01 allroad with manual transmission, basic stage 3 (was working fine for couple years before misfires started), and bunch of other mods including
    3" downipes, magnaflow, cat-back and SAI/EGT/rear O2 coded out.
    I have no idea what else to do to fix the misfires as everything possibly related was replaced including
    MAF,
    spark plugs (4 times, all kinds of gaps and different plugs)
    injectors (Bosch green giants, not green tops, green giants)
    ignition coils (replaced twice all of them, currently R8 red coils)
    replaced ECU, same stage 3 flash by Josh from Solo motorsports, believe it was totally unnecessary, shop's idea..
    All cylinders compression seems to be good, was checked 3 times by different shops in the last 4 months
    One option I am looking at, is to find low mileage engine, and transfer my K04 turbos on it. Or maybe there is still a chance to fix the misfires? Any ideas?
    Here is what I have either before or after latest "repairs":
    Saturday,12,December,2015
    VCDS Version: 12.10.3
    Address 01: Engine Labels: 078-907-551-AZA.lbl
    Control Module Part Number: 8D0 907 551 M
    Component and/or Version: 2.7l V6/5VT G 0002
    Software Coding: 06711
    Work Shop Code: WSC 87119
    6 Faults Found
    17965 - Charge Pressure Control
    P1557 - 35-00 - Positive Deviation
    16684 - Random/Multiple Cylinder Misfire Detected
    P0300 - 35-00 -
    16688 - Cylinder 4
    P0304 - 35-00 - Misfire Detected
    16690 - Cylinder 6
    P0306 - 35-00 - Misfire Detected
    16689 - Cylinder 5
    P0305 - 35-00 - Misfire Detected
    16686 - Cylinder 2
    P0302 - 35-00 - Misfire Detected
    Readiness: 0000 0000
    log is uploaded here: http://s000.tinyupload.com/?file_id=...27199086431251
    I am willing to pay in cash or parts (have a bunch of goof parts that I replaced for no reason), or beer, etc., if someone locally in Washington DC area, or remotely could help me to figure this out.
    Veteran Member Four Rings LakeTahoeQuattr's Avatar
    Jan 04 2013
    '07 JHM S6, '21 TTRS, '06 CTT, '20 Supra GR
    Zephyr Cove NV
    Oh yes the wonderful P1557. I hate boost leaks so much.
    When are you misfiring. Under WOT, idle, or just cruising?
    21 TTRS - track whip 1
    20 Supra GR - track whip 2
    06 Cayenne TT
    07 S6 Thread
    SOLD 14 JHM Q7
    SOLD 04 D3L
    SOLD 02 ar Thread
    Dec 04 2012
    Arlington VA
    Quote Originally Posted by LakeTahoeQuattr View Post
    according to logs misfires are under light loads too, though more at WOT. I spend over $1800 in labor over last 3-4 months, taking car to 3 different shops to do smoke tests and fix boost leaks, pretty desperate now.
    Oct 13 2015
    Omaha, NE
    If i was close I'd come drink a few beers with you and offer you the same advice everyone else probably has lol
    Jan 04 2013
    Zephyr Cove NV
    I'm wondering if it not getting proper fueling. I know super rich causes misfires at wot. I am not knowledgeable enough to help here as I would suggest checking the things you already did. Ugh frustrating. I'll keep it on the back of my mind for you. Your sure your tune is good to go? Could your fpr be shot?
    06 Cayenne TT
    07 S6 Thread
    SOLD 14 JHM Q7
    SOLD 04 D3L
    SOLD 02 ar Thread
    Dec 04 2012
    Arlington VA
    ordered both FPR and N75 on Wednesday, they sroud be delivered tomorrow. It would be pretty hard to blame tune, as I got this tune early 2013 and put almost 25K on stage 3 before misfire started after bunch of upgrades such as coilpack conversions and SAI delete. I spoke to Josh, guy who did my tune couple of weeks ago, and he sent me another ECU with the same file, but ECU did not make any difference. I just made another log, concentration on fueling, will upload in a minute.
    here is the new log, more fueling data:
    http://s000.tinyupload.com/?file_id=...60146988833789
    Veteran Member Three Rings a4kamila6's Avatar
    Sep 30 2015
    You are on right path. Change n75 and fpr. The first code you get tells you that you have boost leak like tahoe stated. Smoke test didnt reveal anything?
    Dec 04 2012
    Arlington VA
    Quote Originally Posted by a4kamila6 View Post
    last one was good, no visible smoke anywhere, but when i push hard, still hear some swooshing sounds. Not sure what they are, or where they coming from. I don't think smoke machine creates enough pressure to match my 22-23 psi of boost. So maybe it holds to the certain pressure, then starts leaking. I will try to remember to blow into wastegate line tomorrow when old N75 is out, maybe that's where the leak is.
    Dec 10 2011
    991 C2S, Stage 3 S4, E46 M3
    CLT | MKE
    Can you just log a single gear pull? Third seems to be what most use for this. Start the log, then go WOT from 2000rpm or thereabouts.
    That way we can see how bad your leak is and if anything else looks funky.
    -Hayden
    B9 Q5 | Brilliant Black
    E46 M3 Cab | Steel Grey
