Results 1 to 20 of 20
    Veteran Member Four Rings Jet Jockey's Avatar
    Jun 17 2004
    2017 B9 A4 Quattro/DSG/Technik/S-Line... 2004 B6 A4 1.8T Quattro race car
    Montreal, Canada.
    Installing the fender flares...
    Straight on shot with a set of knock off RS4 Audi wheels which I think are 8 inches wide (Mike's ex-wheels). Notice also the fenders have a lip and also have an inner part to them.
    Here on this side shot you can see the down wards lip about 1.25 inche and you can also see better the inner portion parts of the fender. You can also tell that the mag/wheel combo is really inside the fenders and that they fit within the flares.
    However with the 18 inch x 10 inch with an ET of 6mm with the Michelin race tires it doesn't work out and that combo will fit tightly if the car is on jacks and the wheels are unsprung but not once lowered. So some heavy modifications to the flares was required. The lip had to be shaved down to less than a quarter inch and inner parts all removed for the big wheels to fit. There is still some bodywork to be done to have the fenders fit nicely onto the car but we think the end result although not perfect is much better than the alternative. I think the front flares could have been done better but the rear seems really good.
    Veteran Member Three Rings lyates1987's Avatar
    Sep 17 2014
    Lakeway
    Do you have a pic of the entire car with those on? Curious what it looks like from a not up close perspective.
    Veteran Member Three Rings USAF Long's Avatar
    Nov 05 2010
    Salt Lake City, UT
    Interested to see when they are painted.
    - Scott Long -
    2002 Audi A4 1.8t Quattro - 5-sp | 3M Wrapped | Test pipe | Custom Exhaust | Tint | 19" Staggered Wheels |
    Veteran Member Four Rings jayiszraw's Avatar
    Aug 03 2009
    swfl
    Quote Originally Posted by lyates1987 View Post
    X2 also where did you order id like to take a shot at modifying a set
    2.7 swap in progress
    Apr 01 2011
    B5 on jack stands
    charlotte
    Wow.....that's a lot of flare.
    powered by
    Hot Boi parts
    Veteran Member Four Rings Bische's Avatar
    Jun 03 2009
    2002 Big Block Avant
    Sweden, north
    Jet Jockey ftw
    Jun 27 2011
    Quote Originally Posted by jayiszraw View Post
    Eww. Only on a purpose built race car like Jet Jockeys. Please.
    -CP
    2008 2.0t S-Line Ti 6MT Avant
    2017 Q7 3.0t
    Former USP CLUB MEMBER #136
    Aug 03 2009
    swfl
    Thanks for your opinion.
    Jun 27 2011
    You're welcome.
    -CP
    2017 Q7 3.0t
    Jun 17 2004
    Montreal, Canada.
    Front View
    Dec 10 2011
    991 C2S, Stage 3 S4, E46 M3
    CLT | MKE
    Thank God it's a racecar.
    -Hayden
    B9 Q5 | Brilliant Black
    E46 M3 Cab | Steel Grey
    Dec 05 2007
    You should see some of his videos. He's also an instructor.
    Mar 02 2015
    miami
    not bad. I've seen another car with flare on ig and it didn't look bad at all. they weren't as extreme tho. this is Ginna e cool
    Veteran Member Four Rings ZipMeUpJ's Avatar
    Nov 12 2012
    hologram R8
    boston
    I still wish we had a rocket bunny kit for these.
    Senior Member Three Rings B6ayfour's Avatar
    Jun 21 2015
    2014 S4 6MT, 1989 535i5
    LI, NY
    looks cool, i really want to see what it looks like with everything painted.
    Active Member Four Rings alien_brain's Avatar
    Jun 04 2013
    SE MI
    will you make fiberglass or carbon panels?
    Veteran Member Four Rings heywier427's Avatar
    Jan 08 2010
    - Dolphin '02 A4 1.8tQ, 91 Q45, 02 caddy ext, 85 datsun 720, 71 datsun 510, 08 Ducati 848, Mk1 TD
    CT Shoreline
    im still waiting to see someone do allroad flares.
    Paint em black.
    Apr 01 2007
    1983 Chevy Silverado
    houston texas
    vorsprung durch technik
    2019 SQ5 Prestige
    Aug 17 2015
    Modded 06 Maxima, 02 Civix EX
    Stockbridge, Ga
    I'm looking for a similar set of flares. Do you mind me asking where you got them from?
