Results 1 to 26 of 26
    Jan 22 2015
    ‘13 TTRS
    Massachusetts
    High Mileage S6/7 Owners
    I am trying to decide between an C7 A6 3.0T or S6. I plan on keeping the car for ~5 years but I put about 30,000 miles on it annually. I was leaning toward the A6 for "lower" maintenance costs but after test driving them both today the S6 just felt so much better. My wife has a '13 Audi S4 6MT and that thing pulls so hard so I figured the 3.0T wouldn't be that far off from the S6. Boy was I wrong!! As many of you already know there is a very noticeable difference. But I digress..
    Has anyone put a significant amount of mileage on their S6/7 since purchase? If so, has there been any major issues with the higher mileage examples?
    Veteran Member Three Rings redrocker55's Avatar
    Feb 21 2010
    St Louis, MO (USA)
    Not to one up you on miles per year but I run in the 35-40,000 miles per year range. I went through this same consideration when I was deciding between a 2010 S-line 2.0 A4 and the 3.0 TFSI S4.
    I thought about extra maintenance, etc. I owned that car to nearly 150,000 miles. I could not be happier w/ the decision to go with the S4. The transformation if the drive/ experience is similar to the difference between the A6 to the S6. From a reliability and cost perspective I would say it was minimal. My S4 was bullet proof. No out of pocket repairs at all. Only basic maintenance. Heck..the car was still on the original battery and it was turning over he engine strong.
    So when I went shopping for a slightly larger vehicle I really only considered the S6. I did think about the TDI due to my huge amount of highway miles...but in the end...the roar is ability of the 4.0 TFSI in the S6 was something I just could not pass up. I am not in the camp that big HP V8 engines will be around much longer...so I wanted to get my hands on one of the best V8's ever produced so I could enjoy the thrill of that engine. The other consideration is the DSG in the S6. I am addicted to direct shift gearboxes. This is my 3rd one...all VAG units. All have been bulletproof. Hope this helps even though it does not directly answer your question.
    2016 S6 Prestige, Misano Red Pearl, Driver Assist, B and O, Sport Pkg, Carbon Atlas, Black Headliner,
    Alu Kreuz, 034 Motor Sport DSG Insert, RS7 Intake Box, APR Stage 1 w/ Dongle
    Sold 2010 S4 Brilliant Red DSG with Prestige Pkg
    Sold 2008 VW GTI DSG
    Jan 22 2015
    ‘13 TTRS
    Massachusetts
    Thanks for the reply. Glad to hear that someone else went through a similar decision. Sounds like you don't regret it at all. On other note I see you chipped your S4... do you plan to chip the S6?
    Veteran Member Three Rings arrivalanche's Avatar
    Jun 08 2014
    Placentia, CA
    I have both and MAN, the gas milage is really bad on the S6 compared to the A6. I get around 8mpg with the A6 and around 18-22 with the A6. If your driving that much, dont even look at the S6.
    -AARON-
    2018 S4 Black Optic
    2017 S6 Black Optic - Sold
    2016 S6 Black Optic - Sold
    2014 A6 3.0T Black Optic - Sold
    2014 S4 3.0T Black Optic - Sold
    2012 A6 3.0T - Sold
    2008 A4 2.0T - Sold
    Established Member Two Rings AnTarbh's Avatar
    Oct 17 2015
    2008 Q7
    MN
    Quote Originally Posted by arrivalanche View Post
    Woah 8mpg. That is really bad for a car estimated at 18-22. That probably has to due with your driving style or something is wrong. My Q7 gets better mileage and I drive the piss out of it (pedal down 100% of time :))
    2016 S6 Goodwood Green Pearl
    2014 A6 3.0 TDI Prestige Phantom Black Pearl (SOLD)
    2008 Q7 3.6l Premium Lava Grey
    2006 A4 2.0T MT Brilliant Red (SOLD)
    Senior Member Three Rings hubris's Avatar
    Jul 07 2015
    Midwest
    Quote Originally Posted by AnTarbh View Post
    Gotta echo that! I do 25-27 MPG average on highway trips in my S6. Average over the last 20k miles = 21.5 MPG. So either arrivalanche's foot is glued to the floor when he drives or that thing is broken! Since he only gets 18-22 in the A6 I'm leaning toward the former...
    2014 S6 | Prestige | Ibis White | APR Stage 2 | Milltek Turbo-back Exhaust, Resonated, ValveSonic, High-Flow Cats | P3 Boost Gauge
    Established Member Two Rings cdubya19's Avatar
    Feb 24 2015
    Nor Cal
    Wow 8mpg. I used to have a C6 A6 got about 20-26mpg. Moved into a C7.5 S6 and getting about 14mpg mixed driving and closer to 20-22 when do more highway miles. 8mpg? Did you bypass cylinder deactivation and only shift at high rpm?
    Sorry OP. Don't do anywhere close in mileage. Can tell you the S6 air suspension is much more comfortable than A6 especially if you plan rack up the miles. I tested drove different setups on the A6, then a S6 back to back. Could definitely tell the difference. Would be interested to know if anyone will high mileage having issues with the air suspension especially since OP plans to rack up 150k.
    Sent from my SM-N920V using Tapatalk
    2016 S6 | Prestige | Glacier White | Sport Package | Driver Assist Package | Black Headliner | 20" Wheels | Carbon Inlays
    Oct 17 2015
    2008 Q7
    MN
    Also, my '14 A6 was a great car but the s6 was way more comfortable. I expect my comfort seats in the s6 to be even more comfortable than my test drives with diamond stitching.
    I hated that I couldn't adjust thigh padding in my A6 long drives (~4k miles) it didn't feel good. But it still felt better than my Q7.
    Veteran Member Four Rings S4Per's Avatar
    Feb 17 2004
    2013 Audi S6
    I thought I was going to do better in the S6 vs the SC'ed RS4. I use fuelly.com religiously, and had average MPG of 14.9 for the RS4 over a period of 2 years. For the S6, two months in, I'm closer to 13 than 14...and it's not all lead foot :/
    2013 Addict::S6 (Build) // UNITED MOTORSPORT by AMD STG III | Milltek DP's and Valvesonic exhaust | 200 CPSI custom cats | AWE intake | Arc's, Helix, Morel's for sound
    2018 Q7 3.0T Prestige | Glacier White Metallic | Titanium Black Optic | Adaptive chassis | Drivers Assistance | Tow | Cold Weather
    Never forgotten:
    2008 Addict::RS4 (Build)
    2002 S4 Stage 3 Tip
    Veteran Member Four Rings zcd2.7t's Avatar
    Jan 19 2010
    MI/CA
    One thing to consider is that the S6's air suspension may require maintenance as the miles pile up. Steel spring suspensions like the A6's have fewer parts to fail/wear out, and will be less expensive to repair/replace.
    The 3.0T is an awesome, super-responsive motor. The thermostat is extremely likely to fail or need replacement at some point (mine went at about 80K miles), and some have had motor-mount issues, but overall, it's a great powerplant.
    I don't know of any such issues with the 4.0T, but I also don't know of anyone who has high miles. It's only been available in the US since 2013, so that's not surprising.
    Regarding fuel mileage, I'm also a fuelly.com user, and my S6 is averaging 21.xx mpg so, far, identical to my S4's average over 90+K miles. To me, that's impressive given the 100+ extra HP and 500+ lbs more weight.
    2022 Tesla Model 3 Performance
    2023 Genesis GV60 Performance
    2015 Q5 TDi - Torque, baby!
    (Gone) 2013 S6, Glacier White over Black.
    (Gone, never forgotten) 2011 S4 Prestige S-tronic wSTaSIS stuff
    Jul 07 2015
    Midwest
    Quote Originally Posted by S4Per View Post
    Does that correlate with the MPG monitor in the car computer?
    Veteran Member Three Rings kouzman's Avatar
    Nov 03 2014
    15 Audi RS7, 14 Audi A4 2.0T
    new york
    WOW guys!
    I bought my rs7 back in January and I have put about 7.5K miles so far and that is a record for me and for all the cars I have owned! But it is not a dedicated daily driver also...
    2015 Porsche 911 Turbo S
    Jan 19 2010
    MI/CA
    Quote Originally Posted by hubris View Post
    Onboard computer has been ~10% optimistic on each of the 8 Audis we've owned...
    This can be adjusted with the VAG-COM tool if desired...
    Jul 07 2015
    Midwest
    Quote Originally Posted by zcd2.7t View Post
    What! I had no idea this occurred. Found an article from Car & Driver chronicling this process, and mentioning calibration: http://blog.caranddriver.com/why-you...how-to-fix-it/
    VAG-COM instrucitons from AW:
    Correct Fuel consumption in DIS (C7): (Revised)
    [17-Instruments]
    [Coding - 07] > [Adaptation - 10]
    Scroll down about 20 items in the drop down list until you see something like fuel consumption adaptation - change the value from 100 to higher or lower:
    Example - if your DIS is consistently off by 7% to your actual calculated mpg:
    You RAISE the number to the percentage if DIS is OVER reporting mpg (i.e. 107)
    You LOWER the number to the percentage if DIS is UNDER reporting mpg (i.e. 93)
    Jan 19 2010
    MI/CA
    What! I had no idea this occurred....VAG-COM instrucitons from AW:
    Those instructions are also available on AZ, in multiple locations. Here's one:
    http://www.audizine.com/forum/showth...-complete-list
    There's even a similar list on THIS forum, but it's not a "sticky", for some reason.
    Jun 08 2014
    Placentia, CA
    My biggest problem is I live in LA where my average speed is like 11mph. I brought this up to another member with an RS7 and she is getting around the same. I assumed it was more than just the traffic.
    Veteran Member Four Rings sciblades's Avatar
    Mar 20 2009
    North Salem/Palm Beach
    my tuned s6 had 58k when i traded it in and and that was over 37 months of ownership, it had many drag strip runs and over 375 launches. Never had any issues that only time anything went wrong with the car was a cam adjuster went bad, but that is because i was revving it when it was cold (started up in a parking garage) so that one was my fault but audi replaced it under warranty and it was good to go.
    If you want long term reliability i think the s6 is a very solid option, but that said the 3.0t engine is also a very solid platform. I for one am not a fan of the transmission that comes in the standard a6 and that is my biggest quam because the a6 with a pulley and tune is not that bad a stage II 3.0t has about the same power as the stock s6 but the transmission will never allow it to feel the s6.
    I would suggest if you are going to put that many much mileage on the car to pick up a cpo s6 or s7 that way you have a 100k warranty and don't have to worry about the premium for a new car there are some pretty nice pre facelift cars out there that are under 15k mileage and ripe for the taking.
    2016 RS7 Stinger VIP laser and radar, Unitronic Stage1+
    Gone
    2013 C7 S6- v1 and LI- Unitronic tuned]
    B8 S4
    06 a3 Full Votex Kit, Unitronic III, apr tbe, precision 750 FMIC, apr HPFP forge dvi, EVOMS cai, BSH gt3076r turbo kit, IE rods, sb stage IV, LSD, on meth
    Feb 17 2004
    2013 Audi S6
    I think you're on to something with the traffic piece...it may actually be just that (hearing other's inputs seems to support that). I've been spending quite some time in rush hour here in Seattle (more than I seemingly did before) and was thinking it may be impacting the mpg more significantly than I'd imagined.
    Never forgotten:
    2002 S4 Stage 3 Tip
    Dec 11 2015
    i just purchased my s6 and would also love to hear about high mileage cars, I will put about 15k a year.
    How do the tuned cars hold up to high mileage?
    Oct 17 2015
    2008 Q7
    MN
    When I left Seattle in '08 traffic wasn't that bad. Moved back in '12 and wtf 100x worse, I just assumed this was your mpg problem ha.
    Feb 17 2004
    2013 Audi S6
    Ha! Yeah :) I live near the I90 bridge..once they started tolling the 520, things just got way worse :/
    Never forgotten:
    2002 S4 Stage 3 Tip
    Active Member Two Rings IngolstadtTech's Avatar
    Nov 05 2015
    1986 Ford Mustang Lx Notch
    Massachusetts
    I would not want to own a high mileage 4.0l just for the simple fact that you have to pull the motor for just about any repair. Even spark plugs take about 3 hours to put in and they are covered in small brittle vacuum lines.the intake manifolds and exhaust manifolds are reversed so if you have any fuel injector issues, carbon issues, or variable intake runner issues, which we all know these motors will start to at higher mileages, the motor will have to come out to correct them. This is just something to consider when the car is out of warranty
    Veteran Member Three Rings GameBreaker's Avatar
    Mar 19 2008
    Phantom Black S6, GONE but Not forgotten: Dolphin Grey B6 S4
    Chicago
    I feel your pain. I've seen the same and worse, but then I live in Chicago. MPG is great on the highway, but I generally do that only on holidays or the summer.
    Veteran Member Three Rings AudiA6A5's Avatar
    Dec 06 2013
    RI
    get a CPO A6 w/ sport (for paddles) and go stage 2
    C7 A6 Prestige - Phantom - Sport - LED - 35% Llumar - Eibach Pro-Kit - EC S+Ls - 034 TM - RS Grill - APR Stg II
    Cayman S - Rhodium Silver - PDK - Sport Chrono| B8 A5 Cabrio - Meteor Grey (for sale) | Pathfinder - Cayenne Red
    past audis: B5 S4 | B7 A4 S-line
    Feb 21 2010
    St Louis, MO (USA)
    Quote Originally Posted by mr_dennis_s View Post
    I am definitely tuning my S6. Probably in the next 3-4 months I will get it. Gotta spread out the funds a bit...getting new summer wheels and tires in February.
    May 14 2020
    13' s6 13' x5D
    Canada NB
    What are people at in 2020 for kms / miles . Thanks I'm at 167xxxkm
