I'm want to build an s4 avant. I don't have a car yet, so I've been looking for a while. I'd like some feedback on my build, the goal, and whether it's something I should even undertake.
1. The goal: build a fun, reliable daily driver. I would like to take this opportunity to do a full engine rebuild, partially because I just want to do it, partially because I'd like to have something reliable.
2. A rough build plan:
3.0 stroker - full bottom end rebuild
2.8l heads, rebuilt (new cams, valves, springs, etc.)
Tial 605 kit
Rebuild 01E w/ JHM
Tial 605 kit
Rebuild 01E w/ JHM
3. My Skills:
I'm not an experienced guy by any means. I've done regular maintenance, belts, alternators, starters, water pumps, etc. I lifted my jeep, swapped axles, built a transfer case (frankensteined some jy stuff together). I think with the resources of the internet, the right tools, and patience, I should be able to manage this type of build (limited fab, not unique, etc). I have a small garage (it's a bit cramped, but I think it's big enough to do some wrenching) and time so that should help.
4. The car:
I recently found a manual avant near me. I've had a hard time finding a cheap manual s4 avant (for example autotrader has ~1 nationwide, and it's already built - that's no fun!). The one I found is inside what I budgeted, so that's good. The reason it's cheap is it has a blown turbo and won't start (owner says he thinks it's the CPS). I don't think that should deter me, as I was planning on pulling & rebuilding the engine/trans anyway. It has a handful of mods:
So that's the info. The questions are: F21bt Turbos
Ev14 52lb Injectors
Srm 85mm maf housing and intake
Oem Rs4 PP with clutchnet 6 puck disk and oem flywheel
034 Motor mounts
ECS snub
Fk coilovers
Oz Superleggeras 18x8 With good tires
Podi Boost gauge
PIggie Pipes with oem exhaust with rear muffler delete
New timing belt, water pump, tsat and housing etc. (All done in the last 10k miles)
Ev14 52lb Injectors
034 Motor mounts
ECS snub
Fk coilovers
Podi Boost gauge
1. Am I crazy thinking I can build a b5 to a reliable dd?
2. Am I crazy thinking I can completely rebuild a b5 with little/no experience?
3. Am I crazy to think this car is worthwhile?
4. How would you value this car?
5. How much would you have budgeted to build this car (including purchasing the car)?
Thanks ahead of time. I've been devouring this forum while looking for a car, there is SO MUCH to learn about these cars.
