Results 1 to 34 of 34
    Veteran Member Four Rings Tjtalan's Avatar
    Jul 19 2014
    Tulsa
    034 spherical rear tie rod installation ?
    Ok so I'm having issues lol, I purchased the 034 rear spherical upper control arms, and rear spherical tie rods. My first question, has anybody successfully installed the black updated versions of the tie rods.
    I'm running the rear chassis stiffening kit from 034 and at suspension compression the tie rods make contact. I was told by 034 that my rear subframe must be bent, first off the chassis stiffening kit would not lineup if the sub frame is bent. I double checked just to be sure, The sub frame is not bent.
    At this point I'm trying to decide if it's in anyway installation error on my part, in fact I hope it is.
    Veteran Member Three Rings lo-lyfe's Avatar
    Mar 27 2012
    2006 tuned & lifted F350 6.0 Powerstroke, 1990 built Ford Bronco 5.0l 302, Built Stage 3 b5s4
    out on the farm, in the Mitten
    I have the earlier version of this tie rod (the red shaft) and ran into the same issue. Regardless of the orientation of the rod end spacers - in other words, where you place the long spacer and the short spacer within the subframe - the shaft will hit the sway bar support bracket and get dinged under load. My solution is to source a set of rod end spacers that place the head of the end link somewhere in the middle of the inside of the subframe, instead of orienting it closer to one edge, as is the case with 034's uneven spacers (in your pic above). Hoping that works. IMO, I don't think 034 tested both of the products in unison (Sway bar support bracket and adj tie rods) to see if they were compatible together.
    Also, the old version included rod ends that, IMO, were not of the best quality. Despite the fact that my car is stored over Winters and hardly sees any rain, the rod ends rusted and seized after less than a year of use. I swapped tho original rod ends with QA1 Endure Series end links in aluminum and wrapped those in dust boots. For the sake of longevity my suggestion would be you do the same (dust boots, that is).
    Old Pic:
    [IMG]005 by Hussaria[/IMG]
    New Setup:
    [IMG]019 by Hussaria[/IMG]
    Stay tuned...
    Jul 19 2014
    Tulsa
    Thank you very much for the reply, exactly the info I needed.
    Veteran Member Three Rings Audi9's Avatar
    Jul 20 2014
    B5 S4, 8V A3, 8V.5 RS3
    San Antonio, TX
    I have the same setup with the updated design and still have rubbing issues even after perfectly lining them up. I brought the issue up with Adil at 034 but he wasn't aware of any other people having problems.
    Compared to your pictures my setup seems to be rubbing much more but I've been running them for about a year
    Mar 27 2012
    Quote Originally Posted by Audi9 View Post
    I ran mine for about a year with the rubbing as well. Once the contact area shaved whatever material off the tie rod shaft to get clearance I didn't have any more issues. I'm estimating the groove cut out of the tie rod shaft was a few mils at least. Would prefer not to have to drive like that, however.
    Stay tuned...
    Veteran Member Three Rings uponone nogaro's Avatar
    Sep 14 2011
    01 Silver S4, 00 Noggy S4 Sport Package, B8.5 Dsg S4 Dual Pulley,240sx w/2j swap
    Bay Area CA.
    Dam the wheel well is hella clean
    Sep 07 2012
    Tucson, AZ
    Quote Originally Posted by uponone nogaro View Post
    Exactly what I was thinking... You could eat off that wheel well
    Jul 19 2014
    Tulsa
    The problem is my suspension is binding, its that bad. Cant even get my alignment done.
    Jul 19 2014
    Tulsa
    Quote Originally Posted by lo-lyfe View Post
    How are you guys adjusting the Tie rod ? Are you still using the eccentric bolt ? I thought the point of the tie rods was the adjustment, I cant turn the rod lol.
    Jul 20 2014
    San Antonio, TX
    I put the length as close to the factory tie rod length as I could get and use the eccentric bolt for any adjustments
    Mar 27 2012
    Quote Originally Posted by Tjtalan View Post
    Use both, tie rod and eccentric bolt. Like Audi9 stated, I get my tie rod close to OEM length and eyeball the position of the wheel relative to the fender, aiming for a neutral stance. The finishing adjustments are made by the alignment shop when the car's suspension is being dialed in.
    You can't turn the tie rod due to the fact that it is binding against the sway bar support bracket? IF that's the case my suggestion would be this: get some 5/8" to 1/2" reducers (8 total, 2 per rod end). The 1/2" reducer will get you close to the diameter of the M12 eccentric bolt. You can get them in different lengths (see below for a possible vendor):
    http://pitstopusa.com/c-131783-chass...-bushings.html
    Then hit up JEGS for some 5/8" spacers or stay with pitstopusa for reducer bushings. Either way, you will probably deal with some trial and error in getting the correct lengths of bushings/spacers that will allow you to place the rod end inside the subframe so that you get the proper amount of clearance for the tie rod shaft. A cheaper alternative is to allow for some slack within the subframe between the rod end and the bushings and run some 12mm spacers to make up the difference.
    https://www.boltdepot.com/Product-De...x?product=4520
    Wish I had a solution for this problem but my car is sealed away in a car jacket for the Winter. Can't get to it even if I wanted to or I would be breaking the moisture seal. I will be dealing with this issue myself come Spring, however, but I hope you're all squared away before then :-)
    Stay tuned...
    Jul 19 2014
    Tulsa
    Thanks everyone that posted, but I don't think any of us should need to modify parts that should just work. I've been in contact with Sam at 034, he has been vary helpful. The rod shafts are going back to 034 for further machining, hopefully this thread points out that the problem is not an isolated incident.
    Jul 20 2014
    San Antonio, TX
    ^So what ended up happening? I'm getting tired of mine binding on the sway bar support brackets
    Jul 19 2014
    Tulsa
    Sam at 034 has been awesome, The engineering team made a new version after coming to the conclusion that the old style does not work with the chassis stiffening kit. I should have them tomorrow, i'll post pictures when I receive them!
    Jul 20 2014
    San Antonio, TX
    I spoke with them Monday as well about the updated design. Cool to see its taken care of.
    Jul 19 2014
    Tulsa
    Sam and the guys 034 are top-notch, they didn't bullshit and they fixed it in a timely fashion. I'm just happy to get my car of jackstands!
    Veteran Member Three Rings slowrideBC's Avatar
    Jun 10 2012
    2000 s4
    I have these installed but my car hasnt seen the road yet, I hope I can just swap them for the revised ones or 034 can machine them.
    2000 S4 - silver- RS4 OEM widebody racecar
    Sep 17 2005
    Fremont, California
    I'm pleased to say that our new design has been officially released and the new tie rods are in stock!
    We've redesigned these rear tie rods to offer increased clearance when utilizing them in conjunction with our Billet Aluminum Rear Subframe Reinforcement Brackets. The new design features a billet-aluminum body that is machined in-house to provide more clearance than the previous version, while retaining ease-of-adjustment, and increasing strength. You can learn more or place an order for these on our website!
    Adjustable Spherical Rear Tie Rod Set for B4/B5 Audi A4/S4/RS4 & 80/90/RS2
    Thank you for your continued support, and we're pleased to continue supporting the B5 platform with new products, while continuing to make improvements to our existing product line whenever possible.
    Veteran Member Three Rings Cacti's Avatar
    Nov 10 2011
    MI
    Can we send back the center section to get a new version if we have the previous version?
    Veteran Member Three Rings kingofqueenz788's Avatar
    Jan 11 2007
    audi%20s4
    NewYork, NewYork
    I need to know the same thing I baught these a few months back!
    Sep 17 2005
    Fremont, California
    Quote Originally Posted by Cacti View Post
    Quote Originally Posted by kingofqueenz788 View Post
    Please send Sam an email at [email protected] and he will help you guys out!
    Jan 11 2007
    audi%20s4
    NewYork, NewYork
    Is it SAMs or sam@034 ?
    Senior Member Two Rings joeSfour's Avatar
    Nov 09 2011
    South Bay, CA
    [email protected] - As 034 said in their post.
    Current - 2001 B5 S4 Imola Avant
    2009 VW GTI
    Past - 2002 B5 S4 - 034 STK 5858 PT fully built 3.0L
    Jul 20 2014
    San Antonio, TX
    Well this sucks. Picked up the "new design" tie rods from 034 and after taking the suspension and old ones apart, I open the wrapping/packaging to find the new ones are identical to the old ones. Kinda pissed
    Jul 19 2014
    Tulsa
    Yeah, that sucks man.
    Mar 27 2012
    The "new design" ones you received are not tapered in the middle? I thought that was the whole purpose of the re-design, with the tapering to provide the clearance needed for the sway bar brackets. Maybe 034 shipped the "old" version by mistake...I'm assuming you do not have the original 034 tie rods for a side-by-side comparison pic?
    Stay tuned...
    Jul 20 2014
    San Antonio, TX
    Mar 27 2012
    Thanks. From the pic I would say someone at 034 definitely made a mistake and shipped the old version of the shafts. Look nothing like the solution 034 advertised here and on a different thread. I can see why you're frustrated. Hopefully 034 rectifies this quickly and at no cost to you.
    Stay tuned...
    Sep 17 2005
    Fremont, California
    We're very sorry about the mishap! Somehow an old set of tie rods were still on the shelf when your order was pulled. We'll be sending you the correct components today at no charge.
    Cheers,
    Laszlo
    Jul 20 2014
    San Antonio, TX
    Well, 034 strikes again! After removing the inner and outer aurora joints so I can transfer them to the "updated" rods I find the outer half isn't threaded correctly and won't allow the Aurora joint to be threaded in. Once again I have to put the old ones back in. Fucking awesome. Thanks 034.
    Jul 19 2014
    Tulsa
    When I got mine they had been anodized inside the threads, I had the same issue, instead of dealing with sending them back I ran a tap through the threads.
    Jul 20 2014
    San Antonio, TX
    I'll try that and see what happens. Thanks
    Jul 20 2014
    San Antonio, TX
    Nice, Tjtalan to the rescue haha. Cleaning up the threads did the trick. Wouldn't think anodizing would be enough to cause a problem?
    Sep 17 2005
    Fremont, California
    We apologize for the issue; generally speaking, we ship these tie rods assembled. Since we shipped you the arms by themselves, it seems the threads may not have been chased after anodizing. Hope you enjoy the parts!
