Yes, it will fit. I just put a bf bel from an 05 a6 into my 02 s4. Fairly easy, just swapped everything over from my apb block.
Originally Posted by
aysix
If it's from an auto car you will have two EGR valves, you might want to look into deleting those if your car is a manual. There is also a spacer on the rear crank face you gotta whack off with a mallet iirc. Other than that you should be good to go.
there was nothing that needed whacked off on the bel I swapped over. Could have been gone already? I also deleted the egr, just made a couple block off plates at work
rani_aridi
@Aysix Aren't the 2005 motors bel? I thought there was much more needed to make a bel swap work.
Yep and nope, easy swap imo
aysix
Yes they are BEL, the only differences is the ECU and harness/coilpacks, everything else is the same.
Not quite, there are small things like the grounds under the im. Different plugs so they won't fit the s4 harness. Had to swap them out after I'd already mounted the manifold
the aux h20 pump plug is different too
LINDW4LL
2005 is BEL. If it's from an automatic car, it will have new-style turbos requiring different downpipes.
You'll have to swap the valve covers, too, I think.
can't say about this, I used the turbos from my apb. All mounted fine though. You will need to swap vc's if you are using your s4 harness.
