I just picked up my car from the dealer for a bad alternator, ran OK for 10 minutes and all of the sudden I got a "Turn off engine check oil level" warning. I pulled over, checked oil level, all's good. It went away and then came back on a minute later. This happened till I got to work. Weird thing is, if I rev hard, the warning goes away.
Could this at all be related to the alternator change? Something they may have missed?
History of the car: 2009 Audi A4, did the Stage 2 oil consumption fix with Audi (pistons/rings) and last oil change was just a few weeks ago.
***Oct 27 - EDIT: Came back from Dealer, they replaced the low pressure switch/sensor because VAG was reporting P164D. 20 minutes after driving, the light came back on again. I wanted to have a look and see if it has anything to do with the alternator change.. I see this:
The sensor cable is very tightly clamped on to the new alternator. I'm assuming the cable is damaged that's why I'm intermittently getting this error.. Is this a valid reason/cause as to why I was having these issues immediately after the alternator change? I need to be told I'm not making assumptions before I go ask for a refund. Any way I can confirm for sure its the cable? I was hinted at it after seeing this thread with a person exactly same as m symptoms: http://www.audizine.com/forum/showth...4b-p164d-p0341
