Page 17 of 28 FirstFirst ... 7151617181927 ... LastLast
Results 641 to 680 of 1087
  1. #641
    Veteran Member Four Rings blbroo's Avatar
    Oct 26 2012
    SQ5, Nissan D21, 435i Gone: K04'd B8 A4, M235i, UrS6, B9 SQ5, D21 Nissan 4X4
    St. Louis, MO
    Quote Originally Posted by 4ringnut View Post
    Sorry for the shitty diagram.
    Damnit G, that is a terrifying pic! Cut off at the stub....
    Collector of German things.
    “Whoever said laughter is the best medicine had clearly never tasted scotch.”
  2. #642
    Veteran Member Four Rings lettuce's Avatar
    Jun 19 2015
    Boston
    Quote Originally Posted by VNA4 View Post
    Lettuce
    In thread #146: "I also epoxied a couple little rubber squares under the crash bar where the tank welds were contacting it to prevent any potential vibration or rattling." Can you tell me which product you bought and how you applied it? Planning to follow your DIY next week.
    They were just thin little half inch chunks of rubber I found lying around my garage somewhere. And I think I used Goop to glue em down.
    B8 A4 - Eurodyne-tuned F23L - 12.6 @ 107 on 93
  3. #643
    Sep 09 2010
    Destin, FL
    Quote Originally Posted by blbroo View Post
    Ha.
    What's funny about this whole bump stop thing is the shop that did my drop just removed them completely and I've never had an issue. Probably not good on the other hand.
  4. #644
    Jun 19 2015
    Boston
    Bought a couple 5-gallon drums of methanol today. Also bought a bunch of distilled water to cut it with. After mixing it all together it should give me 25 gallons of 60/40 water/meth at $4.60 a gallon. Or 20 gallons of 50/50 at $5.50 a gallon. Haven't decided yet.
  5. #645
    Jun 12 2013
    1999 Pontiac Grand Prix GTX
    LaSalle, Ontario, Canada
    LOL talk about "Costco" buying methanol!
    Car is looking good bud!
    Were you able to resolve the high speed/RPM oil fault? I read you swapped the cam bridge but then it came back. Any new info?
    2010 Silver Audi A4 MT Sport Package w/ B&O
    Stage 'X': FrankenTurbo F23L Ceramic Coated Manifold | Bully-Flo P&P Head | Ferrea Intake Competition Valves | Ferrera Exhaust Super Alloy Valves | IE ValveSprings & Retainers | HFC wrapped w/ DEI Titantium
    Eurocode FMIC | Maestro Tuned | K&N Typhoon Intake | EuroCode Meisterwerk | StopTech BBK | 034 Motor Mounts & All Inserts | CTS PCV Catch Can
    Build Thread
  6. #646
    Veteran Member Four Rings 4ringnut's Avatar
    Apr 04 2015
    2019 Audi S4, 2017 Acura MDX
    Woburn, Ma
    Quote Originally Posted by The Infiltrator View Post
    Ha.
    Go for a drive on VT or ME back roads.
    Pedal Responce first responder.
  7. #647
    Jun 19 2015
    Boston
    Quote Originally Posted by Allowencer View Post
    Well I went through a half gallon at the track, so I figured I'd buy in bulk so I don't have to keep restocking. Plus I'll get more consistent results if I do large batches at a time. Consistency is key considering I'll be tuning for it.
    That issue ended up being completely unrelated to the cam bridge. Good to have a new one in, but it ended up being that stupid little cam actuator clip that i snapped in half back when I did the turbo install. Every time I have to unplug it, whenever I plug it back in I have to finagle some bits of wire in there to bridge the broken connection. Apparently I didn't do a very good job one time and was getting an intermittent connection there, causing the fault. I redid it and it went away. I've been searching for a new one to splice into my harness with zero luck. I'll probably need to find a junked A4 and just clip one off the harness. Unless you can find me one..
  8. #648
    Jun 12 2013
    Ah! glad you were able to figure it out. From the top of my head, aren't they the same connection like to the fuel injectors?
    Build Thread
  9. #649
    Jun 19 2015
    Boston
    I don't think so. They're the same as the connector on the front of the upper timing cover that clips into the front actuator that goes into the intake cam's control valve. The one with the reverse thread you need that special keyed tool for.
  10. #650
    Jun 19 2015
    Boston
    Wow, my steering wheel just shipped. That was fast. Now let's see how long it takes to get here from Poland.
  11. #651
    May 22 2013
    Southern ME
    Nice! Now he can start work on mine!
    Is that the stock image from the listing or did he take that of the wheel he's sending you? I still haven't heard anything from him.
  12. #652
    Jun 19 2015
    Boston
    Quote Originally Posted by asfastas63 View Post
    Just one of the pics from the listing. I never heard from him either, but I gave him all my specs in a PayPal note along with the payment. I'd imagine he's just crazy busy nowadays and will only email you if he has to.
  13. #653
    Jun 19 2015
    Boston
    God damn it.
  14. #654
    Veteran Member Four Rings jmeenach's Avatar
    Mar 17 2014
    Los Angeles, CA
    Quote Originally Posted by lettuce View Post
    God damn it.
    Hello two tone steering wheel! haha
    Pedal Responce Team's expedition ace/Banana Responce Team first responder
    2013 B8.5 A4 Quattro. RS grille / 20" 'Flower Petal' reps / AFE / VCDS mods / more to come...
    instagram
  15. #655
    Veteran Member Four Rings Lambda13's Avatar
    Jul 07 2012
    A4, car parts, paint, random sockets, OEM parts.
    Boston, MA
    Weak.
    Sent from my SM-G900V using Tapatalk
    My 2009 A4 Prem+ Build thread
  16. #656
    Senior Member Two Rings ECDT's Avatar
    Jul 15 2015
    Philadelphia
    God damn it.
    Oh god please no I already have a grey one that was ordered wrong
  17. #657
    Jun 19 2015
    Boston
    Quote Originally Posted by ECDT View Post
    Did you have any luck dying it? My wheel is in NYC right now so I imagine it'll be here by the weekend. I know for a fact I will not be able to drive my car without that wheel on it if it's in my possession.
    I may actually have to go with the two-tone until I get a replacement.
    There was a black one on ebay for $76.99 with a 'make an offer' button, so I offered him $50. He sent me a counteroffer within the hour for $75.99. Like, why the fuck do you even have that button on there if you're going to do shit like that. So i countered his counter with $2.50. He has yet to respond. Considering buying it at full price just to leave negative feedback.
  18. #658
    Veteran Member Four Rings earhythmic's Avatar
    Sep 17 2006
    ‘17 F450, ‘24 Street Triple RS
    San Francisco Bay Area
    LMFAO
    2013 Allroad - 12.18s 1/4 mile
    CTS K04| APR | IE | Magnaflow | AirLift 3H | Hotchkis | Vorsteiner
    clicky for build thread
    past: B6 S4, B5 A4
  19. #659
    Jul 15 2015
    Philadelphia
    Lettuce Build Thread, Fast Cars and Fast Women: Stage 2 and Beyond
    I opted to order another cover from the aliexpress link I saw a few pages back on here or another thread hence the " oh God please no " I tried some black interior spray dye from vht I think but didn't care for the finish and didn't another $40+ for a cover. That seller who countered you I have dealt with in the past and had a similar counter offer which I accepted and he ended up selling it to someone else who transferred the funds faster than the 30min it took me then nagged me to cancel transaction. So fingers crossed my cover that has shipped already is black
  20. #660
    Jun 19 2015
    Boston
    Best mod ever.
  21. #661
    Sep 17 2006
    Sexy. I agree. Completely transforms the driving experience.
    past: B6 S4, B5 A4
  22. #662
    Veteran Member Four Rings Alex1188's Avatar
    Mar 10 2013
    Forest Lake, Minnesota
    Best mod ever.
    So did this wheel end up working with the factory 4 spoke airbag? Did you need that different airbag cover?
    Looks very great! This is hopefully gonna be my next mod on my list
  23. #663
    Jun 19 2015
    Boston
    Quote Originally Posted by Alex1188 View Post
    Not exactly. If you'll scroll up a bit you'll see that the 3-spoke airbag cover I ordered was the wrong color, since the seller so graciously had posted pics of a black one uploaded on his store page. So for now I just took a pair of cutters and snipped out a wedge in the bottom of my 4-spoke cover to fit it on the 3-spoke wheel. The side spokes don't exactly line up and I have a small gap where the lower spoke holes are in the cover, but it fits on and works as-is. It's enough to hold me over until I'm able to source a real black 3-spoke cover.
    But yes, the airbag itself works fine, and I'll be using it with the new cover when it gets in. All you need is the new cover. Or your old cover and a cavalier attitude.
  24. #664
    Oct 27 2010
    Sepang S3, Arctic S4.
    Norwood, MA.
    That looks fuckin' DECENT.
    2016 S3
    Instagram- @Thisisastickup
  25. #665
    Jun 19 2015
    Boston
    This is up there as one of the best mods I've done to this car. The craftsmanship and artistry that has gone into this wheel is incredible. The guy who makes these is seriously the Hattori Hanzo of steering wheels. I'd have paid double what I paid for this again in a heartbeat. If you're on the fence, just do it. You will be blown away.
    Disregard the airbag cover fitment in that last pic. I had some issues with the 3-spoke cover I purchased (see a few posts up) and had to modify my stock 4-spoke cover to get it to fit temporarily until a new 3-spoke cover comes in the mail.
    Overall I couldn't be happier with this wheel. I've held an OEM S4 FBSW in person and this wheel blows that shit out of the water. At a fraction of the cost, it's a no-brainer. Not to mention it could easily become a collector's item if the guy stops making them.
    Each wheel is custom made to order to your exact specs and takes at least 3 weeks (depending on how backed up with orders he is at the moment) to get made. The seller has an ebay store by the name of fly-designs and works out of Poland. Once he gets backed up with enough orders he shuts down his store until he's caught up and reopens it once he's ready to accept new orders, so if you check it out and it's down, just keep checking back. It'll be worth it.
  26. #666
    Veteran Member Four Rings avantagg's Avatar
    Jun 21 2015
    1999 T4 Eurovan
    Maine
    Damn that looks awesome! Congrats.
    2012 B8 Avant (3.0t Swapped)
    034 DP | APR UC | Ported Charger | Mertop Headers | Milltek Resonated Exhaust | Bilstein PSS-10 | Alu Kreuz | CR-15 | H&R Sways | 034 Inserts | Ecodes | A5 Cluster Swap | 3G+ MMI | RS4 FBSW | Black Headliner Swap | BUILD THREAD
  27. #667
    Veteran Member Three Rings VNA4's Avatar
    Jun 20 2015
    San Jose
    Yo Lettuce,
    How do you know for sure 100% that upon replacing a non OEM steering wheel the airbag will deploy?
    I wanted to get a S.wheel from eBay but was sceptic about this
    S4 B8.5 2014
    KW H.A.S. / EuroCode ÜSS Adjustable Sway Bar / AWE Touring Diamond Black / 034 Stage 2+ / DP 187mm / APR Stage II Carbon Back Pipe
    20 x 10 et35 StanceWheels SF01 [PowderCoated Diamond Black]
    SOLD
    AUDI A4 B8 Premium Plus Sport:
    CTS k04/ APR k04 File / AWE Quad exhaust / FMIC: TR8
    VIP VRC 13 : 19X9.5 / Tires: 255/35/19 / Solo werks Coilovers / OE S4 Front Brake Upgrade Kit
  28. #668
    Oct 27 2010
    Norwood, MA.
    Yo Lettuce,
    Because it's an OEM airbag...with oem electrical connections. Steering wheel has nothing to do with the bag.
    2016 S3
  29. #669
    Senior Member Three Rings petraman's Avatar
    Apr 26 2016
    Columbus, OH
    That steering wheel is amazing but I've only been able to find that particular one with paddles... Do you think there would be pretty visible openings if the paddles were removed?
  30. #670
    Jun 19 2015
    Boston
    Yo Lettuce,
    The airbag is totally separate from the wheel. I'm still using my stock airbag and it's still plugged into the same harness that it was plugged into before. I had to disconnect it to remove the stock wheel, and then reconnect it after the new one was in. There is literally zero difference in my airbag system now compared to with the stock wheel.
    Quote Originally Posted by petraman View Post
    The guy that makes these should be able to get you one without paddles no problem. I think he'd even take a couple bucks off.
  31. #671
    Jul 15 2015
    Philadelphia
    Well I got lucky
    And fly designs makes amazing wheels shame mine is collecting dust and is still not installed
  32. #672
    Senior Member Two Rings frameshift18's Avatar
    Oct 15 2009
    NE, Ohio
    Man, didn't realize I would have to disassemble the airbag entirely to swap the airbag cover. feels like the bag itself will just fall out with how tightly it's packed in there.
    Edit: That was a stressful time haha. Take your time, make sure the new cover goes on smooth and doesn't catch on the bag anywhere.
    02 S4
    11 A4
    01.5 A4
  33. #673
    May 07 2014
    Well I got lucky
    Will you install it, or, willing to part with it? lol
    2010 A4 2.0t quattro 6mt
  34. #674
    Jul 15 2015
    Philadelphia
    Quote Originally Posted by zokissima View Post
    I will be installing. When I first ordered the air bag cover it was gray and the black one just got delivered yesterday
  35. #675
    Jun 19 2015
    Boston
    Lol I got 38 mpg on the way to work today, up from my usual of 20. Ask me how I was able to do this with just one weird trick. (gas companies hate me).
  36. #676
    Jun 20 2015
    San Jose
    Share! :)
    S4 B8.5 2014
    SOLD
  37. #677
    Jun 19 2015
    Boston
    Share! :)
    Running on only 3 cylinders at the moment. Number 2 crapped the bed yesterday evening, not sure why yet.
    Also I repainted the lip on the diffuser you sold me over the weekend. Hyper Silver to match my wheels. Looks boss.
  38. #678
    Oct 26 2012
    St. Louis, MO
    haha!
  39. #679
    Veteran Member Four Rings KFizz's Avatar
    Dec 27 2009
    Edmonton/Alberta
    Oh! Where do I click?
    Sent from my Nexus 5 using Tapatalk
    Kyle
    2014 a4 Allroad /// Ibis, Unpainted Lowers (True AR)
  40. #680
    Jul 07 2012
    Boston, MA
    Thanks for the assistance yesterday man. I'd have been sunk if not for those tools.
