Page 2 of 28 FirstFirst 123412 ... LastLast
Results 41 to 80 of 1108
  1. #41
    Veteran Member Four Rings impulse's Avatar
    Mar 06 2014
    2006 B7 A4 - 2.7t Swapped. 2008 8P A3 - 3.2L VR6
    Connecticut
    Unrelated to my boost problem, my window regulator finally died out. Had time to replace it tonight
    Also learned that my car has aftermarket pioneer speakers that were totally rigged in...
    Also the sound deadening material was duck taped in... Ended up putting it back in that way lol
    Received my package from JHM today, which I ordered before getting the tune.
    - oil change kit,
    - cat gaskets for my 034 hfc, which I don't even know if I can install because of the tune...
    - 034 street density density line motor mounts coupled with a poly snub mount.
    Joe
    @jg_iii_
    Check out my progression thread - http://www.audizine.com/forum/showth...Picture-Heavy)
  2. #42
    Mar 06 2014
    Connecticut
    Update on the overboosting issue:
    -Went back to the forge DV because the OEM DV I have is throwing the p0299 underboost code.
    -Tried changing the n75 like Jake said... No luck.
    -Think I'm going to go back to Excelerate or a performance shop near me to get the wastegate adjusted. I boost at 14 and spike 17 in stock so I think my issue is right there.
    When I did all of that I got around to changing my oil and installed the snub mount. Definitely can feel a difference, cannot wait to put the density line mounts in!
    Then the other day my brakes started squealing... So the proper thing to do is upgrade! Bought these drilled and slotted rotors off of r1concepts. Very affordable, good reviews. My friend has them on his Infiniti G37xs so I decided to go the same route for only $300 shipped.
    Also bought new control arms and wiper blades from fcpeuro! The control arms for $80 were a no brainer especially for having great reviews.
    Now I realllllly need to find time to do all of this. Working full time isn't as fun as I thought
    Joe
    @jg_iii_
  3. #43
    Mar 06 2014
    Connecticut
    Update (idk if anyone actually reads... This has become my own car diary )
    Had time to install the 034 High Flow cat with my friends, what a royal pain in the ass. Never want to do that again. Overall the sound improved and I definitely feel a little more pep when I accelerate.
    So the overboosting problem is resolved. The wastegate wasn't adjusted properly, so Speedsport Tuning in Danbury CT took care of it for the most part. Then it still needed some fine tuning and I decided to just do the rest as they couldn't take my car back until after the Fourth of July.
    My friend Ryan installed the drilled and slotted brakes. The stopping power achieved is unbelievable. Definitely worth the money! R1Concepts definitely delivered with an affordable price to top it off.
    Went to a car show this past weekend and also shot with my friend Ian.
    Photos from the shoot
    And here's some miscellaneous photos from various photographers at the show. FlyMeet 2.0: Stance by the Sea
    Also had time to tackle my suspension shake and clunk. Only did the passenger side and wow what a difference. Started by changing the control arms to the ones from FCP Euro. The old bushings were clearly destroyed.
    Also changed the hi hat on my suspension. Went from the right one to the left. Decided to leave the OEM setup
    Figured that the little white spacer needed to be snug in the hi hat, opposed to it being loose in the old one. Dremeled the middle out.
    All done
    Now all that's left is to fix the drivers side and install my 034 Density Line motor mounts!!!
    Joe
    @jg_iii_
  4. #44
    Veteran Member Three Rings leftovers's Avatar
    Apr 14 2009
    ottawa, il
    Some great pictures from the show. I'm glad to see you didn't bail on the car. I think the work you're doing now will solve your problems. Keep us updated.
    2004 A4 Ultrasport, 1.8T, 6MT
    Instagram: audi_ute_build
  5. #45
    Mar 06 2014
    Connecticut
    Quote Originally Posted by leftovers View Post
    Minor shake no more clunk. I think I need an alignment but that's really it. Also I am throwing these codes now
    P0089
    P2293
    P0299
    Not sure why. Happened with the tune on. Things might not be keeping up with the added performance
    Joe
    @jg_iii_
  6. #46
    Veteran Member Three Rings 1killera4's Avatar
    Mar 18 2014
    Dunedin Florida
    Baddass looking car. Little to low for this old man...but really looks good!!!
  7. #47
    Mar 06 2014
    Connecticut
    Quote Originally Posted by 1killera4 View Post
    Haha it's on air!
    Joe
    @jg_iii_
  8. #48
    Mar 06 2014
    Connecticut
    So last night I finally finished off my box of parts and installed the 034 motor mounts with my buddy John
    I'm slowly bringing this old girl back to life. Just a little more TLC and ill be able to get back to performance modding.
    That motor mount was totally shot. Glad I replaced them and wow it made a world of difference
    Just a couple old things that came off the car in the last few weeks
    Joe
    @jg_iii_
  9. #49
    Mar 06 2014
    Connecticut
    More blogging to myself...
    Bought a Techtonics Tuning exhaust after a long time with the OEM one after replacing the OBX catback. This should go well with the 034 High Flow Cat.
    Also bought a new fuel filter, high pressure fuel sensor, low pressure fuel sensor, and diverter valve in hopes of removing the check engine light and getting my car to run properly again. Fingers crossed that I get away cheap!
    Jake@JHM told me to go back to stock so this is up for grabs. I have a for sale thread.
    Also have a JHM front mount inter cooler on the way which I'm really excited for!
    More updates later...
    Joe
    @jg_iii_
  10. #50
    Mar 06 2014
    Connecticut
    I didn't really take any pictures but when I was taking my HFC off of the manifold I snapped a stud... Which left me to hours and hours of annoying work just to fix it.
    Anyway I got the exhaust on here's some uninteresting pictures
    Also one of my exhaust hangars was messed up and I was too frustrated to change it so I just did this.
    Then my JHM front mount came in the other day and I got it on yesterday
    Also tried to fix my ac and changed the g65 thrust sensor when i had my bumper off
    So when my buddy went to clear the ac code he just scanned the car. A vw tech was nearby and heard us talking and he was saying there's way more issues with it than I think and I'm stumped where to even turn to to tackle some of these problems. He had told me to shut the tune off and baby the car so I may be parting ways with the JHM tune if I can't get my car to keep up with it.
    If anyone is reading this please shed some light
    Joe
    @jg_iii_
  11. #51
    Veteran Member Four Rings thenofjboy's Avatar
    Oct 08 2007
    08 S-line QMT6 , B5 KO4 & my german sheppard
    Jersey City
    before you changed the g65 thrust sensor, how was the car driving? any codes, knock. non-consistent idle...
    Sean
    The New
    B7---GIAC--BBS--DDM--JHM+S4Exhaust--StaSIS SS--034--AudiUP--USP--RedEBC--IE--DrakesVC#12--B7S4 Brakes--StopTech--GFB DV+--
    The Old
    B5---GIAC-K04--RACETEC--APR--DEPO--AUTOTECH--VMR--FORGE--034--H&R--BILSTEIN--FUJITA
  12. #52
    Mar 06 2014
    Connecticut
    Quote Originally Posted by thenofjboy View Post
    The idle didn't change at all, there were still codes but there was some time between the last scan and this scan. The new ones are the knock sensor codes.
    Here's the last scan, date is around July 13
    Joe
    @jg_iii_
  13. #53
    Veteran Member Four Rings RAudiB7A4's Avatar
    Nov 08 2010
    2015 Hyundai Santa Fe Sport AWD
    Rochester/MN/Mid West
    God damn your car looks good. Wish I had bags!
    DTM_B7_S4
    Previous car: APR_Stage_II+_B7_A4
  14. #54
    Mar 06 2014
    Connecticut
    Quote Originally Posted by RAudiB7A4 View Post
    Haha thanks! Now if only it would run properly...
    Joe
    @jg_iii_
  15. #55
    Apr 15 2007
    WNC
    What are the specs of your final 18x9.5 wheels? Offset?
    2013 RS5, 2014 Q7
  16. #56
    Mar 06 2014
    Connecticut
    Quote Originally Posted by rnp614 View Post
    Et 15 front 25 rear.
    Joe
    @jg_iii_
  17. #57
    Apr 30 2014
    B8.5 S4, A3 e-tron
    CA, Bay Area
    FMIC looks good! Nice work so far
  18. #58
    Mar 06 2014
    Connecticut
    Soooo I sent my car to the body shop
    Just kidding. I picked up this b7 and sold mine. Better maintenance and the body work is flawless.
    Time to dig in to the new car!!
    Joe
    @jg_iii_
  19. #59
    Mar 06 2014
    Connecticut
    Top or bottom
    Joe
    @jg_iii_
  20. #60
    Dec 30 2015
    RI
    I LLLOOOVVEE the way the top looks man, those wheels just fit the color so well
    like Bonnie and Clyde lol
  21. #61
    Dec 30 2015
    RI
    P.S. I think B7s were made just for bags. They sit so purdy
  22. #62
    Apr 14 2009
    ottawa, il
    Bottom
  23. #63
    Veteran Member Four Rings DanKing's Avatar
    Aug 14 2014
    California
    Top 100%
    Damn clean
    Sent from my Nexus 6P using Tapatalk
    '07 6MT Brilliant Red 2.0T
    JHM Stage 1 • JHM test pipe • ST coilovers • Smoothed Cupra R lip • Relak Skirts • 3sdm 0.06 • 034 mounts • Revo snub • GFB DV+ • S4 Recaro seats • RS4 Steering Wheel • Joey'd Bi-Xenons • Phils V4 LEDs • STI projectors • LEDs everywhere • APR Carbonio Intake • p3cars Gauge
  24. #64
    Veteran Member Four Rings Axis's Avatar
    Nov 15 2011
    3.0T 6MT Stage III Allroad | A4 B8.5 Sedan
    Montreal | I sell in USD
    Impulse's Progression Thread (Picture Heavy)
    Bottom for me too, prefer concave to flat faced wheels on a car that can rock concave wheel like those Aka a bagged car.
    Wagons are made to haul things, mine is made to haul ass
    *****I sell in USD*****
    Click here to read my seller feedback
    B8.5 Allroad 3.0T 6MT Sport Diff 034 Stage II+
  25. #65
    Dec 30 2015
    RI
    These two pictures make me want too save for bags lol
  26. #66
    Mar 06 2014
    Connecticut
    Quote Originally Posted by kS_Method View Post
    like Bonnie and Clyde.
    Bottom
    Quote Originally Posted by DanKing View Post
    Top 100%
    Damn clean
    Quote Originally Posted by Axis View Post
    Thanks for the feedback and kind words everyone!
    I think I'm leaning towards the CCV, I would do the CBQ but I couldn't make it have a 3-4 lip with how it's designed
    Joe
    @jg_iii_
  27. #67
    Mar 06 2014
    Connecticut
    Who else has been hoarding through the winter? Here's my collection of things below that aren't all pictured
    JHM FMIC
    JHM DP-Y
    034 HFC
    034 Catch Can
    APR HPFP
    OEM S4 Exhaust
    Silicon Turbo Inlet pipe w/ Spectre filter
    Cuprazilla Lip
    CSR Side Skirts
    Duraflex Window Spoiler
    OEM S-Line trunk lid
    And I have to of course order my Rotiform CCV's and get a tune...
    Debating on going Unitronic this time around. I had JHM Stage 1 on my black B7 but I was boosting 30 psi as soon as I got it so I shut it off. I was troubleshooting it with them and never resolved my issue before just selling the car.
    I adjusted my wastegate like they said which just caused more issues and I tried fixing all sorts of sensors but never really resolved it...
    Soooooo yeah I'm really hesitant to go JHM again since I'm not willing to shell out $600 just to get burned again.
    Videos of my old B7 below
    This is before I adjusted the wastegate or anything
    After adjusting the wastegate I had this miserable problem
    With the tune off I could barely boost over 5 psi soooo I just adjusted it to how it was and never used the tune.
    Can't really figure out why my car didn't take well to it but ¯\_(ツ)_/¯
    Also my girlfriend got me these puddle lights
    Joe
    @jg_iii_
  28. #68
    Mar 06 2014
    Connecticut
    Time for me to be an indecisive little b**** for a little... Excuse my rant.
    So I got the dtm bumper with the CF splitter and I got CF relaks to match.
    Now here's where I'm torn. I have the cuprazilla and its really a nice piece. I'm trying to decide if it's worth cutting the ends off so it fits in the groove where the dtm splitter goes. Personally, I think it'll look better than the dtm splitter.
    Now, since I have carbon fiber accessories to accent the car, I'm probably going to wrap any chrome trim in a carbon fiber wrap or wrap it dark grey.
    Since that's my plan, I'm trying to decide if I should change the finish of my wheels from polished lips matte silver faces, to this.
    Faces
    Lips
    Imo I'm leaning towards that because it's much easier to match 2 colors than it is 3
    Let me know your thoughts.
    Joe
    @jg_iii_
  29. #69
    Nov 08 2010
    Do it. I have been considering picking up the CF Cupra R lip from spoon fed and customizing it to fit my DTM as well. I'd like to see a little more aggressive lip to go with the DTM.
    DTM_B7_S4
  30. #70
    Apr 30 2014
    B8.5 S4, A3 e-tron
    CA, Bay Area
    Just remember they are disposable. I've already busted my DTM lip but that's because San Francisco's grading out of driveways is super fucked. But if youre doing bags I'd just jack it up whenever I'm in trouble.
  31. #71
    Mar 06 2014
    Connecticut
    My thoughts exactly! The dtm lip is not aggressive at all. Very subtle imo
    Quote Originally Posted by mlavelle92 View Post
    I have bags so that's no concern to me. I snapped my cupra r lip but that's because I was driving off of the highway to get out and stretch and the shoulder was very unforgiving (bumpy as all hell and I was going too fast)
    What do you both think about my finish options?
    Joe
    @jg_iii_
  32. #72
    Veteran Member Four Rings mpv314's Avatar
    Apr 06 2012
    Audi A4 2006 Quattro
    New York, United States
    Definitely give it a shot with the Cuprazilla
  33. #73
    Mar 06 2014
    Connecticut
    Quote Originally Posted by mpv314 View Post
    I probably will. I'll measure it all up and go from there.
    Trying to decide a wheel finish. I've been having such a struggle for so long
    Joe
    @jg_iii_
  34. #74
    Mar 06 2014
    Connecticut
    Struggle over after seeing this picture
    Joe
    @jg_iii_
  35. #75
    Veteran Member Four Rings Danaldson's Avatar
    Aug 28 2014
    Calgary, Canada.
    i would love to see the cuprazilla on the DTM.
    Edit: Oh and wheels are sex
  36. #76
    Nov 15 2011
    Those wheels are freaking nice and I dont know if anyone told you already but all ours cars have duct tape on the top of the door to hold the sound deadening material. Hard to believe but it come from the factory like that lol
  37. #77
    Mar 06 2014
    Connecticut
    That's literally so stupid lmao
    My car definitely was tampered with, at least the old B7 was anyway
    Joe
    @jg_iii_
  38. #78
    Mar 06 2014
    Connecticut
    So I fit the cuprazilla to the DTM bumper. Just rested the bumper on top of it.
    Thoughts?
    Also I have to cut the back end of the cuprazilla so it fits into the little groove where the dtm splitter goes. Has anyone had any experience cutting carbon fiber? Or any tip to make it not look cheesy without cutting the lip?
    Joe
    @jg_iii_
  39. #79
    Nov 15 2011
    You need a tungsten carbide cuting wheel. But please dont cut it imo lol Use a dtm splitter
  40. #80
    Aug 14 2014
    California
    I think it looks ACE!!!!
