Page 18 of 20 FirstFirst ... 81617181920 LastLast
Results 681 to 720 of 790
  1. #681
    Veteran Member Four Rings hyperunion's Avatar
    Sep 03 2012
    07 Xterra 4X4 , 02 20V Passat variant.
    Lehigh Valley, PA
    I gained 27 awhp from the tmd alone!.. dyno sheets show!... 😎
    Sent from my Nexus 7 using Tapatalk
    B8.5 A4 Premium +, ZF8, APR Stg II+ E85, APR HFC Downpipe, APR Carbon Intake, APR Intercooler, APR T.M. Delete, AWE Quad Exaust, ECS turbo inlet hose, H&R coilovers , H&R F&R Sway Bars, Q5 4 Piston Brembo upgrade, ECS Slotted rotors and stainless lines, OZ Ultraleggeras, Piaa, 3M Crystalline, Xpel Ultimate. IG: "Veritech1"
    RIP: B6 A4 Sport, AWE GIAC rSK04, Bilstein PSS9, OZ SL.
  2. #682
    Veteran Member Three Rings Brandon K.'s Avatar
    Apr 17 2016
    2017 Golf R, 2018 Q7 3.0T, 1991 Saab 900T
    Vancouver WA
    Quote Originally Posted by hyperunion View Post
    ...and 2 inches. Lol
  3. #683
    Sep 09 2010
    Destin, FL
    I'm going to put the APR and ECS stickers on, that's a total of 30hp right there.
  4. #684
    Sep 03 2012
    Lehigh Valley, PA
    Quote Originally Posted by The Infiltrator View Post
    Look out ! Ecs tuning power!
  5. #685
    Sep 09 2010
    Destin, FL
    Well... I only did one run because it was only hitting 15psi and the wastegate flapper is getting worse.
    Time to throw the new K04 in!
    https://www.ecstuning.com/b-apr-part...t2100009l~apr/
    https://www.amazon.com/NGK-Iridium-S.../dp/B00332810I
    http://www.audizine.com/forum/showth...4-Installation
    Going From:
    Stage II - 93 Octane 291HP / 354TQ
    To:
    K04 - 93 Octane 348HP / 342TQ
    K04 - 100 Octane 363HP / 387TQ
    I'll be putting the car on a dyno with Stage II and then again after the W/M and K04 are installed to show the true numbers with everything I have installed.
    http://emeraldcoastmotorsports.com/dynotime.html
    Box code:
    8K2 907 115 AA
    Revision:
    0005
  6. #686
    Veteran Member Four Rings Spawne32's Avatar
    Nov 20 2016
    I have a eurodyne sticker on my drivers side rear corner window, i think it adds like 100hp or so. :x
  7. #687
    Veteran Member Four Rings Zach L's Avatar
    Feb 23 2010
    Austin, TX
    Well... I only did one run because it was only hitting 15psi and the waste gate flapper is getting worse.
    Even just attempting a before run is awesome... most people will just negate doing it at all. Still not a completely useless dyno IMO.
    Get that turbo on!! Excited to hear what issues, insights, tips and tricks come from you doing the install yourself. Those will be much appreciated!
    BTW car looks good on the rollers!
    Daily Driver: B8 A4 quattro 6MT, Aruba Blue on Black, Premium Plus, Sport Package, Bang & Olufsen
    Current Projects: 2006 Cayman S 6MT • 2006 VW GTI 2.0T 6MT • 1997 VW Golf • 1982 VW Rabbit Diesel • 1972 VW Bay Window Bus
  8. #688
    Sep 09 2010
    Destin, FL
    Quote Originally Posted by Zach L View Post
    I wish it was running to it's fullest potential prior to this K04 install but at least I tried right!?
    I'll be reading through the install soon here and get a good idea before jumping into it. Hopefully I'll get it on next week, that's my target time at least.
  9. #689
    Sep 09 2010
    Destin, FL
    This is how bad my wastegate flapper was...
  10. #690
    Veteran Member Four Rings pierreb's Avatar
    2020 A4 allroad
    NH
    Lol wow
  11. #691
    Sep 09 2010
    Destin, FL
    So I took the turbo out of the box this morning to swap over the DV and whatnot and found this. The solenoid was snapped and now I have to play the waiting game to install this thing. This sucks...
    Edit: It looks like they're going to over night the part which is awesome! I'm thinking about just installing the turbo and putting on the N75 valve when it comes in. Any thoughts on how tight it might be to do that?
  12. #692
    Veteran Member Four Rings Dub_prime's Avatar
    Sep 10 2012
    2010 A4, 2008 Passat, 2002 GTI
    Bham AL
    Didn't someone else have this issue with the CTS kit recently?
  13. #693
    Sep 09 2010
    Destin, FL
    Quote Originally Posted by Dub_prime View Post
    I have the APR kit. They're sending the part over night so it sucks but nice they're getting it out with a quickness.
  14. #694
    Sep 10 2012
    Bham AL
    Oh sorry, don't know why I assumed you had the CTS... yeah I would expect them to get it resolved quickly.
  15. #695
    Sep 09 2010
    Destin, FL
    Just sucks, I took the old one out yesterday and was going to throw the new one in today but oh well. I could probably install everything and then put the N75 valve on tomorrow when I get it, I just don't know how tight it'll be if I did that.
    So for now it's like this.
  16. #696
    Sep 10 2012
    Bham AL
    I just replaced mine on the factory turbo and it was pretty tight, but manageable. If I had the turbo out I would wait though.
  17. #697
    Sep 09 2010
    Destin, FL
    Really? Went bad huh? Yeah you're right but I like to get stuff done now and hate waiting, but I will this time.
  18. #698
    Sep 10 2012
    Bham AL
    The Infiltrators Build Thread
    It didn't go bad at all, but instead of adding 30 mins or so of work in a tight spot or 2 mins with it out of the car, I would pick the latter. LOL. But I would be the same as you itching to get the turbo in.
    Edit: probably take far less time on new hoses and such, but still exponentially easier out of the car.
  19. #699
    Sep 09 2010
    Destin, FL
    I just hope I get it in tomorrow at a decent time so I can install everything, leak check, fill the coolant, change my oil and put the new gapped spark plugs. I was wanting to drive up to APR's headquarters Friday to get the tune loaded. 3.5 hours north is the closest around me and sucks! Not even an Audi dealer around here but there is a VW place.
  20. #700
    2020 A4 allroad
    NH
    One VW place around me is an APR dealer. It's pretty handy.
  21. #701
    Sep 09 2010
    Destin, FL
    Quote Originally Posted by pierreb View Post
    Now that would be nice! I wonder if I can become an APR dealer out of my garage? lol, hmmm
  22. #702
    Sep 10 2012
    Bham AL
    For a paltry 5-6 figure investment.
  23. #703
    Veteran Member Three Rings Fastbke170's Avatar
    May 01 2015
    2003 Silver GSXR1000, Mazda 3S 2006
    Northport
    hey this picture, I'll be doing this install in a couple of months. it almost looks as if you didn't need to push the cat that far back to remove turbo. I know most people just say to remove the coupler between mid pipe and down pipe and slide the cat back. My issue is my exhaust at most all joints was tac welded to prevent leaks. My system was a bitch to get right due to the y section being longer as it is from over the pond. just wondering as your picture looks like it's doable.🤔
    Sent from my SM-G925P using Tapatalk
    2012 A4 Moonlight Blue Metallic : Premium +: RS6 18" GUNMETAL WHEELS: AEM PRO DRY INTAKE: FRANKENTURBO F23L : TopGear UK HFC : TopGear UK 3"Stainless Steel Turbo Back Full Dual Exhaust: TopGear UK Eurodyne Custom Tune:Eurocode FMIC :3 Spoke S4 Black Steering Wheel w/DSG Paddle shifter : S-Tronic Shifter Knob w/Black Boot : LED White Interior: LED Red Footwell Conversion : Hoen White XEON Match Fog Bulbs :R8 Coil Packs: Puddle Projection Lamps with Audi Rings
  24. #704
    Sep 09 2010
    Destin, FL
    So... I've had one hell of a time with this turbo install. The turbo came with a broken part and the new part came today which was great so I could get it installed. Well I got everything installed besides bolting the HCF on and putting the intake in so I added coolant since I had to take a break from being bitten by fire ants which made me breakout in hives. So after adding the coolant it started to piss out the wedge on the coolant line that attaches to the turbo. I'm about to lose my shit! So now I have to spend $70 to get a new one and bend it a little better so it doesn't put too much strain on the wedge when tightening down since it's at such an angle to begin with.
    Does anyone here have small hands to get to the bolt holding the other side of the coolant line?
    https://www.ecstuning.com/b-genuine-...ly/06h121497b/
  25. #705
    Veteran Member Four Rings lettuce's Avatar
    Jun 19 2015
    Boston
    Is it leaking out of a crack in the metal line or just the banjo fitting with the crush washers that bolts onto the side of your turbo near the frame rail? If it's the banjo fitting then just tighten it up. It has to be super tight, the crush washers should take care of the seating. Installing a new line with the turbo in the car is going to be a bitch and you probably don't need it. I've installed my turbo twice and did this the first time cause I didn't tighten it enough. Haven't had any issues since learning I needed to put a little more muscle into it.
    B8 A4 - Eurodyne-tuned F23L - 12.6 @ 107 on 93
  26. #706
    Sep 09 2010
    Destin, FL
    Quote Originally Posted by lettuce View Post
    Oh no it was tight and I put a mirror under the fitting and didn't see anything from that. I was a little jacked up from the hives so I'll have to check it out more in the next day or so.
  27. #707
    Sep 09 2010
    Destin, FL
    Okay, so... I was better this morning and the hives went away but my leg is killing me, I guess I'm allergic to fire ants. But on to car stuff and how I fixed the issue.
    So the picture below shows how I have the two crush washers and how it was on the old turbo. Well the plug below the line did dent in the line but did not break the seal around the fitting after all. It was leaking against the turbo side of the fitting because the plug below wouldn't let it sit flat. So how I fixed it is easy, I took one of the crush washers and put one thick one on the outside and one thin one on the turbo side to help space the line from the plug and create that flush fitting. It worked, but we'll see when I start it up and how everything works together next week when I get my turbo coupler going from the turbo to the hard pipe I forgot to order.
    https://www.amazon.com/dp/B00CB21ASQ..._vlDezbTMXPCVH
    How it is now, it's not touching the plug below that would cause chaffing.
  28. #708
    Veteran Member Four Rings Poodini's Avatar
    Oct 26 2015
    2016 Subaru Outback 2.5 Limited
    Fremont, NorCal
    Okay, so... I was better this morning and the hives went away but my leg is killing me, I guess I'm allergic to fire ants. But on to car stuff and now I fixed the issue.
    So the picture below shows how I have the 2 crush washers and how it was on the old turbo. Well the plug below the line did dent in the line but did not break the seal around the fitting after all. It was leaking against the turbo side of the fitting. So how I fixed it is easy, I took one of the crush washers and put one thick one on the outside like you're supposed to and on thin one on the turbo side to help space the line from the plug and create that flush fitting. It worked, but we'll see when I start it up and how everything works together next week when I get my turbo coupler going from the turbo to the hard pipe I forgot to order.
    How it is now and not touching the plug below that would cause chaffing.
    Well done sir and sucks about the fire ants! Get better soon
  29. #709
    Veteran Member Four Rings Alex1188's Avatar
    Mar 10 2013
    Forest Lake, Minnesota
    Just did a motor swap and turbo swap. having a similar issue with that exact coolant line. i have the washers correct but cannot for the life of me to get it to seal perfectly. i got it right now to just a tiny little drip that forms. any tips or tricks that you did??
    |CURRENT|01.5 S4|
    |TOTALLED|09 B8 A4 QUATTRO|EURODYNE|FRANKENTURBO F23L|
    |PAST TURBOS|IHI JH5|PROTOTYPE BW K03 BILLET WHEEL|
    - OEM IHI K03 APR STAGE 2+ V1.0-1/4 MILE TIME [email protected](-85DA)
  30. #710
    Sep 09 2010
    Destin, FL
    Quote Originally Posted by Alex1188 View Post
    The only tip or trick I have man is in the post you quoted.
  31. #711
    Mar 10 2013
    Damn, worth an ask. i appreciate it though! Must have just got a crap crush washer or something.
    |CURRENT|01.5 S4|
  32. #712
    Sep 09 2010
    Destin, FL
    Yeah if you do tighten it down too much with the double washers on one side it'll leak. The washer on each side should work for you though.
  33. #713
    Jun 19 2015
    Boston
    https://www.amazon.com/gp/product/B0..._st_dp_summary
    Wait a second.. you had two crush washers on the outside of the banjo fitting, and zero between it and the turbo? No wonder it was pouring coolant 😂.
    @Alex1188 I hope you're not doing the same.
  34. #714
    Sep 09 2010
    Destin, FL
    That's how the lines were on the old turbo soooo yeah. I wonder if it's because the dealer took my motor out for the oil consumption.
    You know what's even worse than them installing the lines wrong?! It was making that loud ass rattle sound when I brought it to them, they did the oil consumption and still didn't say anything about the turbo warranty or replace it. This was before I knew it was bad and now i want to kick their teeth in and curious what else they did wrong or half ass...
    Glad you said something!! At least I installed it myself and didn't pay someone though, even if it was wrong.
  35. #715
    Feb 23 2010
    Austin, TX
    Cliff notes: Dealerships suck.
    Details on how to place the crush washers probably wouldn't even make it into the official guide used by techs. Audi would make the assumption their techs are using logic, some level of personal judgement and responsibility, and common sense. That's just not the case for most dealership techs as I've seen proven countless times from working at a dealership briefly and on others' cars.
    Glad the install is back underway.
  36. #716
    Sep 09 2010
    Destin, FL
    I should have looked at this below but didn't think about it since I was just looking at the old and doing to the new. oops... It's all back together now and good but waiting for the coupler to attach the turbo to the intercooler pipe. I don't get that in until mid week this week and then I have to drive 3.5 hours to APR for my tune to be updated.
    http://www.audizine.com/forum/showth...=1#post9987975
  37. #717
    Mar 10 2013
    Haha no my crush washers are right, just won't seal, I think I got a bad washer or something, gonna take it off and try another set of new crush washers
  38. #718
    Sep 09 2010
    Destin, FL
    Well, I took a drive to APR for the K04 software load. This thing feels like a newer / faster car and I love it. I was losing a good amount of power with my K03 wastegate flapper being bad and it's pretty apparent after this software load. Now it's time to install the W/M system when I get some time and switch it to the 100 octane map.
  39. #719
    2020 A4 allroad
    NH
    Nice!
  40. #720
    Oct 26 2015
    Fremont, NorCal
    Great stuff as always sir! Got me to thinking it's been quite a while since upgrading fr Stage 1 to 2. The car has had its fair share of tinkering and mods since so perhaps it wouldn't be a bad idea to see about scheduling an appointment locally. Though it's been a great improvement, i feel it's lost a 1/2 step here and there.
    Any suggestions as far as specifics I should have them look at in terms of the tune?
